Closed Thread
LinkBack (16) Thread Tools Display Modes
Old 03-23-04, 01:31 PM   16 links from elsewhere to this Post. Click to view. #1 (permalink)
IH8MUD Lifer - No Appeal
Mike S's Avatar
Question FJ60 and FJ62 FAQ ********* start here and come back often *********
This is a permanent (sticky) thread which will attempt to categorize and post discussions on commonly asked questions about the Landcruiser FJ60 and FJ62 series trucks. I am NOT the expert here, but will be reviewing posts. gathering and combining information from members responses to questions posted in the Cruiser Tech section.
This should help owners and caretakers to access the IH8MUD braintrust.
If you have suggestions or comments, please PM me.
Buying a 60 / 62
FJ60 or FJ62?
FJ 60 / 62 gas mileage
60 Series Paint Color Chart
Just bought an FJ62 - What's next?
Smog issues
Smog pump rebuilds and emergency fixes
Emission System demons
Removing Smog?
Common repair / replacements
Tips for installing Old Man Emu Lift
Common Torque values
Oil Gally Plug
Rear lift gate support arm replacements
Hood shock conversion
Do your own alignment
Aisin Hub Rebuild-from the 4Runner Section
FJ62 Door Lock circuit breaker fuse location
Fuel or temp guage spikes and goes back down occasionally.
FJ-62 T-case actuator solenoids
FJ62 4WD Vacuum solenoid fix for cheap
FJ62 Starter Rebuild Instructions
FJ60 alternator rebuild reference
Driver side front power window auto down relay
Power window permanent fix.
Modify the fan shroud to make water pump or fan belt access MUCH easier.
Water in your floorboard? Repair your leaky rain gutters.
Poor heat? Heater core flush.
3FE Fuel Pulsation Dampner - may improve your MPG
Intake and exhaust
Tuning and problem solving
Camshaft discussion
Tuning 3F and 2F for better performance
Valve Adjustment on an "F Series" engine
3FE Specific valve adjustment tips
3FE Specific Timing adjustment (in the 80's forum)
3FE fuel supply problems
Overheating - what to do?
FJ60 Fuse Panel data
Reading 3FE engine codes
3FE top end engine mods
Lubrication
Lubrication Secifications - 60 and 70 series Gas and Diesel Enigines
Engine oil choices for the 2F & 3F engines
Conventional or Synthetic oils - what do our members run?
"Which oil filter is best?" - Discussion
Oil pressure readings - senders and gauges
Automatic transmissions
Changing Tranny Fluid
More info on cleaning the filter and flushing the transmision
FJ62 Transmission Oil cooler install
H55F Toyota Manual Transmission swap into an automatic 3FE FJ62
Loose shifter automatic shifter fix
Loose shifter automatic shifter fix - permenant solution
Valve body install
Inexpensive ATF temp guage
Suspension and Steering
Improved handling for a 60
Fixing common steering problems
When and how to rebuild the knuckles
Jim Phillips detailed front end (Birfield and knuckle) repack
Morgan's knuckle rebuild
FJ60 – FJ62 stock spring packs
Old Man Emu and alternatives
Old Man Emu Install with pics
Parabolic Springs - discussion and photos
Talking about shackles
OME or BDS?
Thoughts on SOA (Spring over Axle)
Extended sway bar and LSPV on a lifted FJ62
FJ60 hydro assist porting
Differentials - gears, lockers, etc.
Feedback on what IH8MUD Board members are running
How to modify a Vacuum shift 62 transfer case to manual shift
Wheels and Tires for a 60 / 62
Aftermarket wheels that work & part numbers
Rims and tires
Tires the iH8MUD members are running...
Engine and drive train swaps
More power from the 2F - an alternative
Bottom line for a Diesel swap in a 60 series
Installing an H55F Toyota 5 speed in a PRE August, 1985 FJ60
Installing an H55F Toyota 5 speed in a POST August, 1985 FJ60
H55F conversion parts list
Adapting the stock tach for use with a V8
Building a 2FE from a 2F and a 3FE
Split case ratios and Modifying a 62 vacuum shift case to a manual shift.
Popular modifications
Best mods under $50
Just bought a 60 Series Cruiser? Suggestions on 'must have' modifications
Long range gas tank
Dual Battery installs and battery isolation schemes
Maximizing performance of the stock alternator
Brighter Headlights for the FJ60
How to - Headlight wiring harness upgrade
Questions about wiring driving lights
Bed liner on the exterior
4 Runner brakes - easy bolt on brake upgrade
Sound Deadening
FJ60 Dual Alternator
Appropriate winch for 60 series
Getting rid of the exhaust crossover pipe (rock catching) on the FJ62 Exaust
Sway bar disconnects
Extra grab handles in a 60 series.
Very cool Under Seat Storage
FJ62 sluggish power window fix
2WD LOW t-case mod
FJ62 Headlight upgrade
4Runner Calipers, T100 MC, Rotors and Backing Plate Eliminator install
Mike S is offline
Closed Thread
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/13183-fj60-fj62-faq-%2A%2A%2A%2A%2A%2A%2A%2A%2A-start-here-come-back-often-%2A%2A%2A%2A%2A%2A%2A%2A%2A.html
Posted By For Type Date
Lancruiser FJ's/BJ's - BB.BC4x4.COM This thread Refback 09-14-09 06:15 PM
should I buy this car? - YotaTech Forums This thread Refback 09-12-09 11:08 AM
whats with the steering! - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 04-21-09 04:17 PM
whats with the steering! - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Pingback 03-30-09 10:11 PM
Untitled document This thread Refback 11-11-08 02:20 PM
Anyone know of a good mechanic in Jax? This thread Refback 10-11-08 11:26 AM
Axle Seal Install Advice - Minnesota Toyx4s Bulletin Board This thread Refback 10-02-08 07:41 PM
Форум сети Toyota4X4.RU -> Маразм крепчает :) Покупаю еще одну 60ку :) This thread Refback 09-20-08 06:32 AM
1990 and older Toyota Landcruisers... - NASIOC This thread Refback 08-26-08 09:51 PM
Buying FJ60: What to look for? - Page 2 - Expedition Portal Forums This thread Refback 06-11-08 05:23 AM
Toyota4X4.RU -> :) 60 :) This thread Refback 02-28-08 03:20 AM
Toyota4X4.RU -> :) 60 :) This thread Refback 02-27-08 09:57 PM
Toyota4X4.RU -> :) 60 :) This thread Refback 02-27-08 02:34 PM
what to look for on fj 60 This thread Refback 02-04-08 03:31 PM
Info om motorer levert til 60 serien - Pirate4x4 Skandinavia This thread Refback 12-30-07 09:32 AM
91 FJ 62? This thread Refback 12-25-07 06:01 PM
