02-06-07, 03:19 PM
| | 250+ Club
| Grind when engaged 4wd.... damage? As I was turning out onto the main snow cover street I hit the 4wd button while turning...  It made a clicking/grinding sound and I immediately stopped and turned off the button. Once straightened out it engaged perfectly like normal but I'm paranoid about the possible damage I could have done. It's killing me b/c I always do something retarded when trying to talk on my cell and drive. I totally know better and was lecturing my wife on when to use 4wd just yesterday.  So what kind of damage could have been done? What symptons should I look for? Why am I so retarded?
__________________ 89 62 Ironmans, Arb, 33" BFG's
77 FJ 40 project - FOR SALE. |
02-06-07, 03:53 PM
| | procrastinating
| ah...ur probably fine. You should here my transfer when I engage it into 4wheel low. lol. |
02-06-07, 04:00 PM
| | Forum Regular
| does the grinding still happen now? did you try to align, and then reengage?
Does having the wheels turned just not allow the transfer gearing to properly align when egaging 4wd? |
02-06-07, 04:22 PM
| | Forum Regular
| how bad was the grinding? like when you try to shift without depressing the clutch far enoug? or like a shot glass in the garberator? if you were turning sharp the chance of one of your front wheels spinning close to the right speed to mesh is quite slim.
__________________ 84 bj60
02 vw tdi
66 vw window bus
77 gmc lives in the bush |
02-06-07, 04:49 PM
| | Site Addict
| Quote:
Originally Posted by Chase77 As I was turning out onto the main snow cover street I hit the 4wd button while turning... | 60 series wagons have buttons for selecting 4wd? I've always assumed 60 series are just like 40s and 80s in that they have a mechanical activation (stick) vs electrical (button). Although 80s only sort-of count since they are AWD (mostly).
__________________ '97 LX450 aka "The Whale" with a winch called Damien '97 FZJ80 40th AE, Antique Sage, #267 '74 FJ40, 2F, SM420, 4" Lift, ARB locked front and rear, 33" MTRs '76 FJ40, 2F, 4-speed, 4" Lift, 33" BFG ATs (SOLD) |
02-06-07, 04:59 PM
| | Forum Regular
| i think he drives a 62. its like a 60 but has more comfort options than the tractor that is my truck
02 vw tdi
66 vw window bus
02-06-07, 05:02 PM
| | Forum Regular
| Quote:
Originally Posted by corsair23 60 series wagons have buttons for selecting 4wd? I've always assumed 60 series are just like 40s and 80s in that they have a mechanical activation (stick) vs electrical (button). Although 80s only sort-of count since they are AWD (mostly). | on my 85 bj60 it has a push button 4hi activation after I manually lock the hubs, then to go into 4lo, I deactivate the 4H button and shift into 4lo.
I think this was the early version of on the fly 4wd activation like in my 4runner. |
02-06-07, 06:14 PM
| | War Eagle
| The FJ62s have a push button switch which vacuum operates the 4WD. After locking the hubs, you can press the buttom for 4-High. For 4-Low you can either press the 4-High button and shift the High-Low shifter into Low and you will have 4-Low or you can just shift the High-Low shifter into Low without the 4-High button pressed and it will automatically activate the 4WD vacuum mechanism. This is all assuming that everything is working correctly.
__________________ Caleb - Auburn University
1984 FJ60 - Restomod - 2F - H55F - 4.7:1 Toybox - ARB Front - Full-Floater w/Aussie Rear - Custom Rear Bumper - Warn M8274 - 37 MTRs - Vinyl Floor
1983 FJ60 - Parts Rig
1974 FJ40 - Rustbucket
M416
1966 Mustang Coupe - 289 w/ C4 My Site |
02-06-07, 07:50 PM
| | 250+ Club
| Just got done with a 5 hour adventure to retreive my wife. Drive usually takes 20 min. or an hours tops with snow.... but someone in a bling suv thought that 4wd meant you can drive as fast as you want.  Seems the 4wd is operating normally and I havent heard anymore grinding when engaging or making a sharp turn. I'm going to pretend it never happend.
02-06-07, 08:12 PM
#10 (permalink)
| | Forum Regular
| thats what i would do even if i didnt mean to. damb beer, what was i talking about.
02 vw tdi
66 vw window bus
02-06-07, 10:26 PM
#11 (permalink)
| | Site Addict
| Quote:
Originally Posted by GulfShoresFJ60 The FJ62s have a push button switch which vacuum operates the 4WD. After locking the hubs, you can press the buttom for 4-High. For 4-Low you can either press the 4-High button and shift the High-Low shifter into Low and you will have 4-Low or you can just shift the High-Low shifter into Low without the 4-High button pressed and it will automatically activate the 4WD vacuum mechanism. This is all assuming that everything is working correctly. | One of the many reasons I love this site...I learn something new almost each and every day! I had no idea FJ62s engaged 4 high like that
