Pitman Arm/Drag Link Connection Question Hello All...semi-newbie here with an '84 60, 206,000 on engine 2" lift with Aussie susp, cherry
You all seem knowledgable in the land of Cruisers, I am learning as I go. Question: The connection b/w my pitman arm and drag link appears to be aged and loose. there is a 1/2" gap which looks like it could snap if not given attention. Knowing little about this steering system, I'm not sure if this is normal or should be looked at. The rubber "bushing" or sleeve which sits at the connection (on top of the drag link where the pitman arm slides through) seems "flat and saggy". should there be a gap to give the drag link some vertical play or should this connection be flush? Enlighten me, for I am naive in the art of the Cruiser.
David Halterman |
