12-14-06, 09:55 PM
| | Forum Regular
| Specter Allen Bolts for Differential Drain/Fill Hi All,
Searching through the threads I see that many folks are using the Specter Allen bolts for differential drain/fill plugs, transmission etc, found here: http://www.sor.com/sor/partpict.tam?...%201963%2D1973
My question is whether folks can provide any long term feedback as to how they like these over time vs. the stock bolts? Better, easier to deal with on the next fluid change?
Mahalo!
__________________ 76' FJ40 (new to me)
89' FJ62 Living Aloha(sold)
06' Tacoma (  Carrier) |
12-14-06, 10:36 PM
| | Forum Lifer
| They work well. I always end up grinding my diff plugs off on the rocks. My only concern is that the magnets dont seem to be as strong as the OE plugs. |
12-14-06, 10:53 PM
| | Forum Lifer
| They work well. But they are not a Spector part. They are an OEM Toyota part, they are the drain plugs they put in several cars. My Lexus has one in the drain plug for the transmission.
Search around for the part number, you can get them from your local dealer for less than $pector charges.
__________________ KB1OSF
'98 Lexus ES300
'04 Toyota Highlander |
12-14-06, 10:57 PM
| | Forum Regular
| Allen Diff plugs Have they caused any problems through not capturing as much metallic material or do you find you are just needing to drain out the cases more often?
12-14-06, 11:14 PM
| | Site Addict
| Get 'em from C-Dan. He's always got a few on the shelf.
I wouldn't fret about the capacity of the magnet.
__________________ 1986 V8J60
There's a feeling I get, when I look to the West... |
12-15-06, 07:03 AM
| | photosynthesizing
Join Date: Oct 2003 Location: Palm trees and cool streams
| Differential Drain Plugs, Magnetic, 10mm allen: 90341-18021 ($2.03)
Differential Drain Plug Gasket: 12157-10010 ($0.89)
Just go to your local dealer. They are way cheap.
aka Bushrat 1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled! 1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane |
12-15-06, 07:43 AM
| | Site Addict
| I have never had a problem with the non-hex plugs.
If they ever strip I guess moving to the hex would be nice.
Agreed, go to the dealer and pick 'em up. |
12-15-06, 09:05 AM
| | Forum Lifer
| We have had problems on the rocky trail here with the stock hex bolts. The corners get caught by a rock and unscrewed. It doesn't seem like it should be possible, but I have seen it several times.
I've never seen that with the Allen style plugs. They work great and are highly reccomended. Cruiserdan at American Toyota is my source for those-I think they are stock in Camrys.
__________________ Andrew
1976 FJ40 almost gone
1984 FJ-60 H41, Toybox, 4.56/ARBs, SOA, twin sticks and more
1997 FZJ-80 Driveway queen, with door dent |
12-15-06, 02:29 PM
| | Forum Lifer
| Quote:
Originally Posted by Cruiserdrew We have had problems on the rocky trail here with the stock hex bolts. The corners get caught by a rock and unscrewed. It doesn't seem like it should be possible, but I have seen it several times. | Ditto .. you can order it from MAF .. !
__________________ HJ-60 2H-T Intercooled Tencha
Cruisers on my mind, blood and soul ! Join us at our local Panamá Off Road Forum Quote:
Originally Posted by crushers if you are achieveing the max boost then it isn't the boost that is going to kill your engine... it is your right foot. | |
12-15-06, 02:56 PM
#10 (permalink)
| | Forum Lifer
| What I'd really like to see is a square-drive plug w/ a 1/2" hole so I can just use my breaker bar. Or even a 3/8" would probably work just fine. I think Land Rover uses something like that... anyone know the thread/pitch of the plugs?
__________________ 91 j80 w/93 1HDT. OME 850/860 + 1" front & nchargers, LEDs, Full rack, HIRs, Pyro/Boost, ACSD, Geolander MT's 33x12.50, Tuffy center, body damage, Temp Gauge(M), BigRed air, ARB RR locker. In garage: lightforce lights, Superwinch X9, maggiolina, air horns... ask me about Costa Rica Realty! |
