#91 | |
As for the 4Wheel Auto nuts and bolts, they may actually be a pretty good deal. Plus I am having a fun time finding JIS! __________________ `·. , . .·´¯`·. , . .·´¯`·. , . .·´¯`· .·´¯`·..><((((º>`·.¸¸.·´¯`.¸.·´¯`·...¸ |
#92 |
Couple from tonight
Passenger seat Frame to Tub (2/1971) 4 8mm x 1.25 x 20mm Captured Flat + Split 12mm head but 13mm fits Drivers seat hinge anchors to tub (2/1971) 4 8mm x 1.25 x 20mm Captured Flat + Split 12mm head but 13mm fits Side Apron to Front Bib 2 6mm x 1.0 x 16mm Captured Flat + Split 10mm head Side Apron to Fender 4 6mm x 1.0 x 16mm Captured Flat + Split 10mm head __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
#93 | |
I got an interesting email back from a vendor. He claims that the reason no can find JIS stainless in certain sizes has to do with their strength compared to zinc bolts. He says an 8mm bolt in stainless REQUIRES a 13mm head otherwise it would shear off when torqued to spec. Makes a bit of sense actually.... __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
#94 |
Thanks for posting those coolerman...
I added some more of the stuff on this thread to the excel sheet. From what Coolerman has contributed there are over 800 pieces (nuts/washers/bolts) and counting! Thanks Coolerman for taking the time to do this for other people! There is also quite a bit of other sizes contributed by other people, and some that I have measured by haven't entered. The early 70s soft top FJ40 sizes are now well covered! __________________ `·. , . .·´¯`·. , . .·´¯`·. , . .·´¯`· .·´¯`·..><((((º>`·.¸¸.·´¯`.¸.·´¯`·...¸ |
#95 |
I'd love to get a copy of the spread sheet. I'll measure some bolts if you need some done still since my cruiser is tore all the way down
Thanks, Burl cruiser@visuallink.com __________________ '77 FJ-40 2F 4SPD.TRANS W/3SPD.CASE HOLLEY CARB. OFFENHAUSER INTAKE UNDER CONSTRUCTION SOON TO HAVE GOZZARD TUB, SOA ONE DAY '88 FJ-62 4" Alcan Springs w/Daystar Super Shackles 33"x9.5" tires front & rear Aussie lockers with Sliders NOW '99 GMC SUBURBAN -YOTA TOTER |
#96 | |
IH8Mud4Life
Did you mean to say, "...a bucket of MONEY"... lol. Nice !! ..and I've seen the pics of your finished rig! Scott __________________ 1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag" - www.BSLCA.com - Good friends, a few cruisers, alot of laughs and a bunch of wives making this face --> "If I'm off (which is rare)... I'm in!" |
#97 |
As I get further along in my revival of !Oy I'll keep posting. Especially when I start putting it back together. Then I'll know for sure what goes where and can get a verification of my previous measurements.
This site has been awfully good to me so I don't mind returning some of my work for others to benifit from. __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
#98 |
__________________ BEAT YOUR FACE!!!!! |
#99 |
Thanks Scott, but I'm having trouble opening the files unknown file type keeps coming up
is it something I'm doing wrong
#100 | |
IH8Mud4Life
Sorry bud. Should be an excel file?? I tried mine again and it works fine. Let me know if you need/want me to send it again. I can probably copy it into MS Word. Scott __________________ 1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag" - www.BSLCA.com - Good friends, a few cruisers, alot of laughs and a bunch of wives making this face --> "If I'm off (which is rare)... I'm in!" |
#101 |
I have tried to send out the excel sheet to everyone that asked. If you didn't get it, send me a PM.
Any reports on the 4Wheel Auto bolts yet??? __________________ `·. , . .·´¯`·. , . .·´¯`·. , . .·´¯`· .·´¯`·..><((((º>`·.¸¸.·´¯`.¸.·´¯`·...¸ |
#102 |
Very helpfull thread, WaAkFJ! It has helped me, and I'm sure others. It should be on it's way into FAQ's. Keep up the good work, and thanks!
__________________ --- DAN --- 1978 FJ40 |
#103 | |
IH8Mud4Life
We'll see. Skeptacal... but we'll see :fingers crossed: Scott __________________ 1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag" - www.BSLCA.com - Good friends, a few cruisers, alot of laughs and a bunch of wives making this face --> "If I'm off (which is rare)... I'm in!" |
#104 |
I can't seem to find any screws to fit the defroster ducts to the windshield frame. There are 6 in all and the screw I have that fit's all of the welded on nuts has a 28 count per inch SAE thread count and what might very likely be a metric diameter...
I didn't have a .7 pitch unit to compare it to but the .80 and the 1.0 and 1.25 are not a match. Any help from you amazing 'nuts' who've kept this thread going with so much awesome info so far? Thanks! FE |
#105 |
Been awhile, I have a lot to add this time so bear with me
Fuel Pump to Block Bolts 2 8mm x 1.25 x 30mm. Split washer only. 12mm head but 13 barely fits. Starter to Bell Housing 1 12mm x 1.75 x 25mm Flat and split washer. 17mm head 1 12mm stud 1.25 starter end 1.75 bell housing end x 27mm. 1.25 Threads 15mm long 11mm of shoulder then 1.75 threads 10mm long. Nut is 12mm x 1.25 17mm ** I don't know if the stud is stock but it makes it easier to get the starter off! ** Fly Wheel to Crank Bolts 6 10mm x 1.25 x 30mm. 10mm shoulder. 17mm head. 3 half moon shaped nut retainers with bend up ends. Front Motor Mounts to Block 6 10mm x 1.25 x 30mm. Split + Flat washer. 10mm shoulder. 14 mm head Rear "Motor Mounts" to Tranny Bell Housing 6 12mm x 1.75 x 30mm. Split Washer. 17 mm head. 19mm will NOT fit! bolts heads stamped with a 5. Clutch Cover to Fly Wheel Bolts 6 10mm x 1.25 x 25mm. Split Washer. 4 mm shoulder. 14 mm head. Stamped with a 4. __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 10-25-07 at 11:08 AM. Reason: Corrected motor mount error/Moved T-case stuff to new post |
#106 | |
#107 |
WaAkFJ,
If you will send me a copy of the spreadsheet, I will try to host it somewhere for download so you won't have to email to God and everyone. michaeltweller@gmail.com |
#108 |
IH8MUD Junior Whopper
OK guys.. I have found the BEST PRICES EVER on metric / Hex Head / Grade 10.9 (YELLOW ZINC) Nuts and bolts, you will ever find.
And I will pass this onto my friends here on MUD... Example pricing... M6 x 1.00 x 20mm Grade 10.9 (yellow zinc) Hex Head $7.26 for qty 100 Locking Washers in grade 10.9 (yellow zinc) $3.19 for qty 100 Grade 10.9 Yellow zinc Nuts for 6mm x 1.00 $6.48 for qty 100 Thats only $16.93 for a complete set of 100 M6 Nuts bolts and L-washers. Compare that to the CHEAPEST I could find on the web price of 33.00 PLUS shipping, and you can see that this is a supreme deal... These are there in store prices. You would have to add shipping to this total. The name of the Company is Cascade Nuts and Bolts and there right here in Salem OR... Phone number is 888-511-1005 Your Welcome
__________________ Yahsoo! 1969 Breathe FJ40 Currently in the middle of a ground up... 1976 Olive FJ40 finished as of May 2008 Faster Track Resto
#109 | |
IH8MUD "I Live Here"
Nice, I wanna order right now, but I'm afraid of the shipping for the order I'll want. I'd like a set of 500 with locks, nuts. I'm working on several rigs and would like a stainless assortment. Thanks for sharing. |
#110 |
__________________ Chris Brandt PDX FJ40 BJ60 FZJ80 |
#111 | |
I will have this hosted when it is done. It is far from done
I have been really busy. I will send everyone who asked the excel sheet. Quote:
#112 |
IH8Mud4Life
4x4 Auto...
The kit did come in.. sorry tied up a bit and just getting back to puttin something in this thread.
It looks VERY light to me even for a "frame on" .. however, this is only opinion and Dan said to let him know if anything I found was missing. It's got some funky "nipple" nuts in here etc.. I'll let you know when we dive in it. Have a buddy that ordered one and he's using it. In all fairness to 4x4.. very nice folks easy to deal w/ and easy going. I'm a bit nervous bout the kit size.. but nothing but good things to say about them. ![]()
#113 |
it does look light. very light.
did they include the proper 12mm head bolts? it is ALL SS, right? if nothing else, it looks like a good start, and a descent box to store future purchases... |
#114 | |
IH8Mud4Life
"proper" being the key word there.. it appears so. All SS... Someone had to try it... hell it sounded tempting. ..we'll see and I'll be sure to let you know. Scott __________________ 1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag" - www.BSLCA.com - Good friends, a few cruisers, alot of laughs and a bunch of wives making this face --> "If I'm off (which is rare)... I'm in!" |
