Old 02-08-06, 02:59 PM   #1 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
Talking 1976 '40 Resto/Buildup
I have turned the corner on my project and am starting to rebuild it and decided to start a thread and post some pics of what I have been working on. I have actually been working on this project for almost a year on and off, but progress has been slow till now as first I moved, then I had knee surgery, and then ski season started (and I had to take the new knee for a test drive)
So, 1976 FJ-40 I have had for about 4 years with about a 4" SUA and 33's, Aussie in the rear, Armstrong steering, and a total rustbucket but I love it. I am repairing/restoring the body but not going for completely stock. Also:
SOA on stock 40 springs
5/85 FJ 60 Tranny and t-case
FJ-60 PS / FJ 60 PS Pump
FJ-60 knuckles
Spring reversal, with reversed and redrilled military wraps
OME greasable anti-inversion shackles
Hi-steer (probably 4x4 labs, TBD)
4.7 Toybox
Electronic ignition
Softop/doors
Custom rear tailgate
Family cage
Sliders
Aisin hubs
Custom driveshafts (TBD)
37x12.5 MTR's
Longfields inners and birfs in front
Poly Performance rears
Aussie rear
ARB front
Fine spline 4.11's front and rear
CO2
Fuzzy Dice
I want to keep it as Toyota as possible, so no v8's etc, I just want to spring it over, add PS, and get lower gearing for these CO trails.
I did a thread when I rebuilt the floor so i won't repost that part here. Here are some "before" pics and a shot of where I am right now.
1976 FJ-40
2001 UZJ-100
Pain is just weakness leaving the body.
"Do not go gentle into that good night.
Rage, rage against the dying of the light." - Dylan Thomas
Ullr is offline   Reply With Quote
Old 02-08-06, 06:12 PM   #2 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
Frame repairs, the front crossmember was badly rusted. I shopped around a bit looking for a replacement crossmember but was out there drinking beer one night and decided to just weld in new metal. The bottom of the crossmember was two layers of appx 1/8" steel riveted together, so I cut the rusted section out and replaced it with 1/4" steel. Fixed a small patch with some 1/8" too.
The final shot is the finished product all ground down... notice theres no shot of the welds? Too many 's during fabrication
1976 FJ-40
2001 UZJ-100
Old 02-08-06, 06:40 PM   #3 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
The rear shackle hangers were fubar. I don't know if you can tell from the first pic, but the rust between the plate the hanger attaches to and the frame had expanded to about 5/8", bending the plate downwards.
1976 FJ-40
2001 UZJ-100
Old 02-08-06, 06:43 PM   #4 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
So I flipped the frame and pulled them off, the passenger side one was repairable, the driver side (second pic) was not.
1976 FJ-40
2001 UZJ-100
Old 02-08-06, 06:46 PM   #5 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
So I made a new plate out of 3/16" and used 3/16" rod to make "rivets" to line it all up and help hold it together. I was able to reuse the original shackle hanger itself.
1976 FJ-40
2001 UZJ-100
Old 02-08-06, 06:48 PM   #6 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
i didn't really trust my wanna-be rivets on the new hanger plate or just welding the old rivets on the old plate, so I welded everything in hard.
1976 FJ-40
2001 UZJ-100
Old 02-08-06, 07:07 PM   #7 (permalink)
rutbeer's Avatar
Nice work there boss man!
78FJ40 13B-T, 5speed, split, full floater 70 series, cable lockers,4 disk, a/c, 60 pwr steering, all toyota except the a/c.
www.importpurist.com
Oh, and a bitchin FJ45 that may or may not be for sale.
"Much like a cat or hot buttered toast, the correct side will always try to land down. If the bezel is on upside down, then the force of it trying to right itself may cause you to roll your cruiser unexpectedly."
rutbeer is offline   Reply With Quote
Old 02-08-06, 07:10 PM   #8 (permalink)
bandy rooster's Avatar
good work, nice welds by the way.
that is a pretty serious axle carrier you have built.... you must have built that when steel was cheaper! lol
what prep's did you take to ensure that the shackle hanger was not welded cock-eyed? just followed your previous rivit hole pattern?
71fj40-350,SM465,3SPD L/C T-Case,4 WDB's,SAGINAW
Dude!, those are my work moccasins!
bandy rooster is offline   Reply With Quote
Old 02-09-06, 07:46 AM   #9 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
I built the axle jig out of some c-channel I had leftover from a misguided attempt to build a bumper. The base is actually the base for the bender. I figured the bench vise wasn't going to work and followed Josh's (JCB_Elwood) advice and built the jig to make it easier on myself.
Yeah I just used the rivet holes to line it all up.
1976 FJ-40
2001 UZJ-100
Old 02-09-06, 11:12 AM   #10 (permalink)
wesintl's Avatar
TLCA# 4180
AWESOME Ian.... I need to come bend some tube one night
Those welds look really nice.
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is online now   Reply With Quote
Old 02-10-06, 08:37 AM   #11 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
Turning the driveway into a purple beach. I used 30/40 garnet on the frame, zero risk of silicosis and reusable. What a PITA though
By a remarkable coincidence it was right about the time I started sandblasting in the driveway that the neighbors stopped talking to me.
1976 FJ-40
2001 UZJ-100
Old 02-10-06, 09:08 PM   #12 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
Ok its decision time. I want to go with a Toybox, but since I am upgrading to a Toybox should I upgrade to a split case at the same time? I know the split case is better but it will require a parking brake kit, especially since I am doing the RDB conversion. So now I am at Toybox + split case + parking brake kit... its getting really expensive.
So how bad is my stock case with a t-case saver? Is it really that bad that I should drop so much more money to go split case? Is the lower gearing in a Toybox going to increase the likelihood of t-case breakage?
1976 FJ-40
2001 UZJ-100
Old 02-11-06, 07:56 AM   #13 (permalink)
GCLC President
cruiserhead's Avatar
TLCA# 15185
I`ve read here on the board that a transfer case with a saver is as strong as a split case.HTH.Keep up the good work.
1971-80 FJ40 Hey,I used what I had.Trail and plow truck.
`05 Trailblazer, wifes DD,`05 GMC 2500HD SLE Extra Cab 4x4 Cruiser Hauler,`95 Kawasaki Vulcan 1500
www.gclcny.com
Installer of Metal Tech products
Crum`s Custom Welding,LLC ccw1@optonline.net
Bumpers to roll cages,FJ40 skid plates-fits stock 3,4 speed & Orion trans and transfer case combos.1 year in development and Telico tested
cruiserhead is offline   Reply With Quote
Old 02-11-06, 10:43 AM   #14 (permalink)
bustanutley's Avatar
cruiserhead, I really don't buy that, people snap the nose cones on the earlier cases all the time.
FJ-40 on FO-DEEs
just a lil guy
bustanutley is offline   Reply With Quote
Old 02-11-06, 04:10 PM   #15 (permalink)
foxfab's Avatar
TLCA# 9838
I have a new 4.7 Toybox for a split case for sale
http://forum.ih8mud.com/showthread.p...453#post938453
YANKEETOYS.ORG
Member of the elite FJ25 club
Low range? We Don't Need No Stinkin' Low Range
Why would you want to put a round tire in a square wheel well?
foxfab is offline   Reply With Quote
Old 02-11-06, 04:40 PM   #16 (permalink)
ever thought of just using a line lock instead of the parking brake? or is there another reason for the parking brake kit?
Old 02-11-06, 06:49 PM   #17 (permalink)
jjhancock's Avatar
Looks great man, keep up the good work. Who cares what the neighbors think, I wouldn't! I can't answer the t/c question for you, although I seem to recall reading on the forum here at some point that people weren't that impressed wiht the Toybox. Food for thought... Gitter done!!!
jjhancock is offline   Reply With Quote
Old 02-11-06, 08:40 PM   #18 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
No, becuase I don't know what a line lock is. Can you give me some more details? Search turned up nada.
1976 FJ-40
2001 UZJ-100
Old 02-11-06, 09:49 PM   #19 (permalink)
ian, line lock locks your hydraulics on your brakes
they are super cool for hotroders cause they can lock just their front wheels and do burnouts from hell.
FJ-40 on FO-DEEs
just a lil guy
Old 02-12-06, 09:07 AM   #20 (permalink)
2 types of line locks manual and electrical (aka; mico lock, parking lock, parking brake valve, hydraulic lock......) . I've used the one from Jamar and don't care for it due to rusting of parts in my environment. I'm going to redo my brakes within the next month and replace the Jamar (2 years old) with Swagelok version.
Jamar;
http://jamarperformance.com/TheRealm...product_id=147
Swagelok;
http://www.downeyoff-road.com/Chassi...Brakes_02.html
Electric;
http://store.summitracing.com/defaul...=egnsearch.asp
edgemonster is offline   Reply With Quote
Old 02-12-06, 09:32 AM   #21 (permalink)
red66toy's Avatar
So, do you have to mount the manual locks in the cab? That seems wierd to have brake line coming into the cab. A cable actuated one would be cool.
Edit, why do they all say that they are not meant to be an emergency brake?
65 FJ40L(clifford), sold
06 GF Big Sur-now with working brakes
87 Cannondale Criterium
00 Subaru Impreza outback-bike hauler
It never gets easier, you only get faster.
Ed(Degnol) rocks!
red66toy is offline   Reply With Quote
Old 02-12-06, 02:14 PM   #22 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
Very cool, thanks for the links.
I beleive an "emergency brake" is a mechanical system that does not rely on your brake hydraulics, so it can be used in an emergency if the hydraulics system fails.
1976 FJ-40
2001 UZJ-100
Old 02-12-06, 07:25 PM   #23 (permalink)
ridgerunner's Avatar
There is not a snow ball's chance in hell that a stock T'case brake would slow a Cruiser during an emergency. It's a "parking brake" at best.
What sort of RDB conversion are you going to use? If using Chevy parts, you can do a parking brake....
ridgerunner is offline   Reply With Quote
Old 02-12-06, 10:16 PM   #24 (permalink)
REZARF's Avatar
TLCA# 13041
[QUOTE=
Edit, why do they all say that they are not meant to be an emergency brake?[/QUOTE]
An emergency brake is a seperate system from the hydrolic brake lines.
Picture youself rolling down a steep decent on a nasty trail... now you brake pedal hits the floor... locking up the hydrolic pressure with a line lock in the line will produce no stoppage.
Grab the emergency brake handle, and a mechanical cable engages the brake drum on the tcase...
..."whoa, that was close."-Chris Farley
LIne locks are cool and can give you a third foot sometimes when you really need it, but it shouldnt replace a good emergency brake.
Rezarf <><
Drew F.
Rising Sun 4x4 Club
Old 02-12-06, 11:36 PM   #25 (permalink)
red66toy's Avatar
Dude, I dont think that the dinky cruiser ebrake is going to stop anything on a steep decent.
Ed(Degnol) rocks!
Old 02-13-06, 12:50 AM   #26 (permalink)
TRUTH
FJ-40 on FO-DEEs
just a lil guy
Old 02-13-06, 07:34 AM   #27 (permalink)
> ur godz... wtfpwn
Ullr's Avatar
TLCA# 13862
I was wondering about this. I bought the RDB conversion brackets Dearborn was selling and I am waiting for them to arrive. I assume they are for GM calipers. If so, is there a specific caliper I can use?
1976 FJ-40
2001 UZJ-100
Old 02-13-06, 08:08 AM   #28 (permalink)
tucker74's Avatar
Better check your state regulations as well - in Texas a vehicle must have a working emergency brake to pass inspection ... and a line lock does not fulfill this requirement
Nice work on the frame!
Tucker
'94 FZJ80
'76 FJ40
www.walcs.com
tucker74 is offline   Reply With Quote
Old 02-13-06, 08:17 AM   #29 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
No it's not going to stop you like the regular brake system would. But that said I can lock my rear wheels up with it as long as I pull on it hard. It really depends on if you have it set right and no oil leaks.
And a line lock won't pass inspection at GSMTR. As the saftey guy for our club I would recommend it as a third option or for special purposes.
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
"What fits your busy schedule better, exercising 1 hour a day or being dead 24 hours a day?"
Trollhole is online now   Reply With Quote
Old 02-13-06, 09:01 AM   #30 (permalink)
I'm not sure of the dearborn kit, but you can use Eldorado calipers which have an integral parking brake. http://tsmmfg.com/3110.htm
If you have the "standard" chevy kit, something like this : http://tsmmfg.com/2491.htm you should be able to swap the eldo calipers in no problem.
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/78855-1976-40-resto-buildup.html
Posted By For Type Date
Mensagens recentes This thread Refback 12-17-08 12:52 AM
COMO PASSAR AS MOLAS POR CIMA DOS EIXOS toyotas bj40 bj73 etc This thread Refback 12-16-08 06:26 PM
