Old 05-14-07, 08:34 PM   #1 (permalink)
RS41AB's Avatar
Thought I had it and then it overheated out on the trail
My truck overheats when wheeling in low gear. Otherwise it seems fine. New radiator, good hoses, etc.
I notice that my fan will spin freely when not running. It seems to spin when running but I'm wondering if that's just centrifugal. So, I'm thinking new fan clutch? Under load the engine must be outspinning the fan, right? My truck overheated and wouldn't start, nothing. No clicks, but all the electricals seem to work. Someone also mentioned that if the battery gets hot that's bad.
Now for my question:
Does the location of the ground wire effect anything like what I describe above? What is the stock location of the battery ground? Is it normal for the engine side of the battery to get hot? Would a heat shield be in order and has anyone else done something similiar?
Thanks.
'87 FJ60 Freeborn Red with extras
RS41AB is offline   Reply With Quote
Old 05-15-07, 01:29 AM   #2 (permalink)
RredFJ40's Avatar
The fan should spin freely when the engine is cool. It's the heat that makes the clutch lock up and spin the fan. Otherwise, your engine would take forever to warm up.
I'd say it is a plugged core in the rad if yours wasn't new. Maybe a blocked passage in the block or a hose?
Ground wire wouldn't have anything to do with overheating. Battery should be grounded to the frame and body, engine should be grounded to the frame and body and the body should be grounded to the frame.
What is your engine rpm when it is overheating?
Joel
Parting an FJ62 - PM me
"Birds have nests, foxes have dens but the hope of the whole world lay on the shoulders of a homeless man." - R. Mullins
82 FJ60 - normal stuff
68 FJ40 - gone
88 FJ62 - gone
Jefferson State Cruisers
RredFJ40 is offline   Reply With Quote
Old 05-15-07, 04:18 AM   #3 (permalink)
cruiser1873's Avatar
have you considered that it might be the thermostat
might be only partially opening
just enough to let some water through
but not enough to cool your engine ??
cruiser1873 is offline   Reply With Quote
Old 05-15-07, 06:45 AM   #4 (permalink)
jus cruzin's Avatar
as stated above the fan has a viscous fluid inside it with the combination of a bi-metalic strip the fluid will heat up the strip causing it to lock the fan when the fluid cools the strip will unlock and the fan will spin freely.
start the engine, warm it up and when/if the fan locks in you will notice the change in fan/air flow and you will hear the fan working.
check radiator core for blockages, rad cap, thermostat for operation (if the heater works this is a good sign that the thermostat is good 90% of the time) then the water pump.
with the battery heating check cells for water level, check the top of the battery for dirt, dust and moisture (if you have a muiltimeter put positive to + and with the negitive on the muilty touch near the - battery pole then run it toward the positive terminal you should have no reading on the muilty if you do you have electrolite on the top of the batt thus indicating that a cell has been boiling)
ok I have dribbled on long enough
keep us posted
and good luck
mat
Experience is something that you get just after you needed it!
It is better to ask a silly question than to explain a stupid f*** up!
jus cruzin is offline   Reply With Quote
Old 05-15-07, 07:42 AM   #5 (permalink)
Ducks's Avatar
Garage
Here is a method for checking the fan clutch - Post #7 of this Thread.
Chad... K7DUX.........1984 FJ60 with 12H-T Mojo........Web Album
................"Non impediti ratione cogitationis" - Conloquium Currus ..
2007 BMW F650GS (coming soon)
Ducks is offline   Reply With Quote
Old 05-17-07, 09:46 PM   #6 (permalink)
RS41AB's Avatar
The fan would still spin when the engine was overheated, coolant steaming out of the overflow bottle. Would that be hot enough that it should have been locked?
Old 05-18-07, 12:00 AM   #7 (permalink)
Nemesis Gnat's Avatar
check the heater, if your heater isnt working then its not circulating coolant... the thermostat also did that to me once... just hit it (redneck engineering)
Sept. 1985 FJ60, bike hauler with attitude
For sale:
1972 Buick Lesabre custom
1970 VW Baja bug (street legal)
1984 Toyota pick up (2wd)
Nemesis Gnat is offline   Reply With Quote
