I bought my upper steering u-joint thru cruisder dan. I need help getting the old one off. I've taken out the bolt that holds the joint halves together, taken all four "hognose" clips out, i've pushed the steering shaft as far towards the front of the truck as possible but still can't get the damn joint apart. Halves are loose, I've soaked everything in penetrant. I even went thru the inside of the cab to see if anything is holding me back. The shaft spline just will not completely come out of the upper joint! Any ideas?
