Old 02-25-07, 06:53 PM   #1 (permalink)
Rookie
Question Knuckle Bearing Question HELP!!
I am new to this so here goes. My name is Will and I have a 1990 FJ62 build date 12/89 on the door post. My buddy is rebuilding my knuckles with a kit from Cool Cruisers of Texas. They sent the Koyo knuckle bearings and everything looks complete. However, the driver side has different bearings than the kit and also different from the passenger side. The factory knuckle is stamped 1.8 on top and the bearing is offset and has a sleeve inside the race. the race is also stamped 1.8. They are both top and bottom. The kit is for my vehicle and so far I have not seen any info about this problem. It appears that it sets a funny camber to the spindle? Any help would be great. Also what else to do? I have replaced rear brakes completely, front brakes completely, wheel bearings on front and brake hoses. The steering is all new except the box. I have no problems just trying to rebuild everything that leaks or needs repair. Very good shape, except probably needs valves adjusted and timing set. Also how important is the valve adjustment if not been done in years? I have a lose clunky shift when you let off the throttle. and it shift from park to D/R hard. Is this motor or trans mount. Trans has been rebuilt. what else should I do to it to drive daily. So far I love it and have only had about six months or so. best vehicle ever, except this funny steering knuckle issue and the bearings.thanks
williegluv is offline   Reply With Quote
Old 02-25-07, 07:20 PM   #2 (permalink)
Dynosoar's Avatar
TLCA# 17857
WOW! that is the first time I have ever heard of that. There are guys here with lots more experience than me, but that sounds rather unusual.
Dynosoar
'82 V8J60 - TPI 350 with a 700R4 attached to a splitcase, Cable Locker FF rear end, 4" SUA (National Spring), Copper Metalic Has been south to Cabo San Lucas, BCS and North to Port Angels,WA.
Call Sign: KI6SMP
Dynosoar is offline   Reply With Quote
Old 02-25-07, 08:19 PM   #3 (permalink)
cruiser_guy's Avatar
TLCA# 16387
Some folks screw up when they rebuild and they use a bearing with the wrong taper.
www.wirrell.com
Old 02-25-07, 08:35 PM   #4 (permalink)
Pin_Head's Avatar
It is a new one on me, but if the inner hole is not concentric with the outer race, the bearing is probably designed to adjust caster or (more likely) camber, depending on which way it is offset. Since I am not aware that camber is adjustable on these axles, I would guess that an offset b earing may be used to compensate for a bent axle tube.
Pin_Head is online now   Reply With Quote
Old 02-25-07, 09:20 PM   #5 (permalink)
Dynosoar's Avatar
TLCA# 17857
Post some pictures this is an odd one.
Dynosoar
Call Sign: KI6SMP
Old 02-28-07, 02:08 PM   #6 (permalink)
Front Range 4x4's Avatar
TLCA# 15452
Will - Have you figured this out?
Chris - http://frontrange4x4.com
1988 FJ62 - Emily - 260,000+ miles, FJ60 Round Eyes, H55F, SUA, SR, OME Heavies, 35x12.5's, trimmed fenders, Solid Rock Off-Road bumper & sliders, rear locker, Warn xd9000i, dual batteries, OBA, Scion radio, etc.
Front Range 4x4 is offline   Reply With Quote
Old 02-28-07, 08:13 PM   #7 (permalink)
TLCA# 1594
how many miles on the truck...?
75' 40 350,sm 465 toybox splitcase F/R ARB's and other crap....
member Trail Crew/ L A Co. Cruisers
TLCA#1594
DaveWest5150 is offline   Reply With Quote
Old 02-28-07, 08:23 PM   #8 (permalink)
Pathfinder's Avatar
TLCA# 16560
got me? got some pics. I just did my knuckles from CCOT and both sides were the same.
-LX450 - '96 Cherry condition
- CDL Pin-7 Mod, Aussie Locked Rear, Wheel Re-Finish, OME 3.5" (nice and level) 851 w/1inch space / 863. MAF drop brackets, Slee'd sway bar drops, SS brake lines, PHH, 315/75/16 BFG MT KM2's, Aux fan, and a cool Hula Girl Dash Mod
[__]=LEXUS=[__]
Pathfinder is offline   Reply With Quote
Old 02-28-07, 10:10 PM   #9 (permalink)
dd113's Avatar
Heard of it but never seen it. The NAPA suspension catelog lists offset caps and bearings for TLC. You will need a good parts guy to dig out the paper catelog and find this. I will root around tomorrow but I doubt I will be able to find it.
I bet the axle was bent in such a way the camber was screwed and an alignment shop installed the fix.
David Dearborn
www.urbanlandcruisers.com
Foreign Minister for life of the White Trash of the Elwood Chapter.
Visit our E bay store:
http://stores.ebay.com/Land-Cruiser-Stuff
I collect Hello Kitty
dd113 is offline   Reply With Quote
