Old 05-06-07, 12:41 AM   #1 (permalink)
OlympiaFJ60's Avatar
Stripped fill plug repair
Finally got around to writing this up. Here is what I did to fix my stripped out fill plug on the transfer-case. Will work for the drain plug too, but case has to be apart. I used the timesert drain plug repair kit. It is a little pricey, but I plan on doing them on all my rebuilds. It is like a helicoil or other threaded repair insert but is solid and locks itself in place.
I'm sure for the one time thing, taking it to a good aluminum welder like mentioned in some threads would be cheaper, but I like having the solid steel threads in there.
You can see the details here Timesert drain plug repair
OlympiaFJ60 is offline   Reply With Quote
Old 05-06-07, 08:22 AM   #2 (permalink)
nicholastheczar's Avatar
My Tcase fill plug is stripped out also, but $300 for the kit is too much in my mind. Now $30 on the other hand is doable. Did you do the $300 timesert or $30 Olympia kit?
White '08 Tundra Crew Max 4WD TRD
Rustic Green '70 FJ40 - SBC 350, 700R4, Stock TC, 4" Lift, 35" KM2's - Build up thread
SOLD - Blue '88 FJ62
nicholastheczar is offline   Reply With Quote
Old 05-06-07, 09:38 AM   #3 (permalink)
I did by the kit, but I can do them for people if they send me the case half, for about $30. I plan on doing this on the rebuilds I do, so the $300 cost will get spread out over several cases. I also figured I could do them for others and recover some of the cost.
Old 05-06-07, 10:59 AM   #4 (permalink)
agent orange's Avatar
So what exactly did you get for 300 bucks? A bunch of stepped helicoils?
1988 FJ 62- SUA, 1" body, 34" trxus mudders, 2.5" exhaust, 27spl Longs/Pig Inners, 4.88s, torsen LSD/lockright, 4runner brakes, other random stuff...
1986 pickup- 2wd, 22r, 4 speed, DD
agent orange is offline   Reply With Quote
Old 05-06-07, 02:51 PM   #5 (permalink)
the kit
Here is what you get, drill bit, tap w/alignment collar, inserts (5), counter bore tool, insert tool.
http://www.timesert.com/html/drainplug.html
Probably not worth it to most, but it is to me. I'm sure I could have found it for less if I wanted to search, but my local fastener vendor was able to get it in two days.
