Reading 3FE engine codes at home
I couldn't find this on Mud. Thanks to Aaron (Mr 2FE), he put this together some time back. I have had several questions about reading the check engine light on a 3FE lately, so here it is. I'll be adding it to the FAQ.
Get a Haynes, Chilton’s, or a Factory Service Manual (FSM) For the FSM call Toyota Publications @ (800) 622-2033 How do you retrieve the codes? It’s easier than you think. Follow the following steps to find out how your engine is running.
The codes are in your manual. __________________ Greg Thompson CottonLand Cruisers 00 Camry: Stock 5SFE - 27 MPG 89 FJ62: OME 2.5, 2" BL, Superior shackles, F250 towers, 315 BFG KM2's on zj80 wheels, Extreme A440, FF,4:88,RDB,longs,ARB front,Lockright rear,Warn XD9K in Rover AL bumper, Wildernes Roofrack, Marlin Sliders, SROR 1/4 sliders. Last edited by euclid; 10-18-06 at 08:58 AM. |
I should probly put the pictures up there huh? I'll get those tonight for everyone. Sorry.
__________________ A Ron Using one cruiser to go mountain biking, and the other to collect dust. 2F-E Article McNamara gear writeup |
Pictures of were the jump wire goes would be the best so I know exaclty were to put it. I need to do this and figure out why my light is on and get it fixed
I'll take a picture of the wire in the connections. It's really easy to do. Make a short wire with some spade connectors.
a bent paper clip will also work.
Are the codes the end word in diagnosis? I mean, are they always right?
I found the pictures and the whole works
and descriptions on birfield.com it is really easy to do. It is all spelled out for you there __________________ 10/85 FJ-60 new legs coming "The beatings will continue until the morale improves" |
#9 | |
SOmetimes the code will tell you of a problem you didn't even know existed. In some cases the code will tell you exactly which part needs to be replaced, or which circuit has failed. But don't assume it will be that simple. Mark... |
#10 |
Were at on birfield was looking on there I couldnt find it. I must not be as good of a searcher as you. I am a member to so that shouldnt be a reason. I am still looking though.
#11 |
Never mind on that one I think I figured it out. How can you tell if there is more then one code tripped. Will it just go right on to the next number after it is done with the first one? There could be multiple ones wrong with mine, I sure hope not though.
#14 |
No, that would complicate the already very simple.
This is the easiest thing to do, ever. If you can fill your gas tank you can read the codes. __________________ Greg Thompson CottonLand Cruisers 00 Camry: Stock 5SFE - 27 MPG 89 FJ62: OME 2.5, 2" BL, Superior shackles, F250 towers, 315 BFG KM2's on zj80 wheels, Extreme A440, FF,4:88,RDB,longs,ARB front,Lockright rear,Warn XD9K in Rover AL bumper, Wildernes Roofrack, Marlin Sliders, SROR 1/4 sliders. |
#15 |
If you swapped a 3FE (or 2FE) into something else, the plug might not be anywhere near the check engine light. By wiring a simple toggle into the circuit, you could just flick a switch and read the codes.
Even on a '62, it'd be easy to do. Splice into the wires before the plug. __________________ '76 FJ40, "GIR". A bigger money pit than my tuition! |
#16 |
The plug is nowhere near the check engine light anyway.
![]() It is under the hood one the passenger side of the firewall. A switch would not be a bad idea. But at the same time it is not something you need to do often, and as mentioned it is pretty simple, so... Mark... |
#17 |
Pictures are Up
__________________ A Ron Using one cruiser to go mountain biking, and the other to collect dust. 2F-E Article McNamara gear writeup Last edited by tonkota; 10-19-06 at 02:51 PM. Reason: Added picture |
#18 |
The thing lit up like a christmas tree. There are three codes that were tripped 25, 26, and 28. Anybody have any good suggestions on how to fix these. I am not thinking it is as easy as replacing the oxygen sensor but I hope it is.
#19 |
I am getting this thing figured out. There was a ground that was tucked away under the intake so I bolted up and it got rid of those. Now it is just code 28. Would that be the cat or the oxygen sensor.
#20 |
Correction the hole is after the cats and right before the connection that goes to the muffler. I am thinking I need to fix the hole for everything to be cleared.
#21 |
TonKota were do wheel around spokane maybe we can hook up for a trail run or something. I am down here in moscow for school.
#22 |
When I get the Pig running I can go wheel then, but I need the 62 to stay clean since I rely on it. Vandal huh? I go to school at EWU. If you are up this way let me know and we can get together.
#23 | |
Nope. nothing after the O2 sensor matters. Well, assuming that the cat is not clogged anyway. But holes after the cat never matter. Mark... |
#24 |
you said but holes! he he he!
oh, and I don't know if you saw this: http://www.steelnthings.com/3fetrouble.htm __________________ A Ron Using one cruiser to go mountain biking, and the other to collect dust. 2F-E Article McNamara gear writeup |
#25 |
We dont have to go that hard wheeling since mine is my DD also and the only way I can get home. I did mine in park and it seemed to work but I will try it in neutral and see if it is different. And I am thinking that I need some new O2 sensors (that is going to hurt the old wallet).
