Old 05-05-07, 07:21 PM   #91
Project60's Avatar
Body Removal - Dont's
Spent 7 hours on the 60 today. I must say it was an utter failure.
We got the body lifted up and set down on the 2x4 cross beams. That was the start of the bad. It tended to crease the seams on the body and the rust under the rear driver side simply collapsed.
The other problem is that a wood structure was just too weak and the wheels gave out. I ended up putting the wood frame up on jack stands until I can rebuild something out of steel - stay tuned.
Body on double 2x4 cross beam:
Wheel "ripped" off the wooden dolly:
Both rear wheels ripped off:
83 FJ60, major project in progress
Check out status of the build: http://forum.ih8mud.com/60-series-wagons/128847-83-fj60-build-up-thread.html
Project60 is offline   Reply With Quote
Old 05-07-07, 09:27 PM   #92
Project60's Avatar
Body Removal - Redo
45 minutes on the 60 tonight. Repositioned the jack stands and removed the wood from the side of the old dolly for better access.
I am going to pick up some 1/8" thick 1.5" square tubing tomorrow to build the frame out of. The frame will attach to body mount locations using the stock bolts, rather than letting the body "sit" on the dolly it will be bolted to it.
Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847
Old 05-10-07, 09:14 PM   #93
Project60's Avatar
Steel Tubing for Body Dolly
Went and picked up 48 feet of 1.5" 11 gauge (.120" thick) square steel tubing. Turns out they loaded 18 gauge and I didn't notice until I got home. Went back and they gave me 72 feet of 11 gauge for all my trouble (cut into 8 foot pieces).
Should start working on the dolly shortly, stay tuned.
Old 05-11-07, 10:12 PM   #94
Project60's Avatar
Steel Body Dolly
Spent 1.5 hours on the 60 tonight. I got some plates cut out of 1/8" steel for the castors to bolt to. Drew out a plan for the dolly. Have to clear the rear axle and studs (~61") and still stay inside the trailer dimensions of 70".
Sorry no pics, couldn't find the camera.
Old 05-12-07, 04:12 PM   #95
Project60's Avatar
Steel Body Dolly
1hr 45min on the 60 this afternoon. Got the frame cut out and welded up. Flat steel pieces welded on for the wheels too. Still need to get it assembled under the body and then some attachment points made.
Pics to come.
Old 05-13-07, 01:20 PM   #96
Project60's Avatar
Steel Body Dolly
30 minutes on the 60 today. Some welding, but got sidetracked with Mother's day.
Old 05-14-07, 10:08 PM   #97
Project60's Avatar
Steel Body Dolly
1hr 50 minutes on the 60 today. Got some more work on the body dolly done tonight. I love welding upside down . Coming together nicely. I just need to get the attachments made up to connect to the body mounts.
Some pics tonight:
Old 05-18-07, 09:57 PM   #98
Project60's Avatar
Steel Body Dolly
2 hours on the 60 tonight. Made brackets to attach the rear body mounts to the steel body dolly. Each of the attachment points will bolt on so that I can remove one at a time to paint or sandblast under the attachment point.
Rear of Dolly:
Rear Corner:
Rear Body mount attachment:
Old 05-19-07, 05:29 AM   #99
Great looking project.I think I'm going to sell mine. 82 fj60 $500.00 cell 740-225-2917 udogtoys@aol.com
udogtoys is offline   Reply With Quote
Old 05-19-07, 05:32 AM   #100
project truck 82 fj 60 $500.00 marion,ohio 43302 740-225-2917 or udogtoys@aol.com
Old 05-28-07, 08:24 PM   #101
Project60's Avatar
Steel Body Dolly
2 hours on the 60 this weekend. Sorry for the lack of progress, but travelling a lot for work lately. Finished the steel body dolly and got it attached to the body mounts. I will mount the wheels and get some pictures of the completed dolly later this week.
Old 06-02-07, 02:21 PM   #102
Project60's Avatar
Steel Body Dolly Complete
1.5 hours on the 60 today. Finished up the body dolly today and got it put down on the wheels. Much better than the wood dolly. It is still not the right way to do it, but as long as someone else learns from my mistakes, I am alright with it. I may still have to unhook the rear leafs/shocks to get the dolly to clear the frame.
Removed the powering steering hoses and cooler as well:
Body Dolly Complete:
Front Mounting Point for Body Dolly:
Old 06-02-07, 03:03 PM   #103
HJ61TurboDiesel's Avatar
Did anybody ever put a 60 Cruiser body on a horizontaly swinging turret so one could rotate the bottom of the body skywards. Rust repairs would be so much easier.
HJ60(1) 4 liter TurboDiesel. 10" Mickey Thompson, 33X12.5X15 Goodyear MT/R. Frame-off rebuild: full-floater rear. Brakes, hubs, steering, drive shafts, transfer, H55F and turbo rebuildt. PTO. Frame rust-free and galvanized, Working on rusty body %#!+? )%¤# Nordic Blue
HJ61TurboDiesel is offline   Reply With Quote
Old 06-03-07, 09:27 PM   #104
Project60's Avatar
Yes
Most others make a rotisserie. Unforturnately, I wouldn't be able to rotate it with the height of the garage, so I had to put it on a dolly.
If you want to see it done right, check out the two builds by BuckRoseau:
http://forum.ih8mud.com/fj45-owners-club/39575-1965-fj45lv-build-up-resto-thread.html
or
http://forum.ih8mud.com/fj45-owners-club/104821-3-days-3300-miles-later.html
Old 06-03-07, 09:30 PM   #105
Project60's Avatar
Disassembly work
2.5 hours on the 60 today.
Removed the driveshafts, removed the front bumper brackets (took an hour alone ), removed the charcoal canister and the gaurd around the pass side brake line manifold.
Driveshafts:
Frame w/o brackets:
Missing Charcoal Canister:
Old 06-03-07, 09:40 PM   #106
Project60's Avatar
Hoist points
Quick question to all who have done it. Where is the proper spot to lift the engine from? I don't have a 2F engine manual yet and wanted the correct location.
I have seen a few engines out in other posts, but not exact lifting locations? Any body got pictures?
Old 06-04-07, 12:30 PM   #107
Project60's Avatar
New Thread
I asked the lift question in a new thread here:
http://forum.ih8mud.com/60-series-wagons/159136-2f-engine-hoist-points.html#post2224612
Old 06-06-07, 06:26 AM   #108
Project60's Avatar
Engine Removal
1hr on the 60 last night. I pulled the engine and set it on the floor for now - still has tension on the chain to keep it from tipping.
Rear Driver side lift point:
Front Pass side lift point:
Engine Being lifted:
H42 Tranny:
Pass side frame:
Driver side frame:
Engine on floor (board) with light tension in chains:
Old 06-06-07, 06:28 AM   #109
Project60's Avatar
Boys
Had to throw a shot of my boys driving the truck for the last time. I think the oldest one is going to miss not driving the truck for a while. Next time it comes back, they might be MUCH bigger at my current pace!
Old 06-16-07, 08:30 PM   #110
Project60's Avatar
Disassembly work
1 hour on the 60 today. Pulled the steering box and the engine mounts. Started removing some of the front steering assembly, but I will need to find a puller for the pitman arm.
Sorry for the lack of progress, but 3 out of the last 4 weeks I was out of town on business.... time flies.
Old 06-16-07, 10:18 PM   #111
klinetime574's Avatar
Just read this thread over again. I forgot I had posted in it. Do'h.
We have the same engine hoist. Harbor Freight?
Oh and awesome job!
1984 FJ60, 170 Thousand Miles, OME, 33x10.5x15 BFGoodrich All-Terrain T/A KO, 15x8 Eagle 058 Alloys
klinetime574 is offline   Reply With Quote
Old 06-17-07, 09:10 PM   #112
Project60's Avatar
Engine Hoist
Yeah, 2 Ton folding Harbor Freight engine hoist. For how often I figured I would use it, I had to go with them.
Old 06-18-07, 10:39 AM   #113
Same here too. My brother is using it for his 240sx right now.
Old 06-18-07, 11:11 AM   #114
philos1's Avatar
looking good, keep it up!
no cruiser right now :(
1995 Volvo 850 Turbo
defender of the good, mo-fessional drunk, total art-fag, and all around nice guy...
philos1 is offline   Reply With Quote
Old 06-23-07, 09:52 PM   #115
Project60's Avatar
New parts and disassembly work
Not too much work yet this week. 1 hour today on the 60. I pulled the pressure plate, clutch, flywheel and bellhousing from the engine. Had to stop to get bolts to mount to the engine stand.
I spent most of my time this week getting parts for the truck.
  • Found a 2,000 lb engine stand (non-folding) on craigstlist this week.
  • Found a used ironman/BDS 2.5" lift from beatdown83fj60. He had shocks and full bushings as well. Used them for less than a year.
  • Picked up a set of 2 jaw pullers to get the steering separated as well.
Engine Stand:
Ironman/BDS Lift:
2 jaw pullers from my favorite chinese tool store:
Old 06-23-07, 10:02 PM   #116
Dave-T's Avatar
TLCA# 16951
Good to see more progress. Every little thing get you farther (or closer, depending on how you look at it). Great looking boys you got, lot's of fun.........
Glad the photos are a little larger
