Old 10-02-06, 08:51 AM   #1
Cruzerman's Avatar
Rear Axle Bearing
Can anyone recommend either a trick or a source for an inextensive bearing puller for the rear axle of my 60?
TIA
Cruzerman
'85 FJ60
'78 FJ40
Cruzerman is offline   Reply With Quote
Old 10-02-06, 09:06 AM   #2
80s muncher
2badfjs's Avatar
TIA
see if your local parts house ie. napa, auto zone,carquest will rent you one.
some rental places will have them also.
make sure you take your new bearing with you so you know it fits
SOLID ROCK OFF-ROAD
http://www.solidrockoff-road.com/
1991-92 80 series sliders available, WITH CAT PROTECTION!
It's how YOU want it, i'm just here to build it for you.
SLIDERS FOR 40s' 60s' and 80s' plus a little bit more
2badfjs is offline   Reply With Quote
Old 10-02-06, 09:13 AM   #3
Ride On...
lowtideride's Avatar
TLCA# 14891
Trick: Do your best at pulling it out with exsisting tools. After you have failed but have removed all the rollers lay a bead around the inside of the bearing. When the weld cools it shrinks and shrinks the outside of the bearing with it.
www.NFCruiserheads.org 1983 SR5 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 10-02-06, 10:09 AM   #4
Godwin's Avatar
I've used a slide hammer to yank rear bearings and it worked, and was work. Another approach is to pull the axles on both sides and the differential, you'll then have a clear shot at the insided of the bearing. Get a long pole, ca. 1 1/2" in diameter (+/-) and use that to drive the bearing from the inside. When I did it this way I stuck an appropriately sized bearing/race driver on the end. This technique worked well, but you do have to pull the diff.
Jim Godwin
1977 FJ40 with some stuff
1985 FJ60 with 3FE
1986 FJ60 now with stuff
1997 FZJ80 stockish
Tallassee, AL
Godwin is offline   Reply With Quote
Old 10-02-06, 01:22 PM   #5
NocalFJ60's Avatar
A lead pipe through the opposite side worked great for me. Hit one side of the bearing and then switch to the other side until it pops out.
I had both side removed and the 3rd member out.
1982 FJ60
Northern California
TLCA/PMC Member
"He who throws mud only loses ground."
NocalFJ60 is offline   Reply With Quote
Old 10-02-06, 01:54 PM   #6
BlueCruiser84's Avatar
I rented a slide hammer witha bearing puller from Autozone.
Faded blue '84 fj60 - 2 1/2 inch BDS lift and 33s, ARB front bumper, homemade rear bumper and sliders, snorkel, removable doors, lock-right out back...
BlueCruiser84 is offline   Reply With Quote
Old 10-03-06, 05:38 AM   #7
Cruzerman's Avatar
Some good tricks, but I'm not planning on pulling the diff. While I'm sure the welding trick will work, I don't think that's the method for me.
Looks like a puller is in order. Anyone know where to buy an inexpensive one or are these things used so infrequently that renting one is the way to go? I would prefer to buy one (if not too expensive) since I'm going to be doing my FJ40 sometime soon as well.
Cruzerman
'85 FJ60
'78 FJ40
Old 10-04-06, 09:54 AM   #8
RENT, best way to go.
Slide Hammer....
Some part stores loan tools, ask there first.
Nov 85 FJ60
soggy60 is offline   Reply With Quote
Old 10-05-06, 03:11 PM   #9
debushau's Avatar
slide hammer
I went through the slide hammer route last week and I can confirm that it was a lot of work. In fact, so much so that I would seriously consider the factory tool as an alternative. The factory tool looks like a gear puller.
The standard puller ends are just not the right size and the bearing cage will break fairly easily.
debushau is offline   Reply With Quote
Old 06-25-08, 10:49 PM   #10
Did any of you guys rent the slide hammer from AutoZone? Does it come with attachments or what did you guys use?
AutoZone.com | In Our Stores | Loan-A-Tool Program
1991 Land Cruiser - ARB front bumper, Custom sliders, IPF 968, HIRs, 33's BFG A/T KO, OME 850/863, CB, Aussie Locker, more to come...
2006 IS350 - XD 6500k HIDs (lows/fogs), GFX front lip, iForged Classics (19x8/19x10), Tein CS.
2007 Suzuki SV650S - Motosliders
teejnut is offline   Reply With Quote
Old 06-25-08, 10:56 PM   #11
I bought a slide hammer from NAPA. Similar to the one in the link you posted. Seriously hard work to remove. Took maybe 50 or 60 hits to pop the old bearing out. Cheaper than paying somebody else to do it however...
Doug G
Seattle, WA
TLCA#12671
lovetoski is offline   Reply With Quote
Old 06-25-08, 11:08 PM   #12
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
I've done one with a big slide hammer. That is serious work.
It is way easier to pull the differential and bang out the bearing with a pipe from the other side. i just did one like this the other day, and at most it took 5 minutes. I keep a piece of schedule 40 just for this job.
Remember, once you pull the axle shafts (which you have to do anyway) it isn't much more work to drop out the differential.
Andrew
1997 FZJ-80 Driveway queen
Cruiserdrew is online now   Reply With Quote
Old 06-25-08, 11:14 PM   #13
Sounds like fun... But I agree I would rather do this myself, it's not complicated just time consuming.
Old 06-26-08, 05:38 AM   #14
Cruzerman's Avatar
I actually did end up doing this using the free tool "rental" from Autozone. It was a big slide hammer with a hook. It was some work, but worked well. And the price was right (free!). That's what I would use if (when) I have to do it again.
Cruzerman
'85 FJ60
'78 FJ40
Old 06-27-08, 12:19 AM   #15
Well I ended up getting and using the big slide hammer w/ hooks from AutoZone. Worked pretty well IMO. I think I struck each side about 20x max, didn't seem to be too much work. I think I spent a few minutes on each side before the race/bearing came out. I found it a lot easier then using brass drifts when I did my front axle rebuild.
Old 06-27-08, 10:31 AM   #16
cruiser88's Avatar
TLCA# 17319
If you are doing just one side rent the kit from Autozone....or shall i say deposit. If you are doing both sides use the pipe method.
I went out 2 years ago and bought the kit to work on my cruiser at fj40 Jim and have not used it sense or can I think of a reason to use it on my cruiser again.....i think i payed 140 some bucks
Personal Finance | Advertising | WoW Gold | Car Credit | Final Fantasy MP3
