#31 |
you got it, sending one your way on the big brown truck...
__________________ Front disc brakes: http://forum.ih8mud.com/showthread.p...+brake+dummies 1973 FJ40 - Finished! Vortec/NV4500/ARB's/SOA FJ40 ROTW: http://forum.ih8mud.com/showthread.p...uppie%27s+fj40 1970 FJ55 - Restoration Project in the works /2F/AC/PS FJ55 Restoration Thread: http://forum.ih8mud.com/40-55-series-tech/102079-guppies-fj55-build-thread.html |
#32 |
Bump
__________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
#33 |
so I ordered a boatload of bolts from mcmasster carr and let me say it is a VERY NICE thing to have an assortment of new bolts on hand. I was not concerned with JIS and the bolts are silver in color but plated for wear resistance. For a few items I will need to get the OEM bolts but overall I think this will save me mucho bucks in the long run. I basically used the reccomendations from this thread.
Noah __________________ Front disc brakes: http://forum.ih8mud.com/showthread.p...+brake+dummies 1973 FJ40 - Finished! Vortec/NV4500/ARB's/SOA FJ40 ROTW: http://forum.ih8mud.com/showthread.p...uppie%27s+fj40 1970 FJ55 - Restoration Project in the works /2F/AC/PS FJ55 Restoration Thread: http://forum.ih8mud.com/showthread.php?t=102079 |
#34 |
I spent a few hundred $$ on fasteners. Looking at what I took off, and looking at what is on the truck now....it was worth it.
#35 |
1973 Guppie
Are you keeping a list of nuts / bolts on your FJ55? I'd like to see how sizes compare. Plus I'll need a list of FJ55 bolts one day! I will hopefully get the bolt list updated in a couple of weeks with new sizes for alot of the bolts for the body. __________________ `·. , . .·´¯`·. , . .·´¯`·. , . .·´¯`· .·´¯`·..><((((º>`·.¸¸.·´¯`.¸.·´¯`·...¸ Last edited by WaAkFJ; 11-29-06 at 06:04 PM. |
#36 |
Guppie-------
Do you have a list of the ones you did end up ordering? How much did it cost you? Any pictures of what Mcmaster carr bolts look like Thanks |
#37 |
I have some additions for your list.
Battery tray to battery pedestal mount 4 8mm x 1.25 x 20mm split washer Battery pedestal to frame 4 8mm x 1.25 x 30mm split washer only Under Seat Tool Box Jack Holder Mount 2 6mm x 1.0x 16mm split washer + flat Trans Tunnel Bolts 16 6mm x 1.0 x 20mm split washer + flat Soft Top Tub Rail Rear Bow Bracket 4 6mm x 1.0 x 20mm split washer + flat Soft Top Wheel Well Bow Bracket 4 8mm 1.25 x 16mm Split washer + flat Rear Lift Gate Hinge Bolts 6 8 mm x 1.25 x 20mm split washer +flat Lift Gate Cross Member (ties hard top sides together) 4 8mm x 1.25 x 18mm split washer + flat (side bolts) 4 6mm x 1.0 x 16mm split washer + flat (top bolts) Lift gate support anchors to hard top sides 4 6mm x 1.0 x 16mm phillips head split washer + flat Fiberglass top to hard top side panels 24 6mm x 1.0 x 16mm Hard Top side panels to Tub rail 12 6mm x 1.0 x 20mm Fiberglass top door bows above front doors 8 6mm x 1.0 x 12mm phillips head split washer + flat That's all for tonight! __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 01-01-07 at 06:07 PM. |
#38 |
no pics, nothing fancy, they are just silver zinc plated, nice looking I think. I could not find the cadium plating so I went this route. They are not JIS heads either, but this was not important to me as much as others. I tend to do rebuilds nicely but not perfect restorations so not concerned about bolt details. I basically just took the reccomended bolt sizes from this thread and ordered a bunch of bolts, washers, lock washers, and nuts. I basically stuck to M6, M8 and M10. So far it has worked well for me. I don't plan to record every bolt size I use on the 55 rebuild as I am guessing that most of them should be similar sizes. I spent about $200 and got a boatload of hardware. Hope this helps.
#39 |
Thanks coolerman.... I'll put those into the first part ! !
__________________ `·. , . .·´¯`·. , . .·´¯`·. , . .·´¯`· .·´¯`·..><((((º>`·.¸¸.·´¯`.¸.·´¯`·...¸ |
#40 |
If you have that XLS spreadsheet started I would like to get a copy of it. I'm interested in seeing the totals for some of these bolts!
#41 |
IH8Mud4Life
I'm really interested in anything you guys have as I'm about to start down the restoration path after the Gilmer, Tx gathering.
I'll be glad to contribute to the list when we're done and thanks for your work making this list Scott __________________ 1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag" - www.BSLCA.com - Good friends, a few cruisers, alot of laughs and a bunch of wives making this face --> "If I'm off (which is rare)... I'm in!" |
#42 |
IH8MUD Junior Whopper
I have searched hi and low for the best deal on nuts and bolts, and believe I found the place.
http://www.allensfasteners.com/ Check it out... Here's an example for 10 pieces. $2.80 TOTAL. And shipping is cheap... (one price for 10 or 500, so the more you buy the cheaper) ALL STAINLESS 6mm- 1.00 X HEX HEAD (STAINLESS) 6mm-1.00 X 20 HEX CS (SS) $0.17 x10= $1.70 METRIC STAINLESS LOCK WASHER M6 (STAINLESS) LOCK WASHER $0.06 x10= $0.60 METRIC STAINLESS FLAT WASHER M6 (STAINLESS) FLAT WASHER $0.05 x10= $0.50 __________________ Yahsoo! 1969 Breathe FJ40 Currently in the middle of a ground up... 1976 Olive FJ40 finished as of May 2008 Faster Track Resto
#43 |
WOW, great work.
id like a copy of the spread sheet if you dont mind. alaskanherbs@yahoo.com thanks, herb __________________ Eat drink and be merry, for tomorrow we die. Cheers |
#44 |
OK here is two list of bolts from the Allen Fastener place posted by thecrazygreek.
Stainless Vs Zinc. Bottom line: For the amount listed there is only $63.50 difference between them! I have an email into them asking if these are JIS. I don't think they will be. Bolts Size x pitch x length $(SS) $(Zinc) Qty 6mm x 1.0 x 10mm .12 .07 50 6mm x 1.0 x 20mm .17 .11 100 6mm x 1.0 x 25mm .17 .12 50 8mm x 1.25 x 16mm .24 .31 50 8mm x 1.25 x 20mm .25 .35 100 8mm x 1.25 x 25mm .28 .36 150 8mm x 1.25 x 30mm .29 .37 50 8mm x 1.25 x 35mm .30 .48 100 Flat Washers Size $(SS) $(Zinc) Qty 6mm .05 .02 200 8mm .08 .03 450 10mm .14 .05 75 12mm .22 .08 25 Lock Washers Size $(SS) $(Zinc) Qty 6mm .06 .02 200 8mm .12 .03 450 10mm .18 .06 75 12mm .22 .07 25 Total for all Stainless = $302 Total for all Zinc = $238.50 Not bad for 2150 pieces! Great find there `thecrazygreek!
__________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 12-05-06 at 05:49 PM. |
#45 |
Its thecrazyGREEK!!!
NOT GEEK!!!
hehe... I still havent found a better deal anywhere on the net. And to top it off, they are quick to ship, and quality seems to be top notch.
#46 |
Just a question about Zinc vs. stainless. Is there a difference in the strength of the bolt due to the difference in alloy? Any metalurgists out there?
__________________ 1971 Freeborn Red FJ40 (sold) 1978 Mustard FJ40 2001 Silver Tundra 4WD 2000 BMW Z3 1998 Honda Accord XT225 Yamaha |
#47 | |
pardon me! Guess I need to get better bi-focals? I have fixed the post!I'm placing an order tomorrow. I'm tired of all the searching and don't think anyone will best that price soon. __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 12-05-06 at 05:50 PM. |
#48 |
Yes there is, the zinc bolts are stronger and should be used where critical strength is an issue.
#49 |
I didn't see a listing for the bolts to hook the engine to the engine stand.
They are 12X1.75 80 - 100 mm, depending on the configuration of your stand. Also, they should be hardened, not your standard off the shelf bolt. |
#50 |
Few more I got tonight:
Dimmer switch mount (2) 6 x 1.0 x 12mm split +flat washer Flasher Relay mounting bolts (2) 6 x 1.0 x 16mm split +flat washer Fuse Block mounting bolts (2) 6 x 1.0 x 12mm split washer only Gas Pedal mounting bolts (2) 6 x 1.0 x 16mm split washer only +12V Power Outlet mounting screws (2) 4mm x .7 x 10mm phillips head screw w/internal toothed washer __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 12-07-06 at 08:07 AM. |
#51 |
Couple more from last nights work.
Passenger side Engine Lift Hook/ 2F Alternator bracket mounting bolts (3) 10mm x 1.25 x 30mm split plus flat washers 14mm head if JIS but 17mm fits with no clearance problems Carb Cable retainer on firewall (2) 6mm x 1.0 x 20mm split washer only __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 01-14-07 at 11:02 AM. |
#52 |
Few more from yesterday.
Steering Column to dash mounting bolts 2 8mm X 1.25 X 30mm Captured flat washer Glove Box Door GearShift Plate 4 3mm X 0.5mm X 8mm Split,Flat + 5.5mm nut Glove Box to Dash Mounting Screw 3 5mm X 10mm Sheet metal screws Split, FLat Glove Box Limit strap (wire) rope) Mounting 2 5mm X 0.8mm X 10mm split only + 8mm nut Glove Box Knob 1 4mm X 0.7mm X 20mm Molded in stud Split, flat + 7mm nut Brake Pedal Pivot Bolt 1 10mm X 1.25 X 80mm with 60mm shoulder. Bolt is .485 diameter 12mm head Clutch Pedal Pivot Bolt 1 10mm X 1.25 X 80mm with 60mm shoulder. Bolt is .485 diameter 12mm head Brake/Clutch Pedal Pivot Sleeve 1 0.510 outside diameter X 1.975 length Inside diameter= 0.397 Brake/Clutch Pedal Nylon Bearing 2 ea Cowl Vent lift sleeve anchor screws 4 6mm X 1.0 X 12mm Split, Flat Phillips Head Cowl Vent Door mount Nuts 2 4mm X 0.7mm X NA 7mm nut size Radiator U Frame to cross member Nuts 2 8mm X 1.25mm X 25mm studs welded to bottom 2 nuts 14mm heads Split, flat Fan Shroud to Radiator U Frame bolts 6 8mm X 1.25 X 20 mm Split, Flat captured Radiator U Frame top Cross member bolts 2 8mm X 1.25mm X 20 mm Split, Flat Small front shroud to Radiator U Frame screws 6 5mm X 0.8mm X 10mm Split Only Phillips screw Bib Hinge Mounting Bolts 2 8mm X 1.25mm X 30mm Shoulder = 15mm Split, Flat. 12mm bolt head That's all for now... __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 01-02-07 at 08:54 AM. |
#53 |
IH8Mud4Life
Thanks CM.. .all this much appreciated. I have to do some ordering soon so I need to go back to Melissa's excel file.
I think she mentioned a place (maybe on this thread..I'll have to check) that charged no shipping????!!!! If so.. wonder if there is a limit to weight... b/c I'm gonna give them one, very large, order. Much appreciated. Scott __________________ 1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag" - www.BSLCA.com - Good friends, a few cruisers, alot of laughs and a bunch of wives making this face --> "If I'm off (which is rare)... I'm in!" |
#54 |
Bump
Come on folks lets finish this! Remember we need ALL the information about the fastener! Use metric! Year and model of truck # used thread diameter (3, 4, 5, 5.5, 6, 7, 8, 10, 12mm) thread pitch (0.5, 0.7, 1.0, 1.25, 1.5, 1.75mm) total length of bolt (8-100mm) length of shoulder (no thread area) if bolt has one washers used (split,flat, internal toothed) Head diameter (wrench size) if larger head will fit say so. That way one knows if a non JIS bolt will work nut size (wrench size) if nut used By the way the US is one of only 5 countries in the world that still use English measurments! NASA recently stated that an international commitee has declared that any future mission or base on the MOON be metric. Land Cruiser Moon Buggy?
__________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) Last edited by Coolerman; 01-29-07 at 04:15 AM. |
#55 |
