04-25-07, 09:34 PM
| | Forum Regular
| 84 FJ60 w/ 237,000 miles . . . problems? What problems or specific issues would you all look for in a 1984 FJ60 with 237,000 miles. Does anybody have a rough idea of the market value for such a rig (hard to say, I know)?
Rob |
04-25-07, 09:35 PM
| | Site Addict
| It might need an oil change.
Dynosoar
__________________ '82 V8J60 - TPI 350 with a 700R4 attached to a splitcase, Cable Locker FF rear end, 4" SUA (National Spring), Copper Metalic, Has been south to Cabo San Lucas, BCS and North to Port Angels,WA.  Call Sign: KI6SMP |
04-25-07, 10:22 PM
| | Forum Lifer
| Replace the 1/2 inch heater hose on the driver side rear of the engine.
Replace all the vacuum hoses.
Replace the EGR gasket at the manifold..
Replace all the rubber hoses and belts.
Get the carb rebuilt.
The power steering pump will start to leak-replace it before it wrecks your air pump.
Rebuild the knuckles.
Replace the wheel bearings.
Re-torque the head bolts.
Set the valves to spec.
Have the rear diff rebuilt.
Replace the seal between the tranny and transfer, yours is bad.
Good to go for at least another 50K. (Not kidding about most of this)
__________________ Andrew
1976 FJ40 almost gone
1984 FJ-60 H41, Toybox, 4.56/ARBs, SOA, twin sticks and more
1997 FZJ-80 Driveway queen, with door dent |
04-25-07, 11:47 PM
| | 250+ Club
Join Date: Apr 2005 Location: Everywhere in Polk County!
| you might be able to just get away with rotating the tires. Maybe balance them too...and replace the windshield wipers also, definitely important...those wipers.
__________________ 88 FJ62,10" Lift, 37 SSRs, 4.88s. Skinny guys fight 'till they're burger. There are those who make things happen, those who watch things happen, and then those who wonder, what happened??? Don't say what you'll do, just do what you say. Until you've lost everything can you have anything. |
04-26-07, 07:48 AM
| | Forum Lifer
| Quote:
Originally Posted by Cruiserdrew Replace the 1/2 inch heater hose on the driver side rear of the engine.
Good to go for at least another 50K. (Not kidding about most of this) |
Huh, Never heard of re-torquing the head bolts. Everything else I did.
Can you elaborate? Im just guessing they loosen up after 25 years. |
04-26-07, 08:46 AM
| | Forum Lifer
| Re-torquing the head bolts just improves your chances of not having a head gasket leak. Also easy to do while you are adjusting the valves.
Depending on what area you are located in, I would check for rust on frame and body. A compression check is also always good to do before buying a new cruiser.
1982 FJ60 SUA OME w/AAL's, 34's, H55F, 4.7 toybox
Northern California
TLCA/PMC Member
"He who throws mud only loses ground." |
04-26-07, 10:13 AM
| | 250+ Club
Baloney ! Good To Go For Another 200,000 miles
I've over 441,000 miles and still haven't done 'all' the stuff on the list !
__________________ Nov 85 FJ60 94 FZJ80 |
04-26-07, 10:24 AM
| | Forum Lifer
| Quote:
I've over 441,000 miles and still haven't done 'all' the stuff on the list ! | lol, same here. All i do is put gas and oil in it. |
04-26-07, 11:12 AM
| | Forum Lifer
| Quote:
I've over 441,000 miles and still haven't done 'all' the stuff on the list ! | You know, I meant another 50k before any more service, but at 50k intervals you will be doing knuckle jobs, belt replacements etc. If you have not replaced that @#$% hose on the DS firewall, you have just jinxed yourself.
