Where to get a diagram of vacuum lines?
Big D
Where can i get a good diagram of all the vacuum lines for my 83' FJ60? And where they go?
Thanks.
should be a diagram under the hood as well, but its not the easiest to figure out.
If you want pics of the lines I can take some for you.
[quote author=Landpimp link=board=1;threadid=12807;start=msg117853#msg117853 date=1078848123]
[/quote]
That would be most excellant. I am still having an issue with some rough idleing. My RPM's don't change at all but i can feel the roughness. I have changed the fuel filter, checked the airfilter and now i need to make sure all my vacuum lines are where they are suppose to be.
You can send pics to searsj@aetna.com
thanks LP.
this is the vacuum lines the passanger side of the engine, this is on a 82 fj40,but is identical for a fj60.
I'll find or take the other side stuff hopefull tonight. But even with the pics, the emmision manual will prolly be needed
this might help
http://www.ih8mud.com/tech/desmog.html
its the desmog diagram, but disregard the desmog stuff and its then correct for the fj60, this is right out of the emmision manual. the
