#121 |
Can I get a copy of the spreadsheet? gregsolis@hotmail.com
Anyone hosting it so we can get updated versions online? __________________ ih8rust "...bringing peace with honour. I believe it is peace for our time. Go home and get a nice quiet sleep." TLCA# 15390 1978 FJ-40 Getting Frame-Upped |
#122 |
Couple more
Timing Cover to Block Bolts 8 6mm x 1.0 x 8mm. 10 mm Head. Split washer only 2 6mm x 1.0 x 16mm. 10 mm Head. Split washer only. Pay attention to where these go! 2 10mm x 1.25 x 25mm. 14mm Head. 5mm shoulder. No washer Oil Pan to Block Bolts 22 8mm x 1.25 x 18mm. 12mm hex Head with phillips also. 13mm will NOT fit. Split washer only. __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 04-29-08 at 07:36 AM. Reason: Updated info |
#123 |
This is a great thread. It's definatley something to add to the tech FAQ. Perhaps add full explanation and a plus/minus list of the choices when replacing fasteners:
JIS sizing vs. +1 "normal" Stainless vs. zinc vs. yellow zinc Hex head vs. allen/socket head (what other am I missing?) It seeems to me that stainless +1 "normal" hex head is the easiest way to go. And JIS yellow zinc hex head are the original way. Someone post or PM me a link. I can host it and/or look into some other solution - put it into a google spreadsheet or some other dynamic web site that allowed sort, filter, etc. -m |
#124 |
Great info guys. Thanks for all your hard work. I sure would like a copy of the excel also. firemedic@wildblue.net
Thanks again, Eric __________________ Don't gnaw on your kitty ![]() Poo-flinger build up: http://www.pirate4x4.com/forum/showthread.php?t=548889 |
#125 |
if someone sends me the excel file, I can zip it and put it on my server with a link to it here in this thread.
__________________ 73 FJ40 - Build Thread 350 V8, NV4500, Orion HD, F&R ARB. Power Steering, 4" Spring Lift Volvo Seats, 22 Gallon Gas Tank Disk Brakes Front and Rear |
#126 |
IH8MUD Junior Whopper
__________________ Yahsoo! 1969 Breathe FJ40 Currently in the middle of a ground up... 1976 Olive FJ40 finished as of May 2008 Faster Track Resto
#127 |
"quote" Motor Mounts to Block Bolts from coolerman Post #105
12 12mm x 1.75 x 32mm. Split Washer. 17 mm head. 19mm will NOT fit! bolts heads stamped with a 5. in an earlier post it states motor mount (cast piece to block) 12mmx1.25x25 Does anyone know which is correct. __________________ Don't gnaw on your kitty ![]() Poo-flinger build up: http://www.pirate4x4.com/forum/showthread.php?t=548889 |
#128 |
I've got almost all of this done in excel myself from info posted up here. When I get it finished, tonight of tommorrow, I'll post it up.
Might not be as nice as the one that got started earlier, but I'm no computer whiz. Thanks for all the effort you guys have put into this I'm at work and not near my rig, so does anyone know the sizes of the bolts that are along the frame that holds the fuel and brake lines against the frame? Also for the Bezel, nuts to secure the radiator mesh to the bib, the bolts that hold the heater fan, the rear heater, the seatbelt mounting bolts, instrument cluster screws, ashtray screws, fuel filler neck bolts, fuel tank strap bolts, rear heater bolts, pintle hitch bolts, knuckle wiper cover bolts __________________ Don't gnaw on your kitty ![]() Poo-flinger build up: http://www.pirate4x4.com/forum/showthread.php?t=548889 |
#129 |
also it said engine splash guard to frame m10x1x16 qty 2 with captured split and flat.
This doesn't sound right, can anyone check please I have the excel done now and you can filter by description, bolt size, pitch and length. __________________ Don't gnaw on your kitty ![]() Poo-flinger build up: http://www.pirate4x4.com/forum/showthread.php?t=548889 |
#130 |
Whats the specs on driveshaft bolts. I know post 1 or so said to use OEM, which is fine. But I need the specs so I can find some at the local yard. I read Toyota used the same driveshaft bolts up to 1990 on all thier 4x4's.
Edit: I found the bolt specs. 10mm x 30mm x1.25 with a 10mm shoulder. These should be 10.9 grade and balanced. w/lock and flat. __________________ Yahsoo! 1969 Breathe FJ40 Currently in the middle of a ground up... 1976 Olive FJ40 finished as of May 2008 Faster Track Resto
#131 |
#132 | |
Anyone source their nuts & bolts from the vendors listed on this worksheet (e.g., boltdepot)? Otherwise, I may resort to one of the local Cleveland fastner companies - |
#133 | |
I just corrected this in my old post and do apoligize for the error. I was cussing myself last weekend when I tried to thread 12mm bolts into a 10 mm hole. Here is the corrected data again.Front motor mount to block bolts 6 10mm x 1.25 x 30mm Split + Flat washers. 10mm shoulder. 14mm head. Rear Motor Mount to Tranny Bell Housing 6 12mm x 1.75 x 30mm. Split Only. No Shoulder. 17mm Head. __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
#134 | |
![]() Fixed that also! It should say Qty 2 6mm x 1.0 x 16mm __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
#135 |
GSMTR Chair
__________________ Marshall Upstate Cruisers The Great Cruiser Part Links Thread Buying a Land Cruiser Guide 73 Fj55 Big Ugly 76 FJ40 ROTW Big Gay 2f Build 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. |
#136 | |
#137 | |
Weird interface to their parts... I'll figure it out ....http://cascadenutandbolt.com/index.j...h=externalhome __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
#138 | |
Definitely not a "US Marine" friendly site ... I'll wait until some smart guy figures it out and shares the secrets. __________________ 1978 FJ40 frame up project 1993 Suzuki GS500E |
#139 |
WaAkFJ clean out your mail box!
Then send me a copy of your spreadsheet coolerman@qx.netBad Coco can you send me your version of the spreadsheet? I'll see about finding out some of the bolt sizes you requested earlier. __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
#140 | |
3 8mm x 1.25 x 20mm Captured split + flat washers. 12mm head but 13mm will fit Radiator Mesh Bib Mounting Nuts 6mm x 1.0 Use with 6mm flat and split washers 10mm Head. Bib studs are 6mm x 1.0 x 15mm Heater Core Box to Fire Wall 4 8mm x 1.25 x 20mm Captured flat + split. 12mm head but 13mm will fit. Heater Blower Box to Fire Wall 4 8mm x 1.25 x 25mm Captured split + Flat washer. 12mm head but 1mm fits Gauge Cluster Screws 2 6mm x 1.0 x 8mm Pan head JIS Phillips Knuckle Felt Retainer Bolts 16 6mm x 1.0 x 12mm Captured split + flat washers. 10mm head. Knuckle Steering Stop Studs 4 12mm x 1.25 x 35mm Domed 14mm Head 4 12mm x 1.25 Jam nuts. 17mm Head Fuel Filler Neck to Body Bolts 3 6mm x 1.0 x 12mm Captured split + flat washers. 10mm Head Rear Heater to Floor Bolts 2 8mm x 1.25 x 20mm Split + Flat washers. 12mm Head but 13mm fits. Seat Belt Floor Anchor Bolts 4 11mm x 1.25 x 25mm 5mm Shoulder. Split+Flat washers. 17mm head. __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 08-17-07 at 08:33 PM. |
#141 |
Inbox is cleared now... excel sheet hasn't been worked on at all from the last time (April?? or March?).
__________________ `·. , . .·´¯`·. , . .·´¯`·. , . .·´¯`· .·´¯`·..><((((º>`·.¸¸.·´¯`.¸.·´¯`·...¸ |
#142 |
What? You didn't immediately add the new stuff I posted?
The IH8MUD community is waiting breathlessly for the update! ![]() ![]()
#143 |
4 11mm x 1.25 x 25mm 5mm Shoulder. Split+Flat washers. 17mm head is this correct? or is it a 12mm? I'll pm ya the excel now. I think I have everything that has been posted to date. __________________ Don't gnaw on your kitty ![]() Poo-flinger build up: http://www.pirate4x4.com/forum/showthread.php?t=548889 |
#144 |
coolerman, send me your email. Mud's not letting me send you a file. May be operator error on my end. Eric
#145 |
nevermind, found it on your website. Email sent. Eric
