Old 06-03-06, 01:22 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Focus on the Journey
bsevans's Avatar
TLCA# 16217
Solid-state Replacement for Mech. Voltage regulator
Ever burned up an alternator diode or had a weak electrical system due to the voltage regulator or maybe even had your vehicle parked while you went hiking or to work only to come back and have a dead battery because the contacts on the regulator had welded together and drained your battery. We'll I've experienced them all. If you are still using the factory alternator you might want to get one of these. I got it at the alternator/starter motor rebuild shop. My alternator had a burned out diode and they wanted to check my voltage regulator. I took both that I owned and they were both bad. I ran this one for a number of years without incident and no ammeter gauge bounce until I stepped up to a 200 amp alternator with internal voltage regulator.
TRANSPO
IN569
12V-227
78 FJ40
ARB's F&R, Rear Disks, DUI HEI, 200 Amp Alt, OME 2.5, 33x10.50, PS, RE8000, Stout Rear Bumper, 4+Plus Sliders/U-Bolt Flip Kit/Tie & Relay Rods/Anti-Inversion Shackles, Dual Tanks, BTB Dash Box, Tuned Ceramic Coated Headers, Extended Axle Vents, BrakeQuip Custom Certified SS Brake & Clutch Flex Lines
ROTW My Yoda|HD Skid Plate|Recovery & Windshield Washer Tanks|Toyota Pulley on GM Pump|Bypass Hose|Vapor Recovery Tank
bsevans is offline   Reply With Quote
Old 06-03-06, 01:36 PM   #2 (permalink)
Brian in Oregon's Avatar
Conversely, I had a vehicle (a Ford) that would burn out a transister regulator within a few hours. But the old mechanical style would last for a couple of years. Never did find out why.
"SOYLENT GREEN IS PEOPLE!!!"
ΔΤΧ
Brian in Oregon is offline   Reply With Quote
Old 06-03-06, 02:01 PM   #3 (permalink)
bsevans's Avatar
TLCA# 16217
I hear you. This unit ran flawlessly for the 2-3 years I used it until installing the 200amp alternator. There is something to be said for not having that arcing mechanical contact. However, if it is the cause of problems in the field, a solid-state unit is not repairable but you can take your Swiss army knife and file the contacts, readjust the gap and probably have enough to make it home. Even though I'm a mechanical engineer, I'll take that solid-state device thank you.
78 FJ40
Old 06-03-06, 08:38 PM   #4 (permalink)
bsevans's Avatar
TLCA# 16217
Well just for grins, I searched this part number on the web and found an electrical house that list it as available. For those interested.
http://www.romaineelectric.com/
the page that list it is here.
http://www.romaineelectric.com/TRANSPO.TXT
IN569 N/D EXT REG 14.3V
I'm not sure what the 227 designator represents - maybe the connector used
78 FJ40
Old 06-03-06, 10:51 PM   #5 (permalink)
Does that solid state VR plug into the factory harness?
Over on Pirate someone posted that they found a solid state VR at NAPA that fit FJs. I think it plugged into the factory harness.
4x4Poet is offline   Reply With Quote
Old 06-04-06, 01:05 AM   #6 (permalink)
bsevans's Avatar
TLCA# 16217
That connector you see in the photo is identical to the one on the mechanical voltage regulator as far as interface to the harness is concerned. The only thing different is that some of the mechanical voltage regulators I've gone through had a clear plastic sleeve around the connector to enhance the water resistance.
78 FJ40
Old 06-04-06, 10:46 AM   #7 (permalink)
Ian Rogers's Avatar
TLCA# 14752
i like
TLCA #14752, L.A. Trail Crew
http://www.marksoffroad.net My Parts Source
"nothing pairs better with a bottle of Merlot than an honest workout digging in the sand and my shovel is always ready, lol" PKP80 thoughts on Surf and Turf
Ian Rogers is offline   Reply With Quote
Old 06-04-06, 02:25 PM   #8 (permalink)
Pin_Head's Avatar
IIRC, it was Texican who posted about a generic Dodge SS regulator at NAPA for $15 or something like that. I imagine that you would have to swap connectors.
Pin_Head is online now   Reply With Quote
Old 06-04-06, 02:52 PM   #9 (permalink)
Degnol's Avatar
TLCA# 14529
That's what I used and yes you do have to change out some connectors. It did not make any difference in my needle-bounce, so maybe it is not the same as BSevans used
Ed
My Anger-Management Class really pisses me off
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers, WhiteKnuckle sliders
Degnol is offline   Reply With Quote
Old 06-04-06, 03:56 PM   #10 (permalink)
Pin_Head's Avatar
Ed
Maybe the regulator is not the reason for your amp needle flickering. It could also be intermittent flickering of something sinking current, or intermittent contact of the alternator field brushes.
Old 06-04-06, 04:04 PM   #11 (permalink)
Degnol's Avatar
TLCA# 14529
I did have it tested at an auto electric shop, but that may be something that would not show up? Anyway, I am getting ready to swap in a newer, tested unit. Hope that makes a difference. At idle it does not flicker until I turn on anything, blinker, lights, horn, etc. Even with the "steady" pull of the headlights, the thing bounces and bangs both stops.
Ed
Old 06-04-06, 09:35 PM   #12 (permalink)
Degnol, please post the results of the swap. I have the same problem on my '72. There is slight flutter of amp needle at idle, but turning on lights causes it to go crazy. Changed out regulator with the NAPA part---store here sure hadnt heard it was only $15 part though, over $40!
ar2stp48 is offline   Reply With Quote
Old 06-04-06, 09:39 PM   #13 (permalink)
Pin_Head's Avatar
It could also be a wonky ground connection between the alternator and regulator. My amp meter keeps time to my blinkers, but it hardly moves far. If your is banging on both of the bump stops you really have something there.
Old 06-04-06, 11:01 PM   #14 (permalink)
Ramblin Wreck
CruisinGA's Avatar
I ran the chrysler solid state regulator that is in the tech links for about a year.
Alternator went out and took the reg with it. Put in another mechanical VR and didn't notice much difference between the solid state and a new mechanical.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'53 Willys Wagon
ΣΧ
CruisinGA is offline   Reply With Quote
Old 06-04-06, 11:23 PM   #15 (permalink)
bsevans's Avatar
TLCA# 16217
This VR was purchased 2-3 years ago at the alternator shop for under $15. I do not know how many different harness connector styles Toyota used over the life span of the FJ. This VR has the same bolt pattern and the same harness connector. It is the same shop I went to recently when I decided it was time to switch to a gear reduction starter. The rebuilt GR starter was under $90 with a core exchange that I had picked up for cheap. This GR starter was rebuilt by the same house that MAF sells for $125. I think it pays to look at local shops for the support you need. I find that on average, the local shops are more than competitive with nationwide parts stores. When I had the factory alternator go out, the local alternator shop rebuilt it replacing bearings and diodes etc, and supplying the solid-state VR for less than a rebuilt alternator was at the AutoZone, PEP Boys and of course MAF & SOR.
78 FJ40
Old 08-13-06, 07:14 PM   #16 (permalink)
PabloCruise's Avatar
TLCA# 10713
Thanks for this info - I just had to replace my VR due to excessive curent drain killing my battery.
How did you establish the connections to the factory plug?
Thanks!
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
CO/WY - Horsetooth 4 Wheelers Cruiser Club
<<CLICK HERE>> for my Tech Threads
PabloCruise is offline   Reply With Quote
Old 08-14-06, 11:01 AM   #17 (permalink)
TLCA# 10713
Also, what year Cruiser did you swap this into?
Thanks again for this...
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 08-14-06, 11:30 AM   #18 (permalink)
bsevans's Avatar
TLCA# 16217
I just got off the phone with two alternator shops here in Tucson. They both have solid state voltage regulators on the shelf that are plug compatible. They show two Transpo VR that are interchangeable - IN551 and IN569. The cost is $22. They also said that they can special order SS VR for LandCruisers back to the late 60s. So my question is, why would you not buy one that is plug compatible with a cruiser as opposed to buying one meant for another vehicle and change out the connectors with questionable results?
78 FJ40
Old 08-14-06, 12:17 PM   #19 (permalink)
TLCA# 10713
I did not know they were plug n play!
Even better!
I just ASSumed that you had to splice your connector on - thanks...
What year Cruiser was your application?
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 08-14-06, 08:39 PM   #20 (permalink)
bsevans's Avatar
TLCA# 16217
Even better!
Did you not look at the photos in post #1?
I just ASSumed you could read my signature; 8/78
78 FJ40
Old 08-15-06, 07:46 AM   #21 (permalink)
TLCA# 10713
Thanks man - way cool.
My 09/77 '78 calls for a different VR than your 8/78 '78...
I'll check it out!
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 08-15-06, 08:30 AM   #22 (permalink)
Ming89FJ62's Avatar
OK, I'd like to take this one step further. My two FJ55 have build dates of May 78 (Wang) and Dec 77 (Arnold). The May 78 uses the 6 wire VR which is shown in the original photo but the Dec 77 uses the 3 wire VR. Is there a SS VR for a 3 wire arrangement?
Also, can someone explain the condensor on the plug lead?
Thanks,
Harry
78 FJ55 - "Arnold"
78 FJ55 - "Chester White"
89 FJ62 - "Ming"
07 UZJ100 - "Koto"
TLCA #13476
Ming89FJ62 is offline   Reply With Quote
Old 08-15-06, 09:18 AM   #23 (permalink)
bsevans's Avatar
TLCA# 16217
Thanks,
Harry
I think the condenser was for the radio to reduce the line noise (static). I’ve gone through a number of mechanical VRs and not all of them had the connection for the condenser, which came with the original VR. The alternator shop said that it listed a SS VR for a number of years. You would want to take your VR into the shop so they can confirm that the SS replacement VR has the correct connector. The shop I got mine from had a wide assortment on the shelf. I got the feeling that the connector on my 8/78 VR is not unique to Landcruisers.
78 FJ40
Old 08-16-06, 06:32 PM   #24 (permalink)
bsevans's Avatar
TLCA# 16217
Ok, I've looked into this further. I found that what the shop said about the IN551 and IN569 being interchangeable was incorrect. I also found that Transpo’s website not only list the VR available but show a photo of each and the form factor and pin out of most of the connectors for each VR they offer. Not all of the VRs they offer for Toyotas are SS. Some are mechanical. They list the Toyota VR part number and the cross reference to the Transpo VR part number.
Here is how to look this up and see what is offered and whether or not it is mechanical or SS.
http://www.transpo.de/Catalog/E_cat.html
Select Manuf to Transpo on the upper left.
Then select Toyota under manufacturer
If the Toyota P/N is listed then click on the Transpo number and it will show you the VR and all the X-reference Toyota numbers. This will also let you compare your VR connector with the Transpo connector for compatibility.
If you click on IN569 you will see the SS VR pictured in post #1.
EDIT: The VRs you might want to look at are: 551, 554, 558, 567, 568, 569, 578, 589, 1218, 1225.
78 FJ40
Old 08-30-06, 02:06 PM   #25 (permalink)
Coolerman's Avatar
TLCA# 13645
Bummer! They don't list an application for a Toyota 27700-40010 (ND 9702609-081) SS VR. What's in my 2/71 currently. There is no plug, the wires with ring terminals go under screws on this regulator...
!Oy my 1971 FJ40
It's not having what you want, it's wanting what you got...
http://tinyurl.com/ygeqfp7 FJ40 Wiring Parts for Sale
http://tinyurl.com/mxj5ve Misc Parts FOR SALE!
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 08-30-06, 02:31 PM   #26 (permalink)
TLCA# 10713
This is a WAY COOL thread!!!
I wish I saw it before I bought my latest reman VR from Toyota! $30 for a mech VR -
FWIW: my 09/77 FJ40 called for 27700-60100-84 VR = IN568 VR on the Transpo page.
When it says Regulation: B-Circuit does that mean this is a SS unit?
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 09-01-06, 02:17 AM   #27 (permalink)
el_diabolico's Avatar
More good info.
http://www.myblueheaven.com/fj40/tec...r_Upgrade.html
Thanks Scott!
10/71 FJ40,33s, HEI, 4WDB, PS
2000 UZJ100 Stock
2007 FJ Cruiser
__________________________
el_diabolico is offline   Reply With Quote
Old 09-01-06, 04:56 AM   #28 (permalink)
bsevans's Avatar
TLCA# 16217
IN568 is a SS VR.
78 FJ40
Old 09-01-06, 07:44 AM   #29 (permalink)
Coolerman's Avatar
TLCA# 13645
Originally Posted by el_diabolico
Sounds like that one would work for my 71. Thanks for the link!
!Oy my 1971 FJ40
Old 09-01-06, 09:37 AM   #30 (permalink)
762fmj's Avatar
This is awsome! I found the IN569 was the one for my '80. Thanks for all the great info.
1980 FJ40 Land Crusher Republican Gub Owner
www.2dreconbn.net
762fmj is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/95862-solid-state-replacement-mech-voltage-regulator.html
Posted By For Type Date
Troubleshoot Automotive Voltage Regulator, Troubleshoot 1999 Honda Accord Climate Control, Troubleshooting 1992 Park Avenue Buick Air Conditioning - Alwaysboots This thread Refback 03-08-09 07:51 AM
Starters Transpo << Starters << This thread Refback 08-02-08 01:35 AM
