06-19-06, 12:08 AM
#31 (permalink)
Rookie
What a great set-up you have! Fill us in on the auxilliary gas tank fuel door mod...that is a great feature! I am just tackling my 78 restoration and am always looking for new improvements along the way....the Jeep fill neck assembly has got to go before it "soils" my 40. Your skid is outstanding....I will be designing the same type set-up to guard my NV4500/non-split 4spd transfer assy. including protecting the parking brake assy.; I've already "tacoed" the disc parking brake and have gone back to the stock drum....it works better anyway. Kudos on a well thought out rig.
06-19-06, 12:42 AM
#32 (permalink)
Focus on the Journey
I'll post photos of the door (open and from the backside), filler neck, aux tank, fuel switching valve, dual filters and control switch tomorrow.
78 FJ40
ARB's F&R, Rear Disks, DUI HEI, 200 Amp Alt, OME 2.5, 33x10.50, PS, RE8000, Stout Rear Bumper, 4+Plus Sliders/U-Bolt Flip Kit/Tie & Relay Rods/Anti-Inversion Shackles, Dual Tanks, BTB Dash Box, Tuned Ceramic Coated Headers, Extended Axle Vents, BrakeQuip Custom Certified SS Brake & Clutch Flex Lines
ROTW My Yoda| HD Skid Plate| Recovery & Windshield Washer Tanks| Toyota Pulley on GM Pump| Bypass Hose| Vapor Recovery Tank
06-19-06, 11:25 PM
#33 (permalink)
Rear Tank
Here are a group of photos of the rear tank, fuel filler, filters, fuel switching valve, tank selector and exhaust modifications. This is going to take 3 or 4 post to get all the images.
78 FJ40
06-19-06, 11:31 PM
#34 (permalink)
Photos of the fuel switching valve and the fuel tank selector switch. Pollak Fuel Tank Selector Valves
78 FJ40
06-19-06, 11:51 PM
#35 (permalink)
Here are some photos of the two filters, CM Filters, and the first of the rear tank. The first filter photo is for the rear tank and the second filter photo is for the factory tank, which is mounted to the same plate the fuel switching valve is mounted on. These are large racing filters that have replacable elements that come in 1 or 8 micron filtratration. Very large capacity and flow. If you look close at the third photo you will see a chrome spacer between the skid plate and the frame. This was done so the bolts could be properly tightened. Another modification I made was to the frame. I installed the A-T Series Insert, 3/8-16, from AVK which can be used with grade 8/metric class 12.9 screws due to the A-T Series high shear load capability. I think you can see how much easier it is to install and service the tank. I normally install these at my shop with a impact wrench and a field service kit for that size thread. I drive them until the impact wrench pulls the swage flush with the frame and then run a tap to clean up the threads, AVK Fasteners.
78 FJ40
06-20-06, 12:03 AM
#36 (permalink)
Additional photos of the rear tank. FJ40 Rear Tank
78 FJ40
06-20-06, 12:10 AM
#37 (permalink)
Photos of other items from a closer perspective. The coolant flush adapter, alternator (Mean Green) and alternator spacer.
78 FJ40
06-20-06, 12:11 AM
#38 (permalink)
The ARB Pump and the Aux fuse panel, Centech Fuse Panels, which also shows the K&N breather for the two axles.
78 FJ40
06-20-06, 12:45 AM
#39 (permalink)
Photos of the rear bumper. You can also see the third brake light installed on the second photo.
78 FJ40
06-21-06, 11:18 AM
#40 (permalink)
slick
very slick
06-22-06, 11:17 AM
#41 (permalink)
Rear Drive Shaft
Here are some photos of the conversion of the factory drive shaft to a CV.
78 FJ40
06-22-06, 12:15 PM
#42 (permalink)
Hinges
Up close
78 FJ40
06-22-06, 09:30 PM
#43 (permalink)
Main Fuse Panel, Outside Temp & Compass
Centech PDP-1B, Centech Fuse Panels
Dash Mount Compass Kit with custom billet aluminum mount. The thermocouple is mounted inside the front bumper and the Remote sensor for accurate compass readings is mounted on the passenger wheel well forward of the jump seat. Dash Mount Compass Kit
78 FJ40
06-24-06, 01:20 AM
#44 (permalink)
Hi bsevans,
Thats one sweet ride you've got there. Lotsa good practical mods that still retain that great cruiser look. If you drove past it says, "now there's a man who loves his truck!"
Nice rig!
Question about the black, padded(?) piece that runs along the bottom of the dash (just above where ya knees go!). Shows up best in post #6. Is that a factory fitting? I've never noticed one before. I've had an 82 and I now have an 84 but they don't have it. The close up of your temp read out display in #43 shows it as well and it looks like it is of the same construction as my dash cover. If it didn't come with the truck I would love some info on it.
Thanks, and keep up the good work!
'84 FJ40, '84 FJ45 TROOPY
Twice as fast - half the bumps!
06-24-06, 01:32 AM
#45 (permalink)
Those are all factory standard from 9/72-10/82. 10/82 to 84 they changed but still came from the factory with them. SOR Catalog
78 FJ40
06-29-06, 02:57 PM
#46 (permalink)
Rear Seal Installation Tool
This is made-up of an ABS external slip to internal threads (5803-2) with an ABS plug. The white part is a PVC adapter that is external slip to internal slip (4INDWVX4SD 30 Adapter). What the PVC does is give you an external OD of approximately 4.75 inches versus the Clean out OD of 4.5 inches.
78 FJ40
07-06-06, 09:05 AM
#47 (permalink)
PS Low Pressure Fitting
The part number for the 90 degree fitting that is flair by hose is 44416-34010. You need to look in your low pressure return and make sure there is a flair at the bottom of the port for this nipple to seal against.
78 FJ40
07-06-06, 09:43 AM
#48 (permalink)
Water Proof Rear Bumper Connector
This bulkhead connector uses an o-ring to seal the opening through the bumper and the mating connector also has a waterproof seal. The factory four pin harness connector was replaced with a four pin weatherpak waterproof connector. I also ran a ground wire out the connector to ground directly to the frame. On the inside of the bumper I have used 1/4" Fully insulated Heat-Shrink Quick-Disconnect Terminals so I can remove the bulkhead connector to service the bumper. As a side note: When I went from grounding the tail light assembly through the bumper to a ground wire directly to the frame my tail lights got brigther. About the only thing I can attribute this to is the powder coating on the bumper. It was even worse on the license plate assembly. The two license plate lights would not work until I ran a ground wire for each inside the door and grounded them.
78 FJ40
07-06-06, 08:36 PM
#49 (permalink)
Tranny to Transfer Case By-Pass Hose
The hose is a steel braided -08 Parker "Tough Cover". The centerline distance between the fittings is 15" to 15.25". I made two, and they both fit. The short one is currently in place. The fittings are 37 Deg Flared Compression Tube Fitting, Tube X Male Metric For 1/2" Tube, M18 X 1.5 straight Pipe. McMaster-Carr p/n4545K223 at a cost of $11.44 each (pg 144). The hose with two 90 degree crimp fittings installed plus two steel caps so I can remove the hose without having to remove the adapters was $35. About what you would pay at either MAF ($55) or SOR ($65). This hose is meant to carry hydraulic fluid that is above 200 degrees. The fittings from McMaster-Carr have an outer steel washer with an inner rubber o-ring that seals against the tranny and transfer fill ports.
78 FJ40
09-19-06, 12:06 PM
#50 (permalink)
GM Power Steering Pump Pulley
Toyota four bolt smog pump pulley from SOR with custom press on hub.
78 FJ40
09-19-06, 06:57 PM
#51 (permalink)
Man that is one awesome ride, where did you get, or what did you put on those hinges, those things look super clean.
Stephen
'94 FZJ80 Locked & Stock
'79 FJ40 (Sold)
'93 FZJ80 (Sold)
'01 Tacoma
Olde North State Cruisers
Originally Posted by amos715
landcruisers don't just happen because a tornado goes through a junk yard (that would be a jeep) they are built and assemble in the way their designer planned.
09-19-06, 11:57 PM
#52 (permalink)
Nice.
You've posted pics of your winch setup before. Any detailed pics of the mounting brackets?
"SOYLENT GREEN IS PEOPLE!!!"
ΔΤΧ
09-20-06, 03:08 AM
#53 (permalink)
Sandblasted and powder coated with Cardinal Black Hammer.
78 FJ40
09-20-06, 03:13 AM
#54 (permalink)
Originally Posted by Brian in Oregon
Nice.
I did not take photos of the individual pieces when I had them sanblasted and powder coated. You might try contacting Ramsey as it is a mount they use to offer. I purchased the mount with the winch over 20 years ago.
78 FJ40
10-25-06, 11:27 PM
#55 (permalink)
Nice.
Brian, if you are still interested in photos of the individual components of the winch mount, let me know. I am in the process of removing the winch so I can tear it down for a long overdue service after 18 years of intermittent use.
78 FJ40
10-28-06, 07:53 PM
#56 (permalink)
Bans what part of Arizona are you in? Chandler, AZ here.
Todd
10-28-06, 09:56 PM
#57 (permalink)
Todd
Tucson
78 FJ40
02-27-07, 10:27 PM
#58 (permalink)
Your land cruiser is one of the nicest that I have seen. I've seen it once or twice driving around tucson. I can remember the Virgina stickers on the windows. I was wondering what the name of the body shop that you used after your accident. I wanted to get my 40 painted and have some body work done. if you could tell me that would be great.
Thanks Brendan.
10-03-07, 12:15 AM
#59 (permalink)
Nice rig, I think i have a new crush ....
I used to take my grandmother to Manuels everytime i passed by Green Valley, good memories.
Saludos
10-03-07, 04:51 PM
#60 (permalink)
Where did you buy your 3/8 Aluminum instrument cluster? Or did you make it?
77 FJ40 -- SBC 400 : 4spd : Saginaw : 33x12.5 : Shackle Reversal : Lock-Right
