Old 09-06-07, 11:24 PM   #121
No way Eh !!!
MANUCHAO's Avatar
TLCA# N0PE
So I got the exhaust manifolds(LS2 corvette).. and they fit....but, I dont know if they will squeeze in between the frame and they might be on the way of the motor mounts. I'll post pics tomorrow !!! Also unlike the original EM these have the O2 sensors right in the middle I dont know if the different location makes a difference.
MaNu !!!
'85--FJ60-L59
E-mail: viviendo.de.mar.a.cordillera@gmail.com
manamana tút turút too manamana !!!!
MANUCHAO is offline   Reply With Quote
Old 09-07-07, 12:50 AM   #122
philos1's Avatar
how about some pics frank?
1987 fj60, stuff, and some other stuff. i call her "tootsie roll"- http://forum.ih8mud.com/showthread.p...t=tootsie+roll
defender of the good, mo-fessional drunk, total art-fag, and all around nice guy...
philos1 is online now   Reply With Quote
Old 09-07-07, 01:45 AM   #123
Suffering from V8 Madness
djawahir's Avatar
I don't think the location of the O2 sensors are going to matter much, as long as 2 are before the CATs and 2 are after the CATs.
Yeah, where's the pics???
I have the uncanny ability to make things harder than they really are.
V8 swap progress: Frame's out getting galvanized and powdercoated...planning out the electrical goodies!
djawahir is offline   Reply With Quote
Old 09-07-07, 05:00 AM   #124
RT Customs Vortec Junky
iaintscared1969's Avatar
TLCA# 17528
Won't matter on the location for the sensors. Just need to make sure you have some clearance.
Cool place to get all the cruiser crap you could want! http://cruisercrap.com
1989 FJ 62 4" Hell Creek Suspension, Bridgestone Duellers 33X12.50, Hummer sliders modified of course, HI-Lift Jack, Pioneer Equipment Rack, HFS 2.5 Shackles, Defender Light rack, 4 KC Rally 800 series lights, All new steering components,First responder kit, and a whole lotta stickers!
Member: LSLC, DFW and Austin, BSLCA
iaintscared1969 is offline   Reply With Quote
Old 09-07-07, 07:11 AM   #125
V8J60 - TPI
Dynosoar's Avatar
TLCA# 17857
If they fit on the heads we will make them work. "It's only metal we can out think it". Lets get welding on that thing, you have to have it all done in time for S&T.
Dynosoar
'82 V8J60 - TPI 350 with a Turbo 400 attached to a splitcase, Cable Locker FF rear end, 4" SUA (National Spring), Copper Metalic Has been south to Cabo San Lucas, BCS and North to Port Angels,WA.
Call Sign: KI6SMP
Dynosoar is offline   Reply With Quote
Old 09-07-07, 08:19 AM   #126
No way Eh !!!
MANUCHAO's Avatar
TLCA# N0PE
thats the kind of UMPT I need guys..Thanks !!!
Pics posted later today for sure...
Cool about the 02 sensors and Im sure it doesn't matter much right now but Im curious.. I see the 02 sensors on the exhaust pipes before and after the cats but the wiring has only two connections.
Randy, that's my main concern right now but I think we'll find out once I drop that thing into the bay... and Im aware of the return fuel line.. is that were the canister comes into play...(I dont know, Im guessing) I'll learn something new today !!
Peter when is S&T ??
Laters guys..gotta do some boring stuff now (work) !!
MaNu !!!
'85--FJ60-L59
Old 09-07-07, 08:47 AM   #127
TLCA# 17528
Yes the canister will need to be hooked up you will also need a pressure regulator. The regulator needs to be adjusted to 62 PSI @ zero vacuum. Just FYI
Old 09-07-07, 10:23 AM   #128
djawahir's Avatar
What sources are you guys using for the pressure regulator?
Old 09-07-07, 10:35 AM   #129
TLCA# 17528
I use Jegs. They have many to choose from just make sure it is rated up to 65 or 70 psi with a return line.
Old 09-13-07, 11:06 PM   #130
HI Manuchao
I bought a pair of 2002 Camaro exhaust manifold for my conversion. I can stop by with them if you would like to test fit them. Let me know I'll take a few pictures this weekend too
Ferd
ferd69 is offline   Reply With Quote
Old 09-14-07, 09:50 AM   #131
No way Eh !!!
MANUCHAO's Avatar
TLCA# N0PE
Ferd I got a set of LS2 EM.
I dont know if they will fit within the frame but I'll know until I drop her in.
Yah welcome do drop by this Saturday.
I'll be working working from morning till 12 noon.
Let me know if that works for yah.
Sunday Im working so, no can do...
I just saw your thread you already got your engine in I see. Woah I want to talk to yah about the tranny drive shaft issues..
Let me know
My e-mail is the one on my sig.
Laters,
MaNu !!!
'85--FJ60-L59
Old 09-14-07, 05:25 PM   #132
V8J60 - TPI
Dynosoar's Avatar
TLCA# 17857
Hey Manuchao, Get moving on that thing! S&T is November 2nd. That is your deadline. Lets get that engine and trans in there and weld it up. Did you send your harness out yet? I can't come by this weekend but maybe next weekend.
Dynosoar
Call Sign: KI6SMP
Old 09-14-07, 05:43 PM   #133
TLCA# Associate Member/Sponsor
The Downey or AA adapter you will use from 4L60E to split case is several inches long, and eliminates the front driveshaft clearence problem. The miniturized driveshaft stuff is for different conversions using shorter adapters. We also have two different kinds of reluctor ring set-ups, one at the tranny, and one at the split T.C. I recommend you get one of our freebie V8 instruction manuals ASAP, before you burn up the alternator , and mess up on the 6 wires that go from ECU to your vehicle (not engine). Good luck with it Kimosabi!!!
Downey is offline   Reply With Quote
Old 09-14-07, 07:20 PM   #134
War Eagle
GulfShoresFJ60's Avatar
TLCA# 15437
It's great seeing vendors get on the forum and help their customers. I am getting all the info together for a swap this winter and it has been very nice seeing you helping and clarifying things on the swap. I also called today and got your instruction manuals coming which will help immensely. I can't wait to get the thing installed and I know with a vendor like y'all it'll be pretty painless!
Caleb - Auburn University
1984 FJ60 - Restomod - 2F - H55F - 4.7:1 Toybox - ARB Front - Full-Floater w/Aussie Rear - Custom Rear Bumper - ARB Front Bumper w/Warn M8274 - 37 MTRs - Vinyl Floor
1983 FJ60 - Parts Rig
1966 Mustang Coupe - 289 w/ C4
My Site
GulfShoresFJ60 is offline   Reply With Quote
Old 09-14-07, 10:43 PM   #135
No way Eh !!!
MANUCHAO's Avatar
TLCA# N0PE
Dynosoar
Dyno, I hear yah ...I got my gear box today tapped and rebuilt and will be able to do some wrenching (half day) tomorrow. Im working Sunday and I gots to work next weekend too. What about the weekend of the 29th ?
Lemme know... Thanks eh...
This week and next Im going to be prepping the frame and under body except for area where the motor mounts will be welded..
I was going to prep the front axle too but I think I'll wait....
I feel a SOA coming on but I gots to put it back together and smogged first !!!
No harness yet. If Im using all stock Engine/tranny what does sending the harness out do for the swap. Im at lost on this one. Please explain if you have the time.
Oiii Philos1 Im going to need yah mad welding skills eh !!!
The Downey or AA adapter you will use from 4L60E to split case is several inches long, and eliminates the front drive shaft clearance problem. The miniaturized driveshaft stuff is for different conversions using shorter adapters. We also have two different kinds of reluctor ring set-ups, one at the tranny, and one at the split T.C. I recommend you get one of our freebie V8 instruction manuals ASAP, before you burn up the alternator , and mess up on the 6 wires that go from ECU to your vehicle (not engine). Good luck with it Kimosabi!!!
Hi yah Jim thanks for chiming in on this. I think I'll be able to clear the front shaft I got the correct reluctor ring from yah guys along with the reading material..great stuff..... I know yah explain the alternator a while back when I went to pick up the rad but can't say I remember everything yah said....
MaNu !!!
'85--FJ60-L59
Old 09-15-07, 12:26 AM   #136
philos1's Avatar
Lemme know when you need me and I'll be over...
now get some pics up!
Old 09-18-07, 02:19 PM   #137
No way Eh !!!
MANUCHAO's Avatar
TLCA# N0PE
Hey guys..
Here are some pics of my slow arse project !!
MaNu !!!
'85--FJ60-L59
Old 09-18-07, 02:25 PM   #138
No way Eh !!!
MANUCHAO's Avatar
TLCA# N0PE
I just finish the frame and did as told...drank a cold beer after I finished.. boy that felt good and it looks good too.. I treated the side and seal them as I seen on "another" thread...
I did not do the axles as I may go higher later on...I'll do them then....
I also will have to grind to bare metal once I get the motor mounts but it'll be a little spot and then touch it up...
MaNu !!!
'85--FJ60-L59
Old 09-18-07, 02:33 PM   #139
No way Eh !!!
MANUCHAO's Avatar
TLCA# N0PE
I also went under the truck and sprayed under as I had some nice bare metal showing. So I POR15it primer it and spray painted it... It came out really nice...but most important it will last longer...
Im truly enjoying working in this truck...who knew !!!!
Next is putting back the gear box, fuel lines mating that tranny to the engine and dropping it into the bay !!
MaNu !!!
'85--FJ60-L59
Old 09-18-07, 03:05 PM   #140
TLCA# 17528
Alright Frank, SHOW OFF...Looking great though!! Let's see that engine in there!!
Old 09-18-07, 03:12 PM   #141
No way Eh !!!
MANUCHAO's Avatar
TLCA# N0PE
Eh yah Randi !!
How do yah bring the engine closer to the tranny..I got a hoist and the engine is sitting pretty on a pallet..
Does the torque converter go first... Dang Im a rookie eh !!!!
MaNu !!!
'85--FJ60-L59
Old 09-18-07, 03:40 PM   #142
TLCA# 17528
I always put the flywheel and convertor on first then move my tranny into place with the tranny jack. Put the engine on jack stands and block the back of the pan up level. Then lift the tranny into place.(Use the hoist and save your back) It seems easier for me that way and I don't have to mess with trying to get the three bolts in the convertor with a tranny to deal with. But you can put the convertor in the tranny then bolt the housing and then go for the convertor bolts. It's which ever way you feel it would be easier. Hope it helps.
Old 09-18-07, 04:11 PM   #143
No way Eh !!!
MANUCHAO's Avatar
TLCA# N0PE
Im also looking at getting a fan for the rad..
Do any of you guys know if a LINCOLN MARK VIII ELECTRIC RADIATOR FAN would work.
Will this be overkill at 4-5k CFM.......
I have a new rad (aluminum) waiting to be installed...
MaNu !!!
'85--FJ60-L59
Old 09-18-07, 04:49 PM   #144
TLCA# 17528
I think it would be overkill. You can use the Contour fan and be just fine. What size Alt. is on that engine? 105 or 130 it is stamped on the Alt.
Old 09-18-07, 05:46 PM   #145
philos1's Avatar
nice job Frank!
Old 09-18-07, 06:35 PM   #146
PAFJ's Avatar
TLCA# 16335
Damn Frank... lookin sharp!
Mike S.
'85 FJ60
PAFJ is offline   Reply With Quote
