#121 |
Damn that looks awesome!
__________________ if you can cut a Tcase in half with a cheap circular saw you can do anything. BIG WAGONS RULE |
#122 | |
#123 |
Kool Arrow
![]() I used a YJ jeep safari top for shade worked ok I'm goin to add a few in to the end ![]() ![]() Metal Techs cage rocked and JK's weldin held great had a trail I pulled the top off and used the cage 5 or 6 timed to pivet off of the get down it got every fender but the cage rocked... thanks again guys ![]() added 4 points to the rear for the boys __________________ 82 FJ60 OME Heavy 33BFG's 410's & quicklock ARB bull & side bars and warn 12k down for repairs 85 FJ60 Trail beater SM 420 crawler box lockers 456,38's bobed & choped with a Metal Tech cage 85 SR5 new DD want am I thinkin GIT-R-DONE!!!! TLCA #15374 low riders want SWITCHES... 4 wheelers want SHIFTERS www.jkcustoms.com Last edited by kling-on; 05-28-07 at 08:58 PM. |
#124 |
I friggin love that truck, it looks great topless! Just please dont cut much more off, it still looks like a wagon as it is.
Could you post a pic of how you worked out the door latch, like a shot from the inside? Im gonna cut me up a half door this summer and thats the biggest issue i can think of. __________________ 1988 FJ 62- SUA, 1" body, 34" trxus mudders, 2.5" exhaust, 27spl Longs/Pig Inners, 4.88s, torsen LSD/lockright, 4runner brakes, other random stuff... 1986 pickup- 2wd, 22r, 4 speed, DD oh, and custom tree damage |
#125 |
Kool Arrow
no more cutin more tube yes only parts comin off for now the truck grinds off on the trail .. and I tell you she hates me cause the drivers side is hammered
![]() my door I cut to low you need to stop at the bottom line on the dimpel cause the handle on mine is aZip tie in the opening if you stop higher you could move the inside handle to the top easy I will look for a pic __________________ 82 FJ60 OME Heavy 33BFG's 410's & quicklock ARB bull & side bars and warn 12k down for repairs 85 FJ60 Trail beater SM 420 crawler box lockers 456,38's bobed & choped with a Metal Tech cage 85 SR5 new DD want am I thinkin GIT-R-DONE!!!! TLCA #15374 low riders want SWITCHES... 4 wheelers want SHIFTERS www.jkcustoms.com |
#126 |
Thanks, a guy in my club as a set of doors sitting around so i thought i might give it a go. Does it make a big difference in visibility?
#127 | |
Kool Arrow
yes and you can lean out more too I dont think I will do the rear door so the boys have more protection ... dont know if I want to do the passanger front yet either I'm the only one that need to see and I got hit with alot more crap then every one else __________________ 82 FJ60 OME Heavy 33BFG's 410's & quicklock ARB bull & side bars and warn 12k down for repairs 85 FJ60 Trail beater SM 420 crawler box lockers 456,38's bobed & choped with a Metal Tech cage 85 SR5 new DD want am I thinkin GIT-R-DONE!!!! TLCA #15374 low riders want SWITCHES... 4 wheelers want SHIFTERS www.jkcustoms.com |
#128 |
drool...
__________________ "Just bump it" I am offended by reality all the time. http://www.cascadecruisers.com/ http://www.myspace.com/zachsu ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html |
#129 |
I don't think it's a huge advantage cutting the passenger door, maybe if you remove it complete, but it's another story.
#130 |
Kool Arrow
my DIXIE horn came in today
gota swap out my Birfs(poped a stocker) and install CB radio and horn for nexted weeks day trip to K-rocks
#131 |
that paint looks too good to be rattle canned... what did you use?
#132 |
Ride On...
Lookin freakin sick man....I hope we get to wheel someday together...
__________________ www.NFCruiserheads.org FJ45 Crawler and a 1983 Hilux... has had no peers for 50 years... |
#133 |
Kool Arrow
its pic good great from 10 ft but you get closer and you can see the spray marks ... gun handle thing made it way smoother and I primed all of it(white)first to make thw orange POP the brand was Krylon
#134 |
wow... looks good! That'll make it easy to "touch up" the paint if need be too.
#135 |
Kool Arrow
![]() swapped out my busted shafts killed one inner I think I can save the other as a trail spare ... cant wait for Trees __________________ 82 FJ60 OME Heavy 33BFG's 410's & quicklock ARB bull & side bars and warn 12k down for repairs 85 FJ60 Trail beater SM 420 crawler box lockers 456,38's bobed & choped with a Metal Tech cage 85 SR5 new DD want am I thinkin GIT-R-DONE!!!! TLCA #15374 low riders want SWITCHES... 4 wheelers want SHIFTERS www.jkcustoms.com |
#136 |
Ride On...
I know that sight all too well. I need some 30 spline longs bad.
#137 | |
Kool Arrow
tryin to sell some parts so I can get my 30spl longs .... hope I make it throught nexted weekend with these ...only time will tell had to use a slide hammer in the threaded end to get the one busted bell out
#138 |
damn... you busted those up pretty good. I've wailed on my 30 splines with the 36s in double low and havent run into a problem yet... we'll see how they hold up with 4ds...
#139 |
Ride On...
The last one I broke exlpoded. I think I must have cracked it early on during the trail becuase i back up a little something with the wheels turned a little bit and it just exploded. Enough so that it stalled my ram assist, and dint allow my wheel to turn or rotate.
Thats about the time the sky opened up and it began raining. Im strapped for cash now but hopefully in the next year Ill be sitting on some 30 spline longs and 4340 hub gears. __________________ www.NFCruiserheads.org FJ45 Crawler and a 1983 Hilux... has had no peers for 50 years... |
#140 |
Kool Arrow
longs on order...
#141 |
Kool Arrow
poly rear axles on order , box taped for hydro waitin on fittings and mounts ...BLING BLING post up pick whekn the parts show
#142 |
So I guarantee that if I had the money and the spare 60 lying around it would look like yours.
__________________ 89 62 250k miles, 4 inch BTB lift, snorkel, custom built front and rear bumpers, M8000 "However, I consider my life worth nothing to me, if only I may finish the race and complete the task the Lord Jesus has given me - the task of testifying to the gospel of God's grace." Acts 20:24 |
#143 |
Kool Arrow
Longs and polys in rebuilt the knuckles and installed ARP studs no pics...to bad you cant even see all that cool stuff cause its inside
replaced motor mount with alum blocks and bolts ... no more broken mounts .... wont have the hydro on in time but I got a date with a trail nexted weekend hope to make it more that 45 min this time :![]() ![]() ...so happy just had to share
__________________ 82 FJ60 OME Heavy 33BFG's 410's & quicklock ARB bull & side bars and warn 12k down for repairs 85 FJ60 Trail beater SM 420 crawler box lockers 456,38's bobed & choped with a Metal Tech cage 85 SR5 new DD want am I thinkin GIT-R-DONE!!!! TLCA #15374 low riders want SWITCHES... 4 wheelers want SHIFTERS www.jkcustoms.com Last edited by kling-on; 09-24-07 at 10:49 AM. |
#144 |
wooohooo... glad to see you're up and running again!
