#31 | |
__________________ Ed Gilbert - TLCA #5659 Formula 4 Toy #F006 build in-progress 1977 FJ40 - So. California vorteccruiser@charter.net |
#32 | |
__________________ SoCal FJ - 1974 FJ40 | Trail Photos | Parts Wanted & 4Sale My FJ is better than your honor student SPECS: SBC 350 | 4spd | Front discs | Saginaw | 33's | 3" lift SUA | Rancho 9000's | Detroit rear | Dual gas tanks | BeCool aux fan | Sliders | Onboard air | Stamped Bezel |
#33 |
Oh yeah the venting part, this what I did. i went to the junk yard and picked up a 83 chev pickup filler neck with the screw on cap. Than a 1980 toyota pickup filler hose went down to a utility bed shop and bught the recessed filler neck assembly.
__________________ 73 FJ40 Green - Original 74 FJ40 Red - (BMFCAGE) SOA 36X17IROKS weldedrear ARBfront and what ever els you can think of 97 FZJ80 Green (the wife's) - locked 67 fj45lwb in the works Last edited by greenfox; 06-30-06 at 09:04 PM. |
#34 | |
Although I don't think the Pollak valve is fuel injection pressure capable (60psi) like one of the MAF valves is. I know mine isn't, anyway. |
#35 | |
#36 | |
It wouldn't add much to the restoration cost even if the welding was done professionally. Finding, cutting, and drilling angle iron and then drilling the frame is even easier. |
#37 |
here is a photo montage:
switch handle in cab - tubing/switching device up to switch handle under floor board under cabin - electrical pump mount on frame rail and the fuel shut off valve (see those here) coming off aux tank. did not include one of the power pump toggle on the dash (which can be seen here) or the modified neck and vent setup which can be seen here in depth
__________________ SoCal FJ - 1974 FJ40 | Trail Photos | Parts Wanted & 4Sale My FJ is better than your honor student SPECS: SBC 350 | 4spd | Front discs | Saginaw | 33's | 3" lift SUA | Rancho 9000's | Detroit rear | Dual gas tanks | BeCool aux fan | Sliders | Onboard air | Stamped Bezel Last edited by wantatlc; 06-01-07 at 01:03 PM. |
#38 | |
#39 | |
I still have my filler neck custom mounted inside the wheelwell and want to eventually move it to through the sheetmetal. I was going to mount the original chrome Con-Fer fill neck & bracket combo through the passenger side sheet metal like the instructions always recommend, but I'm considering upsizing to 37s and moving the rear axle back 1" by relocating the center pins which would necessitate cutting the rear fender opening more towards the rear. That might interfere with the aux tank filler. I never thought of going through the rear corner using a 90º or bendable hose like you did. I still have to work out axle-to-aux tank clearance, so I have more thinking to do. Thanks for the pic and parts sourcing info. Thread subscribed.
#40 | |
Yours may be an older model.
#41 | |
#42 |
When I get my tig I am cutting out the tank so I can use 55 springs with yj flares. I put the filler out the back because every time I was leaning to the passenger side I would spill gas. And thre screw cap filler neck has anti flow back flap and is way easy to put gas in from a j##p can.
__________________ 73 FJ40 Green - Original 74 FJ40 Red - (BMFCAGE) SOA 36X17IROKS weldedrear ARBfront and what ever els you can think of 97 FZJ80 Green (the wife's) - locked 67 fj45lwb in the works |
#43 |
Nice pics and a lot of good information.
wantatlc, what size tires are you running? and do the tires come close to rubbing the fuel filler hose if that side was compressed? Also, is the in-line electric pump absolutely necessary or is it more for help? Would the stock fuel pump be strong enough to suck the fuel up from that distance? greenfox, does the spare tire carrier interfere when filling up? I really like that filler assembly, gonna have to pick on up. Thanks for posting pics. On the subject of senders, if the stock sender unit is half the resistance of the aftermarket ones, I wonder how hard it would be to hook up a simple circuit inline to "fool" the gauge into reading correctly. I'm gonna have to talk to a friend who's a lot better at this stuff than I. Last edited by ducktapeguy; 03-21-06 at 12:31 AM. |
#44 |
No problem with it yet the best mod I have so far. The spare tire carrier is my costum built bumper I will post pics when it is finished because this thing is awsome.
#45 | |
as for the pump. I think the pump is a must. a few times I have forgotten to flip the electrical pump on and started to bog down, flipped that on and fuel was good to go. Also, this could be further exacerbated if on a steep uphill climb? pump seems reasonable and necessary IMHO. __________________ SoCal FJ - 1974 FJ40 | Trail Photos | Parts Wanted & 4Sale My FJ is better than your honor student SPECS: SBC 350 | 4spd | Front discs | Saginaw | 33's | 3" lift SUA | Rancho 9000's | Detroit rear | Dual gas tanks | BeCool aux fan | Sliders | Onboard air | Stamped Bezel |
#46 | |
#47 | |
#48 |
wiring 2 tanks to 1 gague?
so, I got to thinking and wonder if this will work?
if you ran both leads from the sending units on 2 different tanks (your main and the auxillary) to a 2 position turn knob and then from said turn knob on to the post on the after market gas gauge on my dash that is currently setup to read just the main tank, could you not then turn the knob and switch between readings from 2 tanks? NOTE: both tanks would use the same brand/style sending unit made to work with the same style/brand gague on my dash so perfect compatability. BTW, I know there are cool systems mentioned that with the flip of 1 switch can change tanks and use 1 gas gauge.. but you can see I already have a menchanical handle in place for selecting bewteen my 2 tanks and this setup I purpose, if possible, would only require a $4.00 turn knob. can anyone with better wiring knowledge confirm if it is infact as simple as adding a turn knob between the gauge and both sending units to make it possible to flip flop between 2 tanks on 1 gauge? if it is possible.. what type of turn knob configuration do you need? (i.e., SPDT - single pull double throw) __________________ SoCal FJ - 1974 FJ40 | Trail Photos | Parts Wanted & 4Sale My FJ is better than your honor student SPECS: SBC 350 | 4spd | Front discs | Saginaw | 33's | 3" lift SUA | Rancho 9000's | Detroit rear | Dual gas tanks | BeCool aux fan | Sliders | Onboard air | Stamped Bezel Last edited by wantatlc; 03-25-06 at 05:11 PM. |
#49 |
Aw shucks. Must not have really been Lingo's mom. What a shame...
#50 | |
#51 | |
#53 | |
#54 |
If there were baffles, I assumed they would probably go from top to bottom, to give the tank some structural rigidity as well, but have holes or slots to allow gas to pass through without sloshing back and forth. But I could be wrong, since mine doesn't have any.
Mine tank looks almost identical to yours from what I can see, with the fuel filler tube coming out near the top of the passenger side of the tank. Meaning even if the baffles were attached from the top, they should large enough that you'd still be able to see them. The filler tube is pretty wide, I'm able to look inside and see a good portion of the opposite side of the tank. If you had a little mirror, you could probably look at the entire inside if you wanted to. |
#55 | |
Man-A-Fre!!!!
#56 |
thanks guys with what I have here, I think the only way is to finish using up the fuel and drop the tank. as soon as I empty the fuel I will be dropping the tank (likely this coming weekend as I burn fuel quick with that Chevy).
so, stay tuned as I will report bakc what I find out about my tank specifically AND I will report the process I use on this project to drop, drill, clean & line, install sending unit and toggle for 2 tanks on 1 gauge all when I am done. |
