Old 08-13-06, 11:57 AM   #1 (permalink)
Carb Idle screw adjustment
I am putting a used OEM carb on my 60. Just noticed the Idle adjustment screw is turned out about 8 turns. The motor idles fine but I just wondered if this many turns out was a good starting point toward fine tuning the carb? What is the normal range for turns out on these carbs? Thanks.
Ron
1978 FJ40 - Restoration project with 58K miles
1994 FZJ80 129K miles Locked with 295 Terra Grapplers, OME heavies, ARB front bumper, Warn 9000
1994 FZJ80 with 43k miles. Tons of Parts for Sale Thread and pics here: http://forum.ih8mud.com/parting-out/...pick-part.html
1984 FJ60 - Fairly Rustfree Texas Truck, Rebuilt Engine with 5K (For Sale)
1984 Harley FLTC
toyman317 is online now   Reply With Quote
Old 08-13-06, 12:35 PM   #2 (permalink)
NocalFJ60's Avatar
That sounds high. The book has you start at 2 turns out but 3 worked better for me. I stick a small screwdriver on the idle mixture screw and then stick the filter back on so everything is normal. You want to bring up the idle as high as possible with idle mixture screw and then turn down the idle speed to about 650 with the ilde speed screw. Keep repeating both until the speed does not increase adjusting the idle mixture screw. I also hook up a vacuum guage and then screw it in a tad until the vacuum starts to decrease and then back off at the end a tad.
1982 FJ60 SUA OME w/AAL's, 34's, H55F, 4.7 toybox
Northern California
TLCA/PMC Member
"He who throws mud only loses ground."
NocalFJ60 is offline   Reply With Quote
