#391 |
So a quick estimate if you were doing a resto for someone for $20 hr. cash would be about $4700 so far for labor.
Interesting. Always wondered what some places charge for major restoration jobs. I look forward to your picture updates. They give me hope for my job.
#392 |
$20/hr? HA! Good luck finding any shop willing to work for that! I do quite a few side jobs out of my home shop, and still charge $40/hr.
#393 |
Body Work
I got 3 hours over the last two nights on the 60. I have been working on the driver side rear corner and rear sill. That rear section is just shot!
Rear Sill Before: ![]() Rear Sill After: ![]() Lower rear inside prepped for patch: ![]() Driver side - small rust marks ground out and primered for now:
__________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/60-series-wagons/128847-83-fj60-build-up-thread.html |
#394 |
This stuff sucks. I don't know if I'd do it even for $40/hr for a living - maybe if I had a better work area it'd be better.
__________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 |
#395 |
wow!
__________________ Real Americans drink PBR |
#396 |
you've got to factor in the overhead. even out of someone's home garage/shop there are plenty of expenses-utilities, tools, basic supplies like paper towels, grease and beer.
__________________ m416 build http://forum.ih8mud.com/trailer-tech...6-buildup.html soa troopy-sold http://forum.ih8mud.com/fj45-owners-...oa-troopy.html hj45lv*t build http://forum.ih8mud.com/fj45-owners-...2At-build.html |
#397 |
Mark's Adapter
Sorry for no posting lately... been painting the house
.I did pick up a Mark's Adapter from Propilot for $440 w/ shipping though! Score! http://forum.ih8mud.com/sale-parts/2...d-adapter.html Chevy 350 Engine side: ![]() 2F Bellhousing side:
#398 |
Body Work
Got 2hrs 45min on the 60 today. Worked more on the bodywork on the rear driver side floor and quarter panel.
Piece welded in: ![]() Rear inner wheel well cleaned up. Welded some extra air chisel holes shut.
#399 |
#400 |
Remember, I make aluminum beverage cans for a living... mostly domestic for me
#401 |
Body Work
Got 4hrs 15 min on the 60 between last night and tonight. I finally got all my summer chores done, so it's back to business.
Still plugging away on the bodywork... I am starting to get tired of weld, grind, weld, grind, cut, fit, repeat. Driver side corner rear panel fixed: ![]() Driver side inner rear patched: ![]() Rear sill fixed up: ![]() More Rear sill on passenger side: ![]() Driver side fender well patch welded in ![]() ![]() ![]() !!!!
#402 |
You can't stop now, but taking a break is always helpful. Just look how far you've already come. I enjoy watching this and seeing your progress because what looks like small stuff takes a decent amount of time and finess to get it to look right. Sounds like it might be time for a new tool to play with
__________________ 85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff. build-up: Family Haulin' FJ60 |
#403 |
Body Work
Got 1hr 50min on the 60 today. More bodywork. Got the driver side rear quarter panel patch finished. Almost got done with a driver side rocker panel patch too.
D.S. Quarter Panel: ![]() D.S. Rocker Panel:
#404 | |
New Tool
![]() New Welding Gloves on right, old ones on the left:
#405 |
Body Work
Got 1hr 30 min on the 60 last night. I got more work done the body. I finished the driver side rocker panel patch and got all the snake blinders welded shut. I cleaned the undercoat from inside the driver side wheel well to see the damage as well. Only part I am stumped on is the inner fender... not a fun part to make from scratch.
Snake blinder holes before: ![]() Snake blinder holes after: ![]() Driver side rear quarter. What's left to fab up on the outside and the ugly inner wheel well: ![]() On the front side, you can see how the inside is rusted out, the outside still looks good: ![]() Driver side inner fender wheel well all cleaned up for welding:
#406 |
Project60, How much of the inner fender are you replacing? Just the portion that contains the outer brace?
I'm in the same situation, but I think I'm going to try my hand at building a hammer form to replicate the inner well and outer brace. Let me know how much of yours you will be reproducing. . . if it's the same as mine you may be in luck. Brandon |
#407 | |
I was thinking of doing it is sections... might not even be as round as it was originally. __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 |
#408 |
Body Work
Got 1hr 20min on the 60 tonight. I finished up the area above the windshield. I kind of cheated on that area - I simply ground out all pinholes and filled them in with weld... I thought it would be easier than a big patch in an area that is so visible. I also touched up the firewall and made sure there were no holes or rusted through spots - all good, some surface rust.
Then I got to work on the driver side rear fender well. I cut the front half out. It's better than I thought, so I will just patch the rusted spots and weld the section back into place. Above windshield: ![]() Driver Side inner fender well - to the front: ![]() Section Removed w/ some rusted through spots:
#409 |
Location: I live in Oslo.. the biggest village in Norway
Nice work! If you need some inspiration check out this Norsk Land Cruiser Klubb :: Vis Temaet - Kåre`s HJ60 garasje
("neste" at the bottom means next page) This guy is restoring a HJ60 to "way better than when it left the assembly-line condition" This one will last for 50 more years for sure!
__________________ HJ60..OSLO
#410 | |
#411 |
Body Work
Got 1hr 30min on the 60 tonight. I patched up the front part of the inner wheel well on the driver side - compound curves suck! I did alright for having a hammer and vice though.
Inner wheel well driver side patched up: ![]() Driver Side wheel well patch cut out and tacked into place:
#412 |
Pretty soon you're going to have a sand dune of just grinder dust in your garage! You're moving right along.
#413 |
Body Work
Got 1hr 45min on the 60 tonight. I got the outside of the rear driver side fender patched up. I then started to weld in the inner wheel well... what pain! I hate welding upside down
. it will take a little more to finish up.I did have a fun moment . The zippers on my coveralls is broken... and a weld bead dropped down through my coveralls burned through my clothes and ran down my leg and into my shoe. That was the fastest I ever got my shoe off! Outside of driver side fender patched up: ![]() Inner wheel well painted before install:
__________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 Last edited by Project60; 07-25-08 at 07:35 PM. Reason: Forgot 2nd pic. |
#414 |
Sounds like time for a lead shot filled leather bag.
Impressive work! __________________ My opinion is worth what you paid me for it. |
#415 |
#416 |
Weld Burn
I had to throw a picture of the weld burn a day later... The splatter burned through 2 sets of clothes and a sock before it did this!
Right Foot:
