Old 04-27-08, 02:46 PM   #331
Eons ago in the first couple pages of this thread there were a couple of questions about strength and SS bolts. For the record I am not a metallurgist but I do have some experience in this area and my company has sold 100's of thousands of stainless nuts and bolts for non-auto related specialty applications.
The short version is that there are different grades of stainless and the most readily available is the cheap stuff, typically type 304 stainless. The threads on 304 are comparatively brittle and under tension will gall or just flat snap off.
For our applications we use type 316 (a slightly different recipe for the stainless) and it's worked well under tension. It's also more resistant to typical corrosive compounds that you're likely to run across. The downside is that type 316 is about 3x the price of the more common type 304 that you'd normally find in a bolt kit.
A couple of other unrelated comments:
A poster a while back mentioned a source for bolts in China. There are to my knowledge no manufacturers in the US for general use threaded hardware like nuts and bolts. They'd go out of business instantaneously as the Asian suppliers have a wildly lower cost base and fewer EPA type reg's to contend with, etc.
On a similar note, SS is a work hardened material which is why you seldom see compound angles in a stainless fitting. Hit it more than once to bend it to your desired shape and it's likely to have become too brittle during the second heat cycle.
Note:
I am a complete caveman with a wrench and don't know what kind of actual torque values that 316 SS threads would max out at. If you have a known high torque application you should verify that the threads will hold up w/ your supplier. The hardness of the fastener certainly will but the brittleness of it may not.
legion is offline   Reply With Quote
Old 04-27-08, 11:10 PM   #332
pportmd's Avatar
Very interesting, thanks!
pportmd is offline   Reply With Quote
Old 04-28-08, 07:15 AM   #333
Coolerman's Avatar
TLCA# 13645
Cool Arghhhhhhhhh.....
Has ANYONE heard from Kevin@boltdepot about pricing or their quotes? I can no longer wait to order bolts and can't afford to wait weeks to get a simple bolt order.
Merbelsfield: What was the final answer to the pricing?
!Oy my 1971 FJ40
Not Road Legal
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 04-28-08, 12:01 PM   #334
71FJ40's Avatar
Nope....
x2 - "I can no longer wait to order bolts and can't afford to wait weeks to get a simple bolt order. "
I am checking with local Auveco dealers....
'64 FJ45L
'71 FJ40 OME, ARB Bull Bar, Non-USA Carb and Distributor, Warn 12000;
'85 FJ60 OME, Bull Bar
'87 FJ60
71FJ40 is offline   Reply With Quote
Old 04-28-08, 03:54 PM   #335
71FJ40's Avatar
Looks like we are back to square 1.
Just spoke with the local auveco rep and most of the part numbers for the M6 and M8 bolts have either been discontinued or are only available in bright zinc.
The rep is looking at other manufacturers and I will let you know if another distributor pops up.
'64 FJ45L
'87 FJ60
Old 04-29-08, 03:26 AM   #336
filmpilot's Avatar
The codes for all the cruiser bolts and torques are decoded in the Worskshop manual. Page 14-23
Theres a method to the madness:
I.E. 91111-40620 Last set of digits: 4= Bolt head mark; 06=Major diameter of thread 20=Grip length (from under head to end)
Have any of you guys tried Caswells plating kit? I have and have had great success!
filmpilot is offline   Reply With Quote
Old 04-29-08, 08:25 AM   #337
Coolerman's Avatar
TLCA# 13645
Cool
Yes this was covered on Page 6, post #159 of this thread.
Are you buying zinc bolts then replating them with the Caswell kit? If so give some detailed information about this.
!Oy my 1971 FJ40
Not Road Legal
Old 04-29-08, 09:02 AM   #338
hmmm, just thinking out loud.......stainless sure is purdy but in aviation you cannot use ANY kind of stainless steel for structural elements....just my 0.02
Lou
n2666s is offline   Reply With Quote
Old 04-29-08, 10:29 AM   #339
kb3gun's Avatar
TLCA# 17295
No word from Kevin...
I'm just going to get from a local hardware source. Not worried about reproduction finishes. Zinc will do. Fit, form and function is what I'm going for.
Bill
Somerset, PA USA
2007 FJ Cruiser
1966 FJ40 (Website Link:New Project) (on Mud: updated more often)
Proud member of ALCA!
kb3gun is offline   Reply With Quote
Old 04-29-08, 11:44 AM   #340
71FJ40's Avatar
Got another solid lead on the yellow dichromate - fingers crossed...
'64 FJ45L
'87 FJ60
Old 05-02-08, 11:57 AM   #341
reservefj40's Avatar
Does anyone have the sizes for the body mount bolts for a 79+ FJ40? I've searched the entire site and the spreadsheet and can only find the sizes for 78-. 79+ has 10 bolts of 4 diff. sizes and the 78- has 12 of the same size. appreciate any help.
Finally found one thing I would trade my FJ40 for and she only weighs 7lbs15oz. Gotta find a FJ40 car seat!
reservefj40 is offline   Reply With Quote
Old 05-02-08, 01:26 PM   #342
Coolerman's Avatar
TLCA# 13645
Cool
No, I only have an old rusty 1971 to measure.
If you do break down and have to pull them out, measure them and post up. I'll put them in the spreadsheet!
I just just have to say, I love your sig line. Congrats on the new addiction! Hard to say which one will cost you more!
!Oy my 1971 FJ40
Not Road Legal
Old 06-01-08, 07:02 PM   #343
merbesfield's Avatar
TLCA# 16162
Nope....
There was no final answer. Sorry for not posting earlier, but I did not see this. Kevin NEVER sent me an invoice after I talked to him many times. But I did get all my stuff from him and most of it was replated yellow zinc and turned out great, just wish I had done more. I did I a good bit, but working in the shop the other day and it just does not seem like a big quantity. I would keep calling Kevin, he is just really busy and needs to be told what you want, don't wait for him to call you back. Good luck. Mark
merbesfield is offline   Reply With Quote
Old 06-02-08, 07:41 PM   #344
TLCA# 16162
Great job Coolerman.
Old 06-02-08, 08:11 PM   #345
71FJ40's Avatar
Think I may have found another source - waiting for samples and will post pics when they arrive.
'64 FJ45L
'87 FJ60
Old 06-17-08, 07:04 PM   #346
antFJ's Avatar
any updates on this? i am about to buy bolts... i would love zinc plated instead of Stainless...
Oct '76 FJ40
'84 S-10 - '94 S-10 blazer leather interior, 3" hocky puck
antFJ is offline   Reply With Quote
Old 06-19-08, 07:19 PM   #347
Coolerman's Avatar
TLCA# 13645
Cool
Headlamp Body to Headlamp Housing Ring Screws
4 5mm x 0.8mm x 12mm Lock washer only. Phillips #2 head.
These screws pass through the Headlamp body, then the bib, then thread into the Headlamp Body Retaining Ring.
!Oy my 1971 FJ40
Not Road Legal
Old 06-20-08, 06:08 PM   #348
Coolerman , the 6 screws that hold on the vent on the outside of the cruiser for the heater blower are 5mm x .8mm x 10mm phillips flat head....
CRAWLTOY is offline   Reply With Quote
Old 06-22-08, 04:04 PM   #349
Coolerman's Avatar
TLCA# 13645
Cool
Thanks! I'll add that to the spreadsheet Monday!
!Oy my 1971 FJ40
Not Road Legal
Old 07-01-08, 12:44 PM   #350
Beast II's Avatar
Convenient Amazon.com Link to Bolts
Here's a link to tons of nuts and bolts on Amazon.com:
Amazon.com: Northeast Fasteners - Industrial & Scientific: Industrial & Scientific
RHD 1982 BJ42
Beast II is offline   Reply With Quote
Old 07-29-08, 11:09 AM   #351
71FJ40's Avatar
OK - just placed an order with Wurth and will take pics once the fasteners arrive.
SEMS Grade 8.8 Yellow Zinc Bolts:
The M6's have a 10mm head
The M8's have a 12mm head
NOTE - The thread pitch on the M10's (1.5) - I do not believe this will work on most cruiser applications
Class 8.8 Yellow Zinc Hex Nuts:
Note the M8's come in either a 12mm or 13mm head (WAF)
Class 8.8 Yellow Zinc Hex Nuts w/ Captive Washer:
Class 8.8 Yellow Zinc Metric Washers:
Wurth USA can be reached @:
800.987.8486 then press 3 and then 2 for a rep in your area.
If you are in Colorado shoot me a PM and I will get you the contact info for our rep.
'64 FJ45L
'87 FJ60
Old 07-29-08, 11:33 AM   #352
Coolerman's Avatar
TLCA# 13645
Cool
Care to publish your order list and how much it all cost?
FWIW I have emailed Kevin at Bolt Depot 3 times. Each time he says he will get back to me but never does....
As an aside, there are only 8 bolts that I have found on the Cruiser that are 10mm x 1.5: 5 water pump bolts, 2 F alternator bracket to block bolts and 1 Clutch slave cylinder to tranny bolt.
!Oy my 1971 FJ40
Not Road Legal
Old 07-29-08, 01:32 PM   #353
71FJ40's Avatar
62612 6x12 bolt
62616 6x16 bolt
62620 6x20 bolt
62820 8x20 bolt
62825 8x25 bolt
62830 8x30 bolt
62835 8x35 bolt
31706 M6 nut
31708 M12 nut
03796 M6 nut w/ captive washer
44106 M6 lock washer
44108 M8 lock washer
40706 M6 flat washer
40708 M8 flat washer
I ordered 100 each of the bolts and then the corresponding number of nuts/washers/lock washers for each
I am waiting for the final quote with shipping and will update shortly.
Thanks for the heads-up on the M10 - and no, I never heard anything back from Kevin either.
'64 FJ45L
'87 FJ60
Old 07-29-08, 01:46 PM   #354
Coolerman's Avatar
TLCA# 13645
Cool
Originally Posted by JimmieT View Post
X2 !!
Torque Calculation for a 1/4" bolt, Gr8, CS
T=(k x d x P) / 12 * 75%
T = Torque (ft/lbs)
k = cofficient of friction
d = nominal diameter (inches)
P = Yield strength (psi)
Formula Lubed Assembly:
T=(.05 x .25 x 130,000 lbs.) / 12*75%, T= about 100 ft./lbs.
Plain & Clean Assembly:
T=(.15 x .25 x 130,000 lbs.) / 12*75%, T= about 305 ft./lbs.
Rusty Assembly:
T=(.45 x .25 x 130,000 lbs.) / 12*75%, T= about 914 ft./lbs.
This demonstrates that properly cleaned and lubed bolts/nuts will acquire the proper torque at a lower torque value.
No offense to physics, but unless I'm missing something, I don't care what that 1/4" bolt is made from, it will break LONG before you reach even a 100 ft.lbs let alone 914! inch lbs maybe....?
!Oy my 1971 FJ40
Not Road Legal
Old 07-29-08, 04:27 PM   #355
JimmieT's Avatar
You are correct, a 1/4" Gr8 bolt should probably only be torqued a to maybe 8 ftlbs. (about 100inlbs)
My example, was only an example .... not actual torque values. The final formula for determining torque values also takes a BUNCH of other data into consideration: Proof Load, Stress Area, TPI, Pitch Diameter, Root Diameter, Underhead Coefficient of Friction, etc.
I apologize for the confusion. I tried, unsuccessfully, to simplify a very complex process!
Again, always refer to OEM specs. for proper torque values.
Big Jim's Dirty Kidz 1970 FJ40 ... mostly stock ... not too fast ... with a little bit of rust ... please send money!
"Things are more like they are now ... then they ever were before!" Dwight D. Eisenhower
JimmieT is offline   Reply With Quote
Old 07-30-08, 10:42 AM   #356
