LinkBack (24) Thread Tools Display Modes
Old 08-12-06, 11:21 AM   24 links from elsewhere to this Post. Click to view. #1 (permalink)
hodag's Avatar
Here are the Toyota part #s for a starter rebuild.
I just got done rebuilding the starter on my '87 and I thought I would share the part numbers for the contacts and the plunger.
I got the parts from Cdan, and he had to cross reference the numbers for a 3FE starter in an early 80 series. The Toyota computer does not show the individual parts for the 60 series starter.
Anyway here are the numbers...
Plunger Magnet 28235-35080
Starter Contact Kit 28226-72010
Starter Contact Kit 28226-72080
The rebuild couldnt be easier, about 1 hour including pulling the starter, cleaning everything, replacing parts and reinstall.
Hope this helps. Hodag
When the Boogeyman goes to bed at night, he checks his closet for Chuck Norris.
hodag is offline   Reply With Quote
Old 08-12-06, 02:04 PM   #2 (permalink)
tlcruzr's Avatar
Are these the same p/n's that I would use for the starter out of an 88 FJ-62? What was the total cost of the "kit"? Thanks, Joel
tlcruzr is offline   Reply With Quote
Old 08-12-06, 03:39 PM   #3 (permalink)
hodag's Avatar
I think they would be the same numbers since they are numbers for a 3FE starter from an 80. I would double check with Cdan for sure.
I'll go dig up the reciept for the cost, but I think it was around $8 apeice for the 2 contact kits and like $12 for the plunger. Way cheaper than new, and too easy not to do yourself.
Hodag
Old 08-12-06, 04:11 PM   #4 (permalink)
NorCal60's Avatar
Good post, Hodag!
I could've used this post back when CDan was on vacation but now I know what I need for the old starter.
Tom
'84 FJ60
For Sale:
'02 Land Rover Discovery II
'78 Yamaha XS750E w/ XS750SE parts bike
NorCal60 is offline   Reply With Quote
Old 08-13-06, 08:09 AM   #5 (permalink)
zcruiser's Avatar
Yup, same here, order parts from cdan but he's 'out of pocket' for a few days...
I paid ~$40 for the kit, shipping included. I plan to take pics when I do mine and will post here but may be a couple of weeks... At the beach right now and lovin' it.
SOLD: 1994 Red Pearl FZJ80, 202K, George's LEDs, PHH, etc.
1999 Millenium Silver 4Runner Limited, Toyo Open Country A/Ts
1993 Red Pearl 300ZX with some bling, K&N and a chip
Previous owner of sweet 1989 FJ62 with OME+KOs
zcruiser is offline   Reply With Quote
Old 09-02-06, 09:27 PM   #6 (permalink)
zcruiser's Avatar
OK, so this afternoon I finally did it.... Let me start from the beginning. My truck would start 95% of the time, but there was always that one time where I would turn the key and all I would hear was a "click" from the right floorboard area (guess why). Sometimes I could turn the key a few times and it would catch, other times I just gave up. The times I gave up, I could go back 30 mins later and it would hit the first time. Starter rebuild time.
Parts arrived from CDan on Friday, just in time. Saturday afternoon, ate a good lunch, no beer, peed one more time before going out to tackle the beast.
Parts as listed above:
- Plunger Magnet 28235-35080
- Starter Contact Kit 28226-72010 (what I call the "left" side contact kit per photos)
- Starter Contact Kit 28226-72080 (what I call the "right" side contact kit per photos)
Tools required:
- 3/8" ratchet drive, may also possibly need breaker bar
- 8" extension shaft
- 8mm socket
- 12mm socket
- 14mm socket
- 17mm socket (6 point recommended)
- 12mm box end
- 14mm box end
- Hammer and flat cold chisel
- Lots of rags, degreaser , contact cleaner
- Nitrile gloves (yah, I'm a "nancy")
1) Gather your tools, park cruiser on a dry flat surface, slide some cardboard or something under the pass side of the engine to make it easier to slide around while getting at the starter.
2) DISCONNECT THE POSITIVE SIDE OF THE BATTERY! This will cut down on the amount of sparks.
3) Locate the starter in need of attention (view is from inside pass tire toward oil filter):
4) Disconnect the battery connection (12mm) on the bottom side of the starter and the signal connection (pull off), then attack the 17mm bolt on the bottom side of the starter. I needed a breaker bar here, but as I said I'm a nancy.
5) Go to the top side to access the upper 17mm nut on the top of the starter. It is hidden behind the 'motor' part of the starter.
I removed the upper part of the starter (two rods w. 10mm hex head) to gain better access, but if you probe with the 17mm socket at the end of the extension, you can get to it w/o removing the top part of the starter. Here's a view with the starter motor removed, to give you an idea where the top nut is.
Removing the top part actually increases the work because if the inner motor comes out of the housing (as it did on me), you have to do some extra work to reassemble it, but it's not impossible. Here is the slightly disassembled starter after complete removal:
I can't help cleaning up parts that I have removed for repair...
I went ahead and put the starter motor back together before actually getting to the rebuild (though the astute will see the old parts lying about so this is actually an "after picture):
6) Locate the end cap of the starter where the plunger and starter contacts are located.
Use 8mm socket here on 3 bolts (instead of Phillips screwdriver):
7) Disconnect the starter motor lead and remove the cap to gain access to the plunger and contacts.
Take care when removing the cap as it has a rubber seal which must not be damaged.
8) Remove the plunger (simply pulls out), but keep track of the spring at the end of the plunger, you'll re-use it.
Note the worn contacts on the left and right side of the housing. My plunger didn't look that bad, but may as well replace it while I'm in there.
9) Ready to start installing the new parts, here's what came from CDan:
10) New parts alongside old parts:
Plunger...
"Left" side contacts (when I took this pic I left out the 'cup' that goes between the 'O'-ring and the flat washer but it was included in the kit)...
"Right" side contacts (showing the cup)...
"Right" side contacts bolt had to be "pressed" onto right side contact (I used a hammer and chisel to tap it on)...
11) When disassembling left side contacts, note that there is a square washer soldered to a wire.
Carefully remove old parts while leaving this square washer undisturbed:
12) Install new contacts into left and right side of housing, taking care to use all new parts in the same order as old parts. Use 14mm box end wrench to tighten the nut inside the cup on outside of the starter.
13) Slide plunger spring on end of new plunger and reinstall in starter housing. Push plunger in against the spring and verify that it pushes the starter gear out the other end, and retracts when you release the plunger. Do this a few times, it's really fun.
14) Reinstall the cap and re-attach starter motor lead to "left" side of the starter (12mm). Be sure to reinstall the rubber cap over the starter motor connection. Mine was a little brittle and cracked, so I used some caulk to repair it and hold it in place. A replacement cap would be nice, but no part number is shown for this.
15) Reinstall starter on the flywheel housing. If the stud came off on the top side of the starter when you removed the 17mm nut, put the stud back in first, which will allow you to hang the starter on the stud while you re-install the 17mm nut. When you put the bottom 17mm bolt back in, be sure to include the ground cable under the bolt.
16) Re-attach battery connection to starter first (cover with rubber cap), then plug in signal connection.
17) Re-attach battery connection at battery.
18) Start 'er up!
When I first tried to start the truck, I got the same @$#&% clicking noise for about 6 tries. I sat there dumbfounded, reviewing in my mind all the steps I had taken to put everything back together exactly as they had come apart.
I began to steel myself for taking it all back apart again, and decided to give it one more turn. Music ensued as the starter kicked in and the engine fired up! I let it run a little bit to make sure the plunger had retracted properly, then turned it off and tried again 2 or 3 more times to convince myself it was really working.
So... 202K miles, rebuilt starter, took about 3.5 hours but I spent probably 45 minutes cleaning all the gunk off the thing and reassembly the starter motor (the latter an unnecessary step).
HTH...
Old 09-02-06, 09:53 PM   #7 (permalink)
zcruiser's Avatar
One question remains...
There is one part in the "right" side kit that I did not use as it was not in the starter when I disassembled so didn't know what to do with it. It appears to be a paper-like insulating material that has a hole the same size as the contact bolt.
Anyone know where this should have been used?
Old 09-02-06, 10:08 PM   #8 (permalink)
Zack1978's Avatar
The write up is great, however is it worth doing the job? I purchased a starter with a lifetime warr from my local foreign parts place for $129.00. I have put in a link for the company that my starter came from. I am happy and I know that I will never have to worry about a starter because of the warr.
Just my 2 cents,
Zack
http://www.pprok.com/
Zack1978 is offline   Reply With Quote
Old 09-02-06, 11:56 PM   #9 (permalink)
Just my 2 cents,
Zack
I think it depends on how comfortable you are doing the repair. The parts are cheap, and the install is easy. Key point for me is that you get to keep using a Toyota starter. Other than a tendancy to wear the contacts, they are bombproof.
Don't know anything about pprok, but most of the "lifetime" starters/alts/etc are junk. They need a lifetime warrrenty because they fail often. They are cheap, and that is a plus. But you have to be prepared to "spend" some time replacing them. The price you paid to pprok is higher than most of the auto parts chains, so maybe you've got a starter that's better than the junk I'm referring too...
Doug G
Seattle, WA
TLCA#12671
lovetoski is offline   Reply With Quote
Old 09-03-06, 12:21 AM   #10 (permalink)
tlcruzr's Avatar
Awesome write-up! Thanks for taking the time to document your experience & taking all the pictures. I'll probably follow your lead here in the next month or so.... Joel.
Old 09-03-06, 05:09 AM   #11 (permalink)
zcruiser's Avatar
Zack -
$45 in parts
2-3 hrs of not-so-hard work (gotta take it off and put it back on anyway)
Knowing your cruiser that much better.
...Priceless
Old 09-03-06, 08:18 AM   #12 (permalink)
Elbert's Avatar
nice writeup z-cruiser
Elbert is offline   Reply With Quote
Old 09-03-06, 08:24 AM   #13 (permalink)
Cruzerman's Avatar
I think rebuilding it is definately worth the effort over spending $130 for a rebuilt unit. When my starter had problems, I only replaced the contacts (didn't do the plunger). Entire job was a sub-$20 bill. It's a very easy job (one banana).
Additionally, on the two starters I have replaced the contacts on, it seemed that the contact on one side was way more worn than the one on the other side. I think you can see that in the picture above too. I replaced both and kept the not-so-worn contact as a spare. When the second starter was doing the clicking thing, pulled out my "spare" contact and it fixed that one.
I've had no issues with either starter since. And it's been about 8 years on one, and 6 years on the other.
Cruzerman
'85 FJ60
'78 FJ40
Cruzerman is offline   Reply With Quote
Old 09-03-06, 12:59 PM   #14 (permalink)
very nice write up
this should go into the electrical tech section
Sex is a body-contact sport. It's safe to watch but more fun to play.
bundy18 is offline   Reply With Quote
Old 06-26-07, 01:39 PM   #15 (permalink)
Yes.
It goes directly against the inside of the housing behind the contact assembly. Beveled side towards the inside of the housing.
1985 FJ60; 182k, OME suspension, 6" shackles (MAN-A-FRE), Long Range 38 gallon fuel tank, ARB front, Ramsey 9500 winch, Kaymar rear bumper, Premier Power Welder, etc.
techninja is offline   Reply With Quote
Old 06-28-07, 10:19 AM   #16 (permalink)
zcruiser's Avatar
Ooops. It wasn't there when I took the old one apart so didn't know where to put it.
Old 06-28-07, 04:05 PM   #17 (permalink)
NocalFJ60's Avatar
Thanks for the writeup and pictures.
1982 FJ60 SUA OME w/AAL's, 34's, H55F, 4.7 toybox
Northern California
TLCA/PMC Member
"He who throws mud only loses ground."
NocalFJ60 is offline   Reply With Quote
Old 06-28-07, 06:22 PM   #18 (permalink)
I went the remanufactured lifetime warr crappy starter route on my 74 and have replaced it 3 times in the last 6 yrs. It's free, and only takes about 30 mins to do, but its still a hassle.
I went with a genuine toyota starter on the 60 and am glad I did.
Trevor
84 fj60
hillcountrycruiser is offline   Reply With Quote
Old 09-22-07, 02:56 PM   #19 (permalink)
forestdan7's Avatar
excellent post on starter rebuild; bumping it back up
I just finished rebuilding the starter on my 85, using this excellent thread from zcruiser and hodag.
The part numbers were right, and the pictures were extremely helpful.
The only thing I would add is wear some safety glasses to keep from getting all that oil and road crud in your eyes when you're under the starter.
My right side contact was completely fried, and I've been roll starting for a week now. Pain in the arse.
After the rebuild, following these instructions, it fired the first time. No more searching for that perfect parking spot on top of the hill.
Thanks to zcruiser and hodag, and to this forum for saving me money and letting me get to know this beast even better.
1985 FJ60
1987 4Runner -- SOLD
2002 4Runner Limited
2007 Honda XR650L
forestdan7 is offline   Reply With Quote
Old 10-20-07, 06:07 PM   #20 (permalink)
pnwfj's Avatar
Thank your for the very helpful "how to" post zcruiser. Just completed the job - took about and hour and the starter is working much better. Thank you! Total cost $40.
PNWFJ (Pacific Northwest FJ)
1984 FJ60 |SOLD| OME Suspension, Kamar rack, 33" BFG ATs, 2F, 230K
2003 UZJ100 | Stock at the moment
FZJ80 | My parents had one
FJ55 | My 1st car
TLCA Member (Promote the club!)
pnwfj is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/105626-here-toyota-part-s-starter-rebuild.html
Posted By For Type Date
pradopoint.com - Toyota Prado 4x4 Landcruiser Forum • View topic - Starter Motor Click This thread Refback 01-30-10 10:42 PM
Toyota Land Cruiser E Locker - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 01-12-10 01:11 PM
$18 Starter Fix '97es300 - Lexus Owners Club (USA & Canada) This thread Refback 12-22-09 10:43 AM
dennism2's CamrySolenoidRepair Bookmarks on Delicious This thread Refback 12-15-09 01:11 PM
pradopoint.com - Toyota Prado 4x4 Landcruiser Forum • View topic - Starter Motor Click This thread Refback 10-23-09 05:20 PM
$18 Starter Fix '97es300 - Lexus Owners Club (USA & Canada) This thread Refback 10-06-09 06:03 PM
Lexus Owners Club (USA & Canada) > $18 Starter Fix '97es300 This thread Refback 09-14-09 01:48 PM
$18 Starter Fix '97es300 - Lexus Owners Club (USA & Canada) This thread Refback 09-13-09 01:44 PM
DIY - šԿ³×´ò²»×Å»ðµÄÎÊÌâ³õ²½½â¾öÁË - δÃû¿Õ¼ä(mitbbs.com) This thread Refback 09-08-09 06:40 PM
pradopoint.com - Toyota Prado 4x4 Landcruiser Forum • View topic - Starter Motor Click This thread Refback 09-06-09 05:43 PM
2jzgte starter repair - Toymods Car Club This thread Refback 09-01-09 02:32 AM
Toyota Starter Rebuild Kit on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 06-28-09 02:03 PM
pradopoint.com - Toyota Prado 4x4 Landcruiser Forum • View topic - Starter Motor Click This thread Refback 06-19-09 05:48 PM
pradopoint.com - Toyota Prado 4x4 Landcruiser Forum • View topic - Starter Motor Click This thread Refback 06-13-09 04:49 AM
pradopoint.com - Toyota Prado 4x4 Landcruiser Forum • View topic - Starter Motor Click This thread Refback 06-02-09 05:22 AM
pradopoint.com - Toyota Prado 4x4 Landcruiser Forum • View topic - Starter Motor Click This thread Refback 05-30-09 09:02 AM
Toyota Starter Rebuild Kit on Kosmix This thread Refback 05-22-09 01:03 AM
Car Starter, Car Spectrum, Car Steel Wheels Pgh Pa - Assyriandemon This thread Refback 03-08-09 10:09 AM
Starter Contacts replacement... - AutosTalk Forums This thread Refback 03-04-09 05:39 PM
Starter Contacts replacement... This thread Refback 12-05-08 07:04 AM
alt.autos.toyota.camry | Google Groups This thread Refback 11-03-08 12:12 PM
Starter Contacts replacement... - alt.autos.toyota.camry | Google Groups This thread Refback 10-27-08 10:12 AM
Toyota Starter Rebuild Kit: Basic Facts, News, Articles, Reviews, Images, Videos and more This thread Refback 10-10-08 08:48 AM
Starting Issues - Toyota Land Cruiser FJ62 This thread Refback 12-17-07 01:12 PM
