Old 06-04-06, 10:52 PM   #1
Nomis's Avatar
Gear Reduction Starter!
Removed my original starter as it would grind on occasion. Installed a Factory Toyota GR unit and wow - what a difference. I'm amazed that a smaller, lighter unit can be that much more powerful. It turns over uber-fast now. I would highly recommend this upgrade to anyone.
1976 FJ40 - See Build Up Thread Here:
http://forum.ih8mud.com/40-55-series-tech/125665-1976-fj40-build-up-resto-thread.html
1996 Lexus LX450
2006 Mustang GT V8 Manual Trans
Nomis is online now   Reply With Quote
Old 06-04-06, 10:58 PM   #2
pygpen's Avatar
TLCA# 8547
Hey, I just ordered a regular one from NAPA this afternoon and forgot about these .
What is trhe application for the GR starter?
it will fit a 75 2F, right?
PMK
when the going gets weird, the weird turn pro.
Benicia, Ca.
My Cruisers
PMK
pygpen is offline   Reply With Quote
Old 06-04-06, 11:10 PM   #3
Ramblin Wreck
CruisinGA's Avatar
App is any FJ60.
Toyota has replaced all earlier starters with this one.
Definatly a good upgrade...
PMK
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'97 FZJ80
'98 UZJ100-OEM RR locker
ΣΧ
CruisinGA is offline   Reply With Quote
Old 06-05-06, 12:06 AM   #4
pygpen's Avatar
TLCA# 8547
Cool, I'll see whats in the box tomorrow....
PMK
Benicia, Ca.
My Cruisers
PMK
Old 06-05-06, 07:41 AM   #5
WES1977's Avatar
How much was this starter?
1977 FJ40 Hardtop/ S-O-R’s Safari Summer Top®. Fiberglass tub. Rear Aussie Locker. 2F with at least 106,000 miles. Running Bfgoodrich MT's 33x10.5xr15
1988 FJ62 Stock
2002 UZJ-100
. Stock
2003 Tacoma extcab 4x4, V6, TRD Factory E-locker
Mid-Atlantic Toyota Land Cruiser Association website
WES1977 is offline   Reply With Quote
Old 06-05-06, 11:16 AM   #6
Nomis's Avatar
I believe they list just under $200. I'm sure CDan can provide a much better deal.
http://forum.ih8mud.com/showthread.php?t=125665
1996 Lexus LX450
Old 06-05-06, 11:56 AM   #7
TLCA# 6453
Pat, I'm running a FJ60 starter in my '75. I bought a rebuilt from Stevens Creek Toyota (25% for TLCA member) but when opened the box I got a brand new starter instead.
/td
'75 FJ40 mostly stock....yeah right!
www.employees.org/~dirttrak
mustardfj40 is offline   Reply With Quote
Old 06-05-06, 11:57 AM   #8
Focus on the Journey
bsevans's Avatar
TLCA# 16217
I went to my local alternator/starter repair shop and they order a rebuilt one for under $90 plus a core (definitely non-working) which I pickup for cheap. I asked MAF what company they got their rebuilds from ($125) and it was the same name that was on the box mine was delivered in. This was a unit that fit 2F motors E to 8/92 and was the non-Bosch made in Japan version.
78 FJ40
ARB's F&R, Rear Disks, DUI HEI, 200 Amp Alt, OME 2.5, 33x10.50, PS, RE8000, Stout Rear Bumper, 4+Plus Sliders/U-Bolt Flip Kit/Tie & Relay Rods/Anti-Inversion Shackles, Dual Tanks, BTB Dash Box, Tuned Ceramic Coated Headers, Extended Axle Vents, BrakeQuip Custom Certified SS Brake & Clutch Flex Lines
ROTW My Yoda|HD Skid Plate|Recovery & Windshield Washer Tanks|Toyota Pulley on GM Pump|Bypass Hose
bsevans is offline   Reply With Quote
Old 06-05-06, 12:04 PM   #9
mountainman's Avatar
TLCA# 15261
I bought a used one from Cruiserparts.net for $50.00. That was over a year ago,and still works great.
mountainman is offline   Reply With Quote
Old 06-06-06, 05:04 PM   #10
pygpen's Avatar
TLCA# 8547
Ok, I got the gear reduction starter from NAPA, 89.99 + 22.22 core.
It has two hook ups, obviously one for the battery and the other for "start"
My problem is my 75 FJ40 has the battery connection, a slip on spade conection (black/white), and another conector.
This one goes to a stud on the solenoid. The wire is black/red, but goes imediatly to a plug and changes to Black/white. This black/white wire is smaller diameter than the other one.
Where do I connect this?
PMK
Benicia, Ca.
My Cruisers
PMK
Old 06-06-06, 05:11 PM   #11
bsevans's Avatar
TLCA# 16217
PMK
You don't; wrap the terminal with tape and tuck it out of sight. If you want an explanation you need to refer to the wiring diagram. It is not needed or used on the gear reduction starters.
78 FJ40
Old 06-06-06, 06:04 PM   #12
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
If I recall correctly, the other wire from the solenoid is a ballast resistor bypass lead. When the key is in the start position, this lead will send a full 12 volts to the coil instead of the seven to nine it sees in the run position going through the ballast resistor.
Old 06-06-06, 06:10 PM   #13
pygpen's Avatar
TLCA# 8547
Gotcha!
I remember this from highschool shop now!
Thanks guys!
PMK
Benicia, Ca.
My Cruisers
PMK
Old 06-06-06, 10:07 PM   #14
iCruz
projektdotnet's Avatar
will this work in a 10/74 fj40 (F motor)
"Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety." -Benjamin Franklin
projektdotnet is offline   Reply With Quote
Old 06-06-06, 10:09 PM   #15
Ramblin Wreck
CruisinGA's Avatar
yes
Bailey Quintrell
'97 FZJ80
ΣΧ
Old 06-06-06, 10:22 PM   #16
iCruz
Originally Posted by CruisinGA
yes
thanks i will bookmark this for the next time I need a new starter
Old 06-07-06, 09:40 AM   #17
Ramblin Wreck
CruisinGA's Avatar
I would find a cheap used one somewhere and put that in now...
really it makes such a difference it is not something worth waiting to do.
Bailey Quintrell
'97 FZJ80
ΣΧ
Old 10-22-06, 10:14 PM   #18
iCruz
Anyone have a napa p/n by chance for these?
Old 10-22-06, 10:24 PM   #19
Ramblin Wreck
CruisinGA's Avatar
just ask for a starter for a 82-87 land cruiser...
Bailey Quintrell
'97 FZJ80
ΣΧ
Old 10-22-06, 10:53 PM   #20
sine80's Avatar
TLCA# 17109
got mine for free.99 from greenfox last week! the gear reduction kicks ass. and I got a brand new regular starter I used only for a few months which will work for a spare for now.
mike
sine80 is offline   Reply With Quote
Old 10-23-06, 05:36 AM   #21
iCruz
Mine still works but I need to start finding SMALL projects I can do at home on mine over the winter months. Thanks for the info!
Old 10-23-06, 07:46 AM   #22
762fmj's Avatar
On the NAPA part number question.
1987 Land Cruiser I assume thats an Fj60 with a 2F?
Parts guys are not the smartest and seem to need every detail to put in their computer to get an answer. When I do this, I just want to make sure I get the correct part.
Is there any shimming involved in this swap to get the teeth to line up correctly?
I haven't done this on a 2F before soooooooooooo be patient
The only stupid ? is the one not asked
1980 FJ40 Land Crusher Republican Gub Owner
www.2dreconbn.net
762fmj is offline   Reply With Quote
Old 10-23-06, 08:34 AM   #23
Ramblin Wreck
CruisinGA's Avatar
every landcruiser from a few years before 82 through 87 ALL had the correct starter regardless of options.
No shimming.
The only thing that may be slightly different is the wiring. And the fact that there is no provision for the ballast resistor bypass. (not a factor for your '80 model)
Bailey Quintrell
'97 FZJ80
ΣΧ
Old 10-23-06, 08:50 AM   #24
762fmj's Avatar
Ok, It is a possibility that my starter might be the GR one? It seems pretty slow. How can I find out?
www.2dreconbn.net
Old 10-23-06, 09:41 AM   #25
In the garage
John Smith's Avatar
TLCA# 9074
I just did this upgrade a few months ago when my original starter died. I got Napa part number 44-6154 which is the lifetime warranty one.
79 FJ40 & 78 FJ55
http://users.starpower.net/johnsmith <- Detailed ToyBox install instructions
Please help save the Upper Tellico OHV area, Donate to the Rescue Tellico Fund http://www.sfwda.org/trails/tellico/donate.html
John Smith is offline   Reply With Quote
Old 10-23-06, 09:48 AM   #26
762fmj's Avatar
John,
Awesome. Did you notice a big difference?
www.2dreconbn.net
Old 10-23-06, 09:58 AM   #27
Landpimp's Avatar
TLCA# 5506
I actaully think its 82 thru at least 92 that works, might be thru 97, but to be safe 82-7 is good
can swap even to the early F motors, I have one on my 64 FJ45LV.....took just a few mins to change the wiring around to make it work
No shimming.
Landpimp is offline   Reply With Quote
Old 10-23-06, 10:04 AM   #28
In the garage
John Smith's Avatar
TLCA# 9074
Originally Posted by 762fmj View Post
John,
I really have not noticed much of a difference except that the new starter sounds different because it is gear reduction. Where I expect it to shine is in the rocks when I need to start it in gear from time to time.
