#151 |
Frame is out!
Spent 3hr and 20 minutes yesterday on the 60, finally got some pictures of it today. I moved the frame out from under the body and rolled the body to the other side by myself.
Got the rear spring pins and all the bushings out. Removed the spare tire carrier as well - it's in good shape, just some surface rust and a rebuild of the mechanism in order. I started grinding off the rivets for the rusty section in the rear too. New position in Garage: ![]() ![]()
__________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/60-series-wagons/128847-83-fj60-build-up-thread.html |
#152 |
Rust in Frame
Here you can see the rear unboxed sections. I am planning on removing the channel and boxing the frame. Nothing special here.
Passenger side: ![]() Driver Side:
__________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 |
#153 |
Rust in Frame
Here is the rear X member. I will have to cut out the bad and weld in new.
#154 |
Spare Tire Carrier
Spare tire carrier looks ok. No major rust, just surface.
#155 |
Rust in Frame
This is the part that concerns me. I am thinking of cutting this section out and welding in new. Anyone see any problems as long as there is sufficient patch panels?
Driver side is through just behind the spring pin: ![]() Passenger side is fine:
#156 |
I don't think it looks all bad.
Why not just grind the surface first and see how it looks - it really just looks like surface rust to me. I take it you're going to eventually POR it. |
#157 | |
![]() Good call on the rear spring hangers. I will sand blast before doing any cutting. __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 |
#158 |
Frame Prep
Spent 30 minutes on the 60 tonight until the battery in the drill died. I think the quickest approch to removing the buck rivets is to grind them flat and drill them out. Still have a lot to go
.End Result:
#159 |
Frame Rust
Well, I took a closer look at the areas behind the rear spring pin. Sorry Winston, but we were both wrong. I did the old screwdriver trick (with a light tap of the hammer). The driver side of 2-3" long and the passenger side is small.
I am going to have to grind off the center cross member and cut out/weld in patches for these areas. I will also have to weld in some extra material for strength. I can feel a ton of dirt in the frame, so it must of caused the rot. Driver Side: ![]() Passenger Side:
#160 |
Frame Repair
Started a discussion thread on how best to repair frame:
http://forum.ih8mud.com/60-series-wagons/168426-frame-repair-rust.html#post2382287 EDIT: Decision Made - Make repairs to current frame. Keep posted to see how. __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 Last edited by Project60; 07-27-07 at 03:47 PM. Reason: Decision made on frame path |
#161 |
Ouch!
#162 |
Frame Repair
Got 2 hours on the 60 this weekend. Grinding and drilling out rivets. Rivets are my favorite
. Gonna be out of town for a few weeks, sorry no progress for a while .Stay tuned for the frame repair... __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 |
#163 |
Frame Repair
Got 2 hr 15 min on the 60 frame. I removed all the rivets finally and got the rear C channels out of the back of frame. both were rusted through. I could not find any tricks for removing rivots besides grinding and drilling them. I will say, I took my air hammer and it really helped to pull the C channel away from the frame rails - Only trick I got. The first picture really shows how much crap is behind the C channel.
Driver side removed: ![]() Passenger Side Removed: ![]() Air Hammer ($10 @ Harbor Freight):
#164 |
Frame Repair
Got 2 hours on the 60 yesterday. I got the 3rd to last cross member cut out and out of the way. You can see the inner C Channel is in more than one section. I will be cutting out a small section and welding back in for repair.
Crossmember removed: ![]() Passenger Side: ![]() Drivers Side: ![]() Rear X Member Welded in and additional "support" to keep frame from twisting:
#165 |
Bolt Holes?
A little help from those still watching? The holes just behind the passenger side X-Member are for holding the fuel and brake lines - correct?
If I have to remake a piece for here, I want to make sure the hole locations are not critical. Passenger side, behind X-Member:
#166 |
Naw, those holes aren't critical. You could always bend the lines a little to where you put new holes or make some kind of longer tube clamp like the stock ones just custom for you application. Or you might get away with eliminating them since those line have a bunch of bolts holding it to the frame anyways. Or you could use long black zip ties around the frame. Or...
__________________ 85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff. build-up: Family Haulin' FJ60 |
#167 | |
Confirmation
. I will put the holes back in, I just won't worry about getting them too close to the original location.
#168 |
Frame Repair
Well, got 40 minutes and 3 cut off wheels on the 60 last night. I cut out a section of inner frame rail from the passenger side. You can see in the photos that the inside of both rails has a "water" line on it. What happens is that the drail holes in the frame get clogged (mine have rocks in them) and water sits inside the frame rails. You can see how much crap is inside the frame as well.
Passenger side with cut out inner frame rail: ![]() Passenger side inner frame rail. You can see the "Water" level rusted into the steel:
#169 |
It looks as if you are working long and hard on this 60! Just out of curosity, why did you make the choice to keep your current frame?
Zack |
#170 | |
The main reason I chose to repair what I had is to learn. This is a project for me and I am learning new skills and practicing others. The second reason is cost - If I simply replace everything with new or near new this thing would get out of control very quickly .There are only 2 real problem areas:
#171 | |
Zack |
#172 | |
I am thinking a few coats of zero-rust sprayed on (for practice using the paint gun) and a topcoat of chassis black after sandblasting the frame. __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 |
#173 |
LC Junky
just a curious question.....
if you are planing on media blasting the frame any ways, why do it after the repairs? why not first so you can see what has really gone on with the rust.? yours is not the first i have seen this done or talked about. project looks like a great experience. thanks for the write up. __________________ 87 FJ60, rust free, 186K, 3rd owner, 31x10.5 BFGAT, Red Top, 4runner calipers 1964 Dodge D100 Sweptline CSS 88 FJ62.........SOLD (\__/) (='.'=) (")_(") |
#174 | |
#175 |
Sand Blasting Material
I bought 300 pounds of 30/60 coal slag on Friday from United Western Denver ($33 total). They said this was the best for 3/32" to 1/8" tip size. Hopefully I will get to use it soon
#176 |
Frame Pressure Washing
I got an hour and 40 minutes on the 60 this afternoon. The neighbor was more than kind in letting me borrow his pressure washer. It was a gas powered 2500psi model - worked like a champ. I drug the frame out to the driveway (well... the kid's wheelbarrow and my creeper sit did all the work
). I sprayed it down and soaped it all up. They say to clean it up good before sandblasting as the grease can get driven into the steel. After cleaning the top, I hoisted the front in the air with my engine hoist and sprayed inside the frame rails until the water ran clear. Pressure Washer: ![]() Clean frame in need of sandblasting and paint:
