Home Forum Gallery Wiki CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 40- & 55-Series Tech
LinkBack (3) Thread Tools Display Modes
Old 03-27-06, 12:52 PM   3 links from elsewhere to this Post. Click to view. #1
wantatlc's Avatar
2 gas tanks on 1 gas gauge?
I asked this question deep in another thread, but it got no play becuase of it I think so I thought I would ask it on it's own.
if you ran both + leads from the sending units on 2 different tanks (your main and the auxillary) to a 2 position knob and then from said knob on to the + post on the after market gas gauge on my dash that is currently setup to read only the main tank, could you not then turn the knob and switch between readings from 2 tanks? NOTE: both tanks would use the same brand/style sending unit made to work with the same style/brand gague on my dash so perfect compatability.
can anyone with good wiring knowledge confirm if it is infact as simple as I think it is logically and just adding a turn knob inbetween the gauge and both sending units to make it possible to flip flop between 2 tanks on 1 gauge?
if it is possible.. I believe I need a SPDT (single pull double throw) switch that has 3 posts (1 for each tank and 1 to gauge) and is always on (on-on) and has no off option. that is, the switch is either A or B and no dead center. correct?
SoCal FJ - 1974 FJ40 | Trail Photos | Parts Wanted & 4Sale
My FJ is better than your honor student
SPECS: SBC 350 | 4spd | Front discs | Saginaw | 33's | 3" lift SUA | Rancho 9000's | Detroit rear | Dual gas tanks | BeCool aux fan | Sliders | Onboard air | Stamped Bezel
wantatlc is offline   Reply With Quote
Old 03-27-06, 12:55 PM   #2
andrewfarmer's Avatar
correct
My ROTW thread...
andrewfarmer is offline   Reply With Quote
Sponsor 03-27-06, 12:59 PM
Sponsored Link
advertisement
Old 03-27-06, 12:59 PM   #3
wantatlc's Avatar
much appreciated
Old 03-27-06, 01:43 PM   #4
And, if both sending units match your guage.
1973 FJ40
Toy-let Front End; ARB Rear Locker; OME 2" lift with Rancho 9000s; Saginaw PS; Front & Rear Bumpers and Roll Cage by "DJ"; AL radiator by McCulloch; Spal fan; Rhino-lined; Base coat-Clear coat.
Coming Soon: 1999 5.3liter GMC Vortec; 4L60E & Toy
Split Case TC with Marks 3.05:1 Low Gear
hi50phd is offline   Reply With Quote
Old 03-27-06, 04:45 PM   #5
wantatlc's Avatar
guess you missed this:
"NOTE: both tanks would use the same brand/style sending unit made to work with the same style/brand gague on my dash so perfect compatability."
Old 03-27-06, 05:39 PM   #6
Yup, I did....
So, will you be using and aftermarket guage?
1973 FJ40
Old 03-27-06, 06:40 PM   #7
wantatlc's Avatar
yes sir.
I already use an aftermarket JC Whitney gauge and sending unit kit for the front tank as the original one is dead and I could never get the gauge to work. So, I have ordered the same exact JC Whitney sending unit/gauge kit for the rear and will just not use the gauge and use the gauge I already installed.... so 1 gauge on the dash only.
should be kind of slick when complete. if your really interested in what started this whole thing read here....
and this is related as well
Old 03-28-06, 03:41 AM   #8
Thanks...
just wondered if you'd found a Unicorn, the mythical 17-130 aftermarket sender.
1973 FJ40
Old 03-28-06, 09:25 AM   #9
Rick '79 FJ40's Avatar
My brother's 76 Bronco had a setup like you are talking about from the factory. The really slick thing to do is to get a solenoid-operated tank select valve and a double-pole switch so you will actually switch tanks when you switch gauges...
I know you can order these type valves for the Bronco. If you want to, check out Wild Horses webpage for those valves. www.wildhorses4x4.com
The biggest problem with switching the gauge like that is you can lose track of which tank you are running on and be looking at the fuel level in the wrong tank. My brother ran out of gas a time or 2 like that. The electric valve would prevent that.
Rick Jones
Put your seatbelt on, I wanna try something. I saw it on a cartoon, but I think it'll work! -JJJ
TLCA #14467
'79 FJ40 "Maureen"
'03 Lexus RX300 Mall Cruiser
Rick '79 FJ40 is offline   Reply With Quote
Old 03-28-06, 09:42 AM   #10
wantatlc's Avatar
I would like that system you mention and even looked at them. BUT, in a link above about my dual tank setup, I already have a hand mechanical switch in place to change tanks. So, that is why I just went the $4.00 switch route as I like the system I have and could not afford to go that route.
BTW, I actually installed the switch last night to tank 1 on my dash and have it hooked up and working just waiting for tank 2 to be attached in the coming weeks after I add the sending unit (see above link). And, I labeled the switch MAIN and AUX so I will know exactly which tank I am looking at. Also, you need to turn on an auxillary electric pump to help pull fuel from the rear tank to the engine, so that toggle (which has a light) is also a reminder of what tank you are drwing on. So, I think I am good there and no confusion shoud ensue.
Old 03-28-06, 10:21 AM   #11
45Kevin's Avatar
I had a 92 f150 with the dual tank setup. It was great on long trips to get 600 miles between fills. The system had one switch on the dash that changed from one sending unit to the other and at the same time flipped a valve where the two fuel lines converged. It was seamless.
45Kevin is offline   Reply With Quote
Old 03-28-06, 01:50 PM   #12
Yes, its a good system. The only drawback on my brother's Bronco was that the 2 tanks capacity together was about what a single tank holds on most 1 tank vehicles, 23 gal. I think the dual tank in this particular case was more of a gimmick than a real benefit...
Rick Jones
TLCA #14467
'79 FJ40 "Maureen"
Old 03-28-06, 01:56 PM   #13
You did a nice job on the switch. I'm kind of a fanatic about labeling things and making them look "factory"...
Rick Jones
TLCA #14467
'79 FJ40 "Maureen"
Old 03-28-06, 02:05 PM   #14
wantatlc's Avatar
thanks.. see this post for more like that simple and clean and I can replace easy and cheaply.
this switch went into the hole for the "Fan" as I had no use for it.......
Old 04-09-06, 06:25 PM   #15
wantatlc's Avatar
UPDATE: success today. I hooked up the second sending unit I bought to the switch and did in fact confirm I can flip back and forth between the 2 tank sending units with a SPDT switch and use 1 gauge.
sweet setup.
Old 04-09-06, 10:39 PM   #16
I can mangle anything...
DSRTRDR supports the BlueRibbon Coalition!
DSRTRDR's Avatar
man, you're on a roll........
will we see the rig at Cruise Moab?
Claudia
'72FJ40 with a no-number 2F, MAF headers, 4spd, 33x10.5 BFG MT, 4" lift, roll cage, prehistoric ARB lockers f/r, MAF disk brakes f/r, hand throttle, Painless wiring, CB, custom horn brush, dual advance dizzy, Bilsteins, 4+ front bumper/rear shackles/U-bolt flip, Kevin-improved frame/shackles/shackle hanger, several polished turds , with ChaseTruck yes, MANUAL steering
Copper State Cruisers #40 - TLCA #14706
http://www.desertrider.net/
DSRTRDR is online now   Reply With Quote
Old 04-10-06, 08:10 AM
Sponsored Link
advertisement
Old 04-10-06, 08:10 AM   #17
wantatlc's Avatar
I would like to but I have a big local race on May 7th (and I won the series last year) so I need/want to show up as that is my first love.
And, I have spent about 10 years or so going to Moab mountain biking everything there is to ride (and know how burley some of those trails can be) and I could easily see myself over extending my abilities.. getting caught up in the moment and frankly... I think I need another year of local wheelin to feel truly comfortable with the rig and my abilites before I tackle the trails at Moab I would want to tackle. Yeah, I could do the softball trails, but that is a long drive to do the easy stuff.
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/85951-2-gas-tanks-1-gas-gauge.html
Posted By For Type Date
Info.com - dual fuel tank switch - www.Info.com This thread Refback 02-08-10 04:22 PM
Spare tank wiring help - International Full Size Jeep Association This thread Refback 02-14-08 07:39 AM
SoCal FJ40 - Toyota 1974 Land Cruiser - FJ40 Toyota This thread Refback 12-22-07 10:49 PM
