04-12-07, 10:54 PM
| | 250+ Club
| Upgrading all 4 brakes!/bigger front,disc rear. Need Help! Hey guys... Just bought the rear disc brake brackets for my 1985 fj60. I should be getting it in next week. I will start visiting the junkyards for the rest of the parts.  I am also going to upgrade the front. Read the tread on upgrading to 4runner discs/calipers with a t100 master cylinder. But I am also going to convert the rear! Is the T100 master cylinder enough? Or is there a better one for all wheel disc brakes? Guys I need to order all the parts... I would like to start on it next week...
need your help.
Oh and what do I do about the hand brake? I saw one that mounts on the transfer case (I think). If so...would the same system work when I do a 5 speed conversion? (I plan to do it by the end of summer). Or do they make calipers (for the rear disc mod) that I can tie my hand brake cable to?
thanks. |
04-12-07, 11:15 PM
| | Site Addict
| The t-100 master should be perfect for the disk rear, its probably better for the disks than a rear drum setup.
What kind of calipers are you gonna use for the rear?
__________________ 1988 FJ 62- SUA, 1" body, 34" trxus mudders, 2.5" exhaust, 27spl Longs/Pig Inners, 4.88s, torsen LSD/lockright, 4runner brakes, other random stuff...
1986 pickup- 2wd, 22r, 4 speed, DD |
04-12-07, 11:52 PM
| | Site Addict
| search for eldorado calipers. Several people have done it a few were having difficulties with the eldo e-brake, Spook50 comes to mind.
I was thinking about forgetting the hand brake altogether and going with a line lock but was worried about either wiring an electric one to work correctly or running lines into the cab.
Either that or doing a driveshaft or pinion brake.
__________________ Joel
----- Parting an FJ62 - PM me
"Birds have nests, foxes have dens but the hope of the whole world lay on the shoulders of a homeless man." - R. Mullins
82 FJ60 - normal stuff
68 FJ40 - gone
88 FJ62 - gone Jefferson State Cruisers |
04-13-07, 01:53 AM
| | Site Addict
| i think you should get the eldorado rear calipers, but expect the e-brake to take a bit of fab and work to get it to work properly.
__________________ 83BtJ60 rustbucket,Merkur turbo+intercooled,SOA,aussie locker Custom bumpers,,4.88's, longs and poly rears.RDB's +4runner calipers, parabolics in front, 39.5 IROK's on DC-1's
92FJ80 Cummins 6BT, Airbagged, part time 4wd conversion, rancho air adjustable shocks, custom bumper+8274, 37" nittos, RTT,Mall Ready! |
04-13-07, 07:34 AM
| | 250+ Club
| If you need calipers for the rear, I have a pair. PM to discuss if you want. I'm not so far from Los Angeles, I'm in Claremont.
Don |
04-13-07, 10:05 AM
| | what he said
| I do not know a single person that thinks the Eldorado pbrake works worth a crap.
It is good for tech inspection but that is about it..
__________________ I am kinda gay.......
I've set the bar, don't trip over it....
"Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
04-13-07, 10:23 PM
| | 250+ Club
| Hey guys.....
1st... I will definitely grab a t100 master over the week end...
2nd... I will be using these to convert the rear...It comes with instructions to use mid 80's gm calipers and chevy truck rotors... Soo..... I will have to try that first. Looks like its worked enought to the point of making a bracket for them.
3rd.... well I will have to worry about the hand brake soon after.... I will be limited to level grade parking in gear. LOL. |
04-13-07, 10:31 PM
| | 250+ Club
| AGENT ORANGE!!!! Hey... what are the other parts??? I read your write up... but since I'm a newb..... I'm clueless.    What else do I need ..you know that 20$ part? mm... well you wrote:
"(not sure how the brakes differ on a 60) youre gonna need to budget for an inline residual valve to keep pressure on the rear brakes to counteract the return springs. Without a residual valve, itll take a couple pumps to get the drums working. I got a 10 lb wilwood valve from summit for 20 bucks. Youll need a pair of 1/8 inch NPT male to 3/16 compression/flare fittings to mate the valve up to the brake lines on the truck."
sorry dude but you lost me. I need the parts....w,w,w,w,w?
where do those go?  go a pic with an arrow or something
I will have my friend help me...(hes good but not a modder) Man I feel like a real NOOB! right about now.
Pls. help. |
04-14-07, 06:31 AM
| | Site Addict
| You wont need the residual valves with the disks, they are only needed with the drum rears. You might want to plumb a proportioning valve in so you can adjust when the rears lock up.
04-14-07, 09:47 AM
#10 (permalink)
| | 250+ Club
| sorry Orange but ???"plumb a proportioning valve"???
Dude... I do my own tune ups...and even change my gear oil's... but man....thats it. |
04-14-07, 10:26 AM
#11 (permalink)
| | Tank Buster
| Im using four runner IFS four piston calipers and vented rotors up front, and 1985 truck rotors and calipers in the rear. Im also using an FZJ80 master cylinder. The truck stops on a dime....
__________________ 2001 VW TDI Bora
1987 Toyota HZTJ-60
I'm a democrat member of the House of Representatives, and I've got what it takes to take what you've got! |
04-14-07, 01:14 PM
#12 (permalink)
| | Forum Lifer
| Quote:
Originally Posted by HZJ60 Guy Im using four runner IFS four piston calipers and vented rotors up front, and 1985 truck rotors and calipers in the rear. Im also using an FZJ80 master cylinder. The truck stops on a dime.... | How did you install the rotors and calipers in the rear? Do you have a SF or FF rear?
__________________ Doug G
Seattle, WA
TLCA#12671
1987 fj60, 310,00 miles, 3" lift, 33X10.50's BFG MT, dual battery, rear drawers, CB, tuffy, , lockright, 4.10's and H41 soon |
04-14-07, 01:29 PM
#13 (permalink)
| | Site Addict
| Quote:
Originally Posted by GAS-A-LOT! sorry Orange but ???"plumb a proportioning valve"???
Dude... I do my own tune ups...and even change my gear oil's... but man....thats it. | With the disk rears you have the possibility of locking up the rear brakes before the front, which is a bad thing. You can put a valve inline between the rear output of the MC and the rear disks, so that you can dial in the amount of pressure the rears get to keep the braking force balanced appropriately between front and back. You'll need a flare tool so you can flare the brake lines so you can get a good, safe connection. You may have to do some work on the lines in the rear to get them set up right so it would be a good tool to have. You may be able to rent a set from a autoparts store.
-Matt
04-14-07, 09:25 PM
#14 (permalink)
| | Site Addict
| Quote:
Originally Posted by agent orange With the disk rears you have the possibility of locking up the rear brakes before the front, which is a bad thing. You can put a valve inline between the rear output of the MC and the rear disks, so that you can dial in the amount of pressure the rears get to keep the braking force balanced appropriately between front and back. You'll need a flare tool so you can flare the brake lines so you can get a good, safe connection. You may have to do some work on the lines in the rear to get them set up right so it would be a good tool to have. You may be able to rent a set from a autoparts store.
-Matt | Like he said.
Its actually really simple once you know how a proportioning valve works.
Like he said.
__________________ 1988 FJ62 (Toylet): LT1, 4L60e, IPOR seats (heated), 3" OME HD w/ 4+ Ubolt flip, 1" BL, 33x10.50 BFG KM's, Longfield 30 SS, PP Rears, Aussied, ARB/Warn M8000/HID's, TG sliders, RL harness, Thule box, and a 125 lb. Bouvier des Flandres. |
04-15-07, 01:04 PM
#15 (permalink)
| | 250+ Club
| sweet! what year 80 did you get the master cylinder from? |
