12-06-06, 07:16 PM
| | Forum Lifer
| SBC Dual Exhaust Advice & Pix?  Have to change the exhaust on my '84 with the 5.7 Vortec & 4L60E. Currently it's a single 3" pipe exiting on the driver's side in front of the (extended) shackle. Emissions Nazis (they're just doing their job) say I need 2 cats, so that makes it hard to do with the way the Y is now, so I'm guessing it will end up being duals. I've read that a crossover pipe increases HP - any thoughts? I kinda like the sound without it.
I like the idea of it exiting on the side (as opposed to the stock location), but I want to go to a Dakar suspension with the standard OME greasable shackles & I'm afraid 2-1/2" pipes wouldn't fit in front of the shackles & might get crushed on compression. What about after the shackles - will I crush them on steep departures?
Any pix of clean, clever setups would be appreciated! |
12-06-06, 10:49 PM
| | Forum Lifer
| why not run two small cats inline like the 80's? |
12-07-06, 05:14 AM
| | Forum Lifer
| Has to be the same configuration as the donor vehicle: per side from the manifold O2 sensor/cat/O2 sensor. Nothing after that matters (no emissions equipment) so I could run straight pipes as far as the EPA is concerned. |
12-07-06, 08:17 AM
| | 250+ Club
| If going to dual, you need the crossover pipe or an X-pipe to help with the scavenging effect of the exhaust. It has to do with the firing order, and the pulses of exhaust pulling the next one along keeping it running smoothly. Could you just have everything same as stock up to the cats and then just route two pipes back into one? my 2 pesos
__________________ 81 BJ60 Completely Gutted, Bobbed 33"- Looking for lockable 80 series rear axle.
85 Runner w/ 33's, OBA, Custom bumpers with rear swing out,8274.
Other stuff
My budget build/trip to the Arctic Circle: http://forum.ih8mud.com/expedition-b...something.html |
12-07-06, 12:37 PM
| | Site Addict
| I'm a little confused as to what the emissions dept is requiring you to have. Did the donor vehicle have 2 in-line cats after a Y? 2 cats before a Y, or a duel exhaust with separate cats? Are they placing any requirements on where your exhaust dumps out?
__________________ Rising Sun 4 Wheel Drive Club Member
1976 FJ40, A project with little progress.
1985 FJ60, wife wants me to sell it, you want it?
1997 FZJ80 40th Anniversary, daily driver |
12-07-06, 02:29 PM
| | Site Addict
| Corbet, 2 pre cats w/ 02 sensors, then 2 cats w/ 02 sensors, then it Y's (IIRC) and he can do whatever he wants... i'd say go back into a single 3" after the cats????
Tinker, look at the BTB site, they have a slick looking install on a 40 that has both cats right next to each other and slightly offset so that they take up minimal room. that's what i'll probably be doing on mine this spring...
__________________ no cruiser right now :(
1995 Volvo 850 Turbo
defender of the good, mo-fessional drunk, total art-fag, and all around nice guy... |
12-07-06, 02:50 PM
| | Forum Lifer
| Hobie - yes I could, but I don't think it would fit the way it's plumbed now. The Y is in front of the trans, & there wouldn't be enough room for a cat unless they were vertical below the new ramshorn headers, immediately after the 1st 2 sensors. It could end in a single exhaust, but I'm concerned about placing a 3" pipe anwhere sensible (not in front of the rear shackle, anyway).
Corbet - again, per side from the manifold:O2 sensor/cat/O2 sensor. In other words, 2 sensors, 2 cats, 2 sensors. It doesn't matter to the EPA what comes after the last sensor(s) - that's not emissions equipment. Do you have cats on yours? |
12-07-06, 09:51 PM
| | Site Addict
| Quote:
Originally Posted by Tinker but I'm concerned about placing a 3" pipe anwhere sensible (not in front of the rear shackle, anyway). | I've got a 3" pipe running through the rear spring (before the shackle) and it works fine. You just need to angle it slightly toward the rear as it exits the line with the frame. I have a 4" Alcan lift and anti-inversion shackles. HTH.
__________________ 1986 V8J60
There's a feeling I get, when I look to the West... |
12-08-06, 05:12 AM
| | Forum Lifer
| Greg -
I'll be going to the 2-1/2" lift OME medium in the rear with greasable shackles (probably anti-inversion). What I didn't mention is that I have a Dynomax Ultraflo & a 3" pipe that exits just before the left rear shackle. It's annoyingly loud after about 15 min on the highway.
I know a good exhaust shop can set me up with mufflers that will rumble at idle, growl on acceleration, but purr at cruising RPMs. |
12-08-06, 07:57 AM
#10 (permalink)
| | Forum Regular
| Tinker,
I assume that this setup is particular to the vortec and not the TBI. Is that correct? Original equipment for the engine being swapped in? Or for the vehicle?
I am putting in a '92 tbi motor from a single cat, 1 o2 sensor vehicle and am curious. What are you running now? I wonder if your old setup would work for me...
__________________ 1988 FJ62 - SBC TBI, 700r4, 1973 Jeep Commando |
12-08-06, 11:00 AM
#11 (permalink)
| | Site Addict
| I do not have cats but I probably have space for them if I wanted to. My 3" dumps straight down directly behind the rear axle. I think I've got some pics on my home PC. I'll post or take new ones later. I'm also running a 50 series Flowmaster. It has the sound traits your looking for. Modest noise unless you put your foot into it.
12-08-06, 12:25 PM
#12 (permalink)
| | Forum Lifer
| Turtle -
The configuration I described is specifically for the 98 5.7 Vortec. My current exhaust system might work for you, but it would depend on the exact placement of your engine. I believe it's all welded past the flanges on the headers, so it will have to be cut apart to take it off, anyway. The block-hugger headers are going away, too.
The truck is at my shop right off X184 in Castle Rock if you want to see it some time. |
12-08-06, 01:04 PM
#13 (permalink)
| | 250+ Club
| This set-up is for OBD-II setups only.............the rear O2s are actually called 'cat-monitors'........they can tell if the cats are working or not......so yeah it has to be 2 seperate and side-by-side cats and 4 sensors....
here's what I did on my car: http://www.hotrod.com/featuredvehicl..._lx/index.html
)scroll down to the last pic)
it wasn't OBD-II but I had to run a single exhaust 'cause of the external fuel pump and offset fuel tank.............
Flowmaster makes that cool Y-pipe that goes from 2 2-1/2" pipes to a single 3"
worked well in that situation and with the big muffler and mandrel bent 3" tailpipe I don't think I lost much HP if any..............
On a Land Cruiser there isn't room to spread out the exhaust like this but if the cats are laid on their side and welded together it could come out pretty compact..
Oh Yeah don'y buy cheap Hi Flo cats 'cause they suck and fall apart in no time(ask me how I know)
Magnaflows are pretty good..............
__________________ <---- That's my boy! Carson James Born 6/05
84 FJ60 249,750 miles....... 32X11.50 BFG MT 15x8 A/R XM OME , Bilsteins, AussieLocker rear, Unity spots
my 1/4 mile time is faster than my 0-60
(Quote)- Dazza "Don't think of it as a slow car.
Think of it as a fast tractor." |
12-08-06, 06:16 PM
#14 (permalink)
| | Forum Lifer
| Thanks, Jeffmo - nice setup!
But I really need to see FJ60 setups with dual exhausts, preferrably with an auto (since I have one). |
12-11-06, 07:47 AM
#15 (permalink)
| | Forum Regular
| Still no pics? Darn - I've been watching this to see how it turns out. Is it that most conversions have been done in no smog law states? Tinker - have you asked some of the shops that do conversions if they have pics of their setups? TLC claims they do conversions.
Does your current setup have AIR injection in the headers?
12-11-06, 12:05 PM
#16 (permalink)
| | Forum Lifer
| Turtle -
I have an excellent example of an illegal, single-exhaust setup from a "good" shop (not TLC by any means, but that's another story).
I'll have pix when I'm done, but I'd hoped to see some clever dual setups with high-flow cats & X-pipes. BooHoo |
