02-07-07, 07:27 AM
| | Rookie
| Interior air vent for Newbie owning '89 FJ62 I'm new to IH8MUD, so please be easy on me with this first question...The '89 FJ recently purchased has a broken passenger side air vent "director". I purchased a used/refurbished vent control on-line; however, there are no installation directions [and no information I could easily find on-line].
Before I start dismantleing the dash, is there a simple way to pop-out/replace the plastic vent? Is there access through removing the glove box?
Thanks for your help! |
02-07-07, 07:48 AM
| | Forum Regular
| Vent Problem Hello,
I dont have the answer to your question but the best investment that you should make ASAP is on The Original Toyota Repair Manual. The book costs $50+ but the diagrams, pics, and instructions are supurb. This is the book that they give to the Toyota Technicians. I have seen these manuals on Ebay. Take care and good luck.
-Graham |
02-07-07, 08:24 AM
| | Merchant of Death
| just pop/pull it out......and pop it back in, nothing will break.
__________________ Truth is a torch that shines through the fog without dispelling it. Always be true to your work, your word, & your friends, & you will never live a day without peace |
02-07-07, 08:29 AM
| | Forum Lifer
| Welcome to Mud GreyGoose!
You do have to pull the front of the dash since the vent goes in from the back. Just carefullty remove screws and panels. The trim around the heat controls should come off first as I recall. Just make sure you don't put too much pressure on anything and break it. When it comes to the instrument panel the speedo cable has to be released.
It's really quite easy, just take your time and don't use force.
__________________ Chris - http://frontrange4x4.com
1988 FJ62 - Emily - 260,000+ miles, FJ60 Round Eyes, H55F, SUA, SR, OME Heavies, 35x12.5's, trimmed fenders, Solid Rock Off-Road bumper & sliders, rear locker, Warn xd9000i, dual batteries, OBA, Scion radio, etc. |
02-07-07, 08:31 AM
| | Forum Lifer
| Landpimp is faster than me but things will break. Specifically the tab that "locks" the heater/AC piece in place, I know because I cracked mine.
Remove that first and nothing will break unless excessive force is used.
02-08-07, 12:40 AM
| | Rookie
| Thanks! Very much appreciate to good advice! |
02-08-07, 08:21 AM
| | Merchant of Death
| hmm.........your vent stuff must be brittle.........I have pulled a bunch of these.....I just yank em out from the front and pop em back in.....but I guess if you want to be safe.....take the dash off? Quote:
It's really quite easy, just take your time and don't use force. |
02-08-07, 10:32 AM
| | Forum Regular
| try pullin it out if it breaks remove the dash to install the new one. if it survives the new one should be fine seeing that it has not been sitting in the sun with heat blowing through it for twenty years
__________________ 84 bj60
02 vw tdi
66 vw window bus
77 gmc lives in the bush |
02-12-07, 09:12 AM
| | Rookie
| Final Outcome... Thanks again to everyone's advice. I had ordered the entire vent control including housing, and based on your information, I figured out the inner control popped out of the housing  [with some light force]. I then popped the old inner vent control out and the new one in, and did not have to remove the dash. If replacing with entire vent housing, the dash would have to be removed.
...On to the next repair of this '89 rig. -GreyGoose |
