Suggestion for FAQ - Common Torque Values
Once you do a number of repairs on your cruiser, you prolly remember what to do. If you are like me though, the exact torque values might not be firmly in memory. So, I was thinking that a useful FAQ would be a list of common torque values.
When the list is done, I was thinking to post this as a pdf to facilite saving and printing. Thoughts? This is NOT a how-to, it's only a reference table of how tight to turn the various nuts/bolts. I'm happy to look up the values, but want to get input as to what to include. Here's a starter list...please feel free to add Front Axle Freewheel Hub Cover - 7 ft-lb Freewheel Hub Body - 23 ft-lb Front Hub Bearing lock nut - 58 ft-lbs Knuckle Studs - 71 ft-lbs Spindle Mounting bolts - 34 ft-lbs Brake Caliper - 65 ft-lbs Brake Hard Line - 11 ft-lbs Tie Rod to Knuckle Arm - 67 ft-lbs Relay Rod to Pitman Arm – 67 ft-lbs Relay Rod Clamp bolts – 33 ft-lbs Steering Damper – 54 ft-lbs (both ends) Sway Bar End Links - 13 ft-lbs Sway Bar to Axle - 9 ft-lbs Drive-Shaft/Companion Flange - 54 ft-lbs (4 per end) Differential Carrier Nuts – 34 ft-lbs (10 total) Diff drain/fill plugs - 36 ft-lbs Spring Center Bolt - 26-39 ft-lbs Spring Pins - 67 ft-lbs U-Bolts - 90 ft-lbs Shock - Upper - 19 ft-lbs Shock - Lower - 70 ft-lbs Rear Axle Rr Diff Cover - 9 ft-lbs Rr Diff Carrier Nuts – 34 ft-lbs (10 total) Drain/fill plugs - 36 ft-lbs Drive-Shaft/Companion Flange - 65 ft-lbs (4 per end) Spring Pin – 9 ft-lbs Shackle Pins – 67 ft-lbs U-Bolts – 90 ft-lbs Shock – Upper – 47 ft-lbs Shock – Lower – 27 ft-lbs Sway Bar to Axle – 9 ft-lbs Sway Bar end-links – 9 ft-lbs General Tune-Up/Fluid Change Transfer case fill/drain plug - 27 ft-lbs Spark plugs - 20 ft-lbs Oil Drain Plug - 20 ft-lbs Diff drain/fill plugs - 36 ft-lbs Valve cover - 78 inch-lbs Misc Wheel Lug nuts - 90 ft-lbs Thermostat housing bolts - 156 in-lbs Waterpump to block - 27 ft-lbs FJ62 Transmission pan bolts - 61 in-lbs __________________ Doug G Seattle, WA TLCA#12671 1994 fzj80, 275,000 miles, 285X75/15, Billy's, dual batteries 1987 fj60, 310,00 miles, 3" lift, 33X10.50's BFG MT, dual battery, rear drawers, CB, tuffy, , lockright, 4.10's and H41 soon Last edited by lovetoski; 06-15-08 at 11:57 PM. |
FAQ'd
__________________ Greg Thompson CottonLand Cruisers 00 Camry: Stock 5SFE - 27 MPG 89 FJ62: OME 2.5, 2" BL, Superior shackles, F250 towers, 315 BFG KM2's on zj80 wheels, Extreme A440, FF,4:88,RDB,longs,ARB front,Lockright rear,Warn XD9K in Rover AL bumper, Wildernes Roofrack, Marlin Sliders, SROR 1/4 sliders. |
Head stud torque on 2H motor? Help please.
__________________ HJ60 2H Diesel Donkey Pretoria, South Africa |
I have no clue - and no appropriate manuals to refer to. However the diesel forum has some folks on it who could help for sure!
__________________ Doug G Seattle, WA TLCA#12671 1994 fzj80, 275,000 miles, 285X75/15, Billy's, dual batteries 1987 fj60, 310,00 miles, 3" lift, 33X10.50's BFG MT, dual battery, rear drawers, CB, tuffy, , lockright, 4.10's and H41 soon |
Is the torque for the manual transmission the same as the transfer case?
Chad
__________________ Chad... K7DUX.......1984 FJ60 - Daily Driver......Web Album ................"Non impediti ratione cogitationis" - Conloquium Currus .. ![]() |
Can you add the torque for the engine side cover & oil pan?
__________________ Kevin 1982 FJ60 Northern California SF Bay Area TLCA/PMC Member "He who throws mud only loses ground." |
Ya, good idea! Can't find the value for the engine side cover though? Looked in the engine manual and Haynes too.
#8 | |
I couldn't find anything either for the side cover. I am guessing it is a little less than the oil pan bolts. __________________ Kevin 1982 FJ60 Northern California SF Bay Area TLCA/PMC Member "He who throws mud only loses ground." |
Ya, I was looking at different but similar bolts and was guessing similar. I'm going to do a few updates to the original list and repost. Thanks again for the sugggestions.
#10 |
Have you reposted this somewhere? I assume the tranny drain/fill is the same as the diffs but I can't find it in the FSM.
#11 |
I didn't find it either.
#13 |
"Are we sure about the Torque settings on the Waterpump to block values?
I'm looking at the FSM and it calls for 13Ft Lbs. Can anyone verify this?" I just did mine a few weeks ago, and yes it's 27 ft-lb. __________________ Are the voices in my head bothering you? 1989 FJ62, OME lift, 33" BFG A/T's & a new air freshener |
#14 |
"Thermostat housing bolts - 156 in-lbs"
That seems correct, but it may be simpler to write 13ft-lbs.
#15 | |
Yep, you're right....I was looking at a different FSM for a different Toyota Vehicle.
#17 |
A440F Transmission Pan?
#18 |
#19 |
How about the head bolt for a 2f?
__________________ -1986 Fj60-32x12.5 on stock rim, white roof, desmog, headers, hellas, surf racks, sunroof, springs so flat a yardstick sits flush -1989 Porsche 944S2-3.0ltr pita to work on, why I bought cruiser |
#20 |
[quote=JLH911;3407306]I have the FSM's but can't find a torque value for the five bolts that bolts the intake to the exhaust manifold. There are three on top and two on the bottom. Anyone have them?
How about the EGR tube?QUOTE] Ditto for me- J-tube torque value. It's hard to find some of this obscure info in the FSM. __________________ Scott Granbury, TX 1987 Beige FJ60. |
#21 |
I found the torque specs for the intake manifold to head:
Page 3-20 of the 2F Engine manual: "Tighten eack manifold bolt and nut a little at a time to the specified torque in the sequence shown in the figure." Tightening torque: (29-36 ft-lb) (3.9-5.1 kg-m). I'm hoping 2mbb will be along soon to post a picture of the page so you all can see the sequence. I still can't find any specs for the EGR J-tube flange. Or anything else related to the exhaust, for that matter. __________________ Scott Granbury, TX 1987 Beige FJ60. |
Buy Anything On eBay | Loans | Personal Loan | Car Insurance | Car Loan |
