10-22-06, 06:11 PM
| | 250+ Club
| HELP I was driving my car down the road and, all the sudden a high pitched squeal occured so I pulled over and steam is shooting out of the front of the car and water was coming from the water pump area. There was also a low grumble that we beleive was caused by the loose fan rubbing on the belts. Anyone had this problem before? Please help me, my 60 is on the side of the road, and if I can fix it why take it to the mechanic?
__________________ 1984 FJ60, 176 Thousand Miles, Rebuilt 2F, OME, Desmog, Weber 38, SOR Header, BFG A/T's on Eagle 058's |
10-22-06, 06:13 PM
| | Site Addict
| Have you looked at the thermostat housing itself? They ususally develop a hole after a while and it will shoot coolant all over the place. If so get a new one from Toyota.
Zack |
10-22-06, 06:20 PM
| | Site Addict
| The high pitch squeal sounds like something seized up. Can you turn the water pump by hand with the belt off? Smog pumps are more likely to seize up, but that should be on a separate belt. It is possible that the water pump seized, so check that first.
__________________ 1989 FJ62 Raffle Truck
2002 4Runner SE
TLCA #14424 |
10-22-06, 06:22 PM
| | Forum Lifer
| yep i vote water pump also |
10-22-06, 06:32 PM
| | 250+ Club
| You ask why take it to a mechanic? because that's what keeps our economy strong! Give and let Live! |
10-22-06, 06:36 PM
| | springfield user
| x3 on the water pump, siezed or otherwise toasted.
__________________ it's only metal, we can out think it.
77-fj40 20th anniversary edition
87-fj60 216K mile DDer
93-fzj80 mall crawler toyota material distribution center. your source for Factory Service Manuals. they're alot cheaper than you think. 1-800-622-2033 |
10-22-06, 06:47 PM
| | 250+ Club
| Zack it wasnt coolant it was water, thanks guys for the input, but what about the wobbling fan?
10-22-06, 06:54 PM
| | 250+ Club
| Quote:
Originally Posted by klinetime574 Zack it wasnt coolant it was water, thanks guys for the input, but what about the wobbling fan? | So by that statement!! you don't run antifreeze mix? as in "coolant" or did you just hit a water puddle and splash some water on your belts? |
10-22-06, 07:12 PM
| | 250+ Club
| By bad, it was leaking coolant, and we put water back in to see if we could get it back home.
