elder statesman
intake manifold variations (FAQ)
The question was posed in a separate thread, but I thought it would be easier to find this info later if it was posted directly on topic in it's own thread.
58-9/66: F135 Engine [3.9 liter] 1bbl cast iron intake standard, 2bbl optional. 4 bolt attachment to exhaust manifold 9/66-9/69: F145 Engine[3.9 liter] 2bbl aluminum intake with wide runners standard. 3bolt attachment to exhaust. 4 bolt bosses on the side of the intake for oil filter bracket, which attached via an adapter plate. 10/69-1/72: F145 Engine[3.9 liter] 2bbl intake with narrow runners. 69 and 70 models had one vacuum port only, for the 4wd shifter. 71 had one port on the side for the brake booster. 72 added a second one in front of the carb for filtered manifold vacuum. 1/72-12/74: F155 Engine[ 3.9 liter] 2bbl intake with narrow runners. 74 Cali intake is distinguishable because there is a large hole in the side of the intake under the carb for the Cali-spec EGR system. 1/75-1/79: 2F [4.2 liter] 2bbl intake with 5 bolt attachement to exhaust. Port behind carb for brake booster, port under carb for PCV, port in front of carb for filtered vacuum source. 1/79-9/87 2F [4.2 liter] 2bbl aluminum intake with 5 bolt attachment to exhaust. Main distinction from earlier 2F intakes is that EGR ports into the side of the intake underneath the carb, alongside the PCV system. __________________ A carbureted man in a fuel injected world. 65SWB45, 64LWB45, 68FJ40,72V840, 76HJ45[going],84FJ60[gone], 76K5, 73Sub454, 89Sub7.4[gone], 97Sub5.7 TLCA delegate, Trail Crew-LAC TLCA, The White Trash of the Elwood Chapter my website: http://www.marksoffroad.net |
elder statesman
WOW! My first FAQ on MUD. I'm somebody now!
good info Mark
thanks __________________ TLCA #14752, L.A. Trail Crew http://www.marksoffroad.net My Parts Source "Our election is in 40 days, our economy is in crisis, and our nation is fighting two wars abroad. ... The American people, I believe, deserve to hear directly from myself and Sen. McCain about how do we intend to lead our country," Obama said |
#5 | |
springfield user
yes, but nobody will ever see it as it seems nobody uses the faq.
__________________ it's only metal, we can out think it. 77-fj40 20th anniversary edition 87-fj60 216K mile DDer 93-fzj80 mall crawler toyota material distribution center. your source for Factory Service Manuals. they're alot cheaper than you think. 1-800-622-2033 |
#6 | |
elder statesman
I have a 66-69 with the wide runners and a 72 with the narrow runners. Both have all the vacuum ports I need.
I am running SOR headers, along with a Holley 350 carb. Is there any preference for the narrow vs wide runners for air/fuel flow on the intake side? I've been running the intake with the wide runners for 2 years on a 77 2F engine. |
elder statesman
Well, at first glance, a Holley 350 would seem to suggest that you are motivated by a need for speed!
Rather than just making the assumption, I'll offer this. The narrower runner manifolds are going to keep manifold vacuum higher at lower rpms, but become somewhat restrictive at high rpms. The wider manifold isn't gonna have quite as much vacuum at the lower rpms, but will obviously move more air for higher rpm operation. I use the narrower manifold on my '68, which is pretty well built. I notice a little drop off in power above 4000 rpm because of the manifold. But I get in that RPM range so seldom, I can more than live with the trade off; I like the higher vacuum and torque at slow speed that the 'smaller' manifold gives. Hth Mark A. __________________ A carbureted man in a fuel injected world. 65SWB45, 64LWB45, 68FJ40,72V840, 76HJ45[going],84FJ60[gone], 76K5, 73Sub454, 89Sub7.4[gone], 97Sub5.7 TLCA delegate, Trail Crew-LAC TLCA, The White Trash of the Elwood Chapter my website: http://www.marksoffroad.net Last edited by 65swb45; 12-29-06 at 09:27 PM. |
#11 |
I've been having the same argument with myself. I actually have the Holley with a 2 stage power valve for high altitude performance, not necessarily for speed, though it does provide that also. In fact, I put in a Downey cam for more mid-range/low-range torque. I have the engine balanced, so 3,400 - 3,600 or more rpm is not a problem, but I rarely am above 3,200 rpm.
I'ts a daily driver, but also gets some serious offroad work in rough country at 10000 ft elevation when I'm hunting elk. Based upon your observations, I think I'll try the narrow runner intake, at least for now. I've had the wide one on for two years, so I know what it does. Thanks, Mark. |
#12 |
Noaccount Webwheeler
Thought I'd add a couple of pics. The top one is a 9/66-9/69 wide runner intake and the bottom one is, uh later, I guess? EDIT: I meant the wide runner is on the RIGHT!
Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#13 |
That's cool that the wide runner has the firing order stamped into it.
__________________ 9/70 FJ40 +Rollbar 9/64 FJ45 (L) P-B with restored wiring 4/84 Toy 4x4 Mini PU "The hungry sheep look up, and are not fed: but, swol'n with wind, and the rank mist they draw, rot inwardly and foul contagion spread."--Milton |
#14 |
In the first pic you can see how deep the sparation of the runners actually is. The side view shows the relative thickness of the two.
IDave.......like you need the firing order stamped on the intake. Shit, that's on the wrong side of the motor! What good would that do?!?!?!?! ![]() AFAIK, the firing order of all 6 cylinder motors is the same. At least the Toyota F/2F is the same as my BMW. Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#15 |
#16 |
will any of these fit a 3fe?
__________________ 82 Fj60 TurkeyWizz THXAL 88 BJ62 Family Truckster http://nfcruiserheads.org/forum/index.php |
#17 |
Sorry, but I know nothing about 3FEs Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#18 |
__________________ For Sale: Parachute. Only used once, never opened, small stain. Last edited by grant5127; 02-28-07 at 09:35 PM. |
#20 |
So you can not use a carb intake on a 3fe block?
I want to ditch the efi __________________ 82 Fj60 TurkeyWizz THXAL 88 BJ62 Family Truckster http://nfcruiserheads.org/forum/index.php |
#22 |
Another difference to be noted is the spacing on a 1F versus 2F manifold for aircleaner placement.
I have a F155 engine. I had changed the valve cover over to a aluminum cover. I was running a Holley but decided to change back over to an Aisan carb. I sourced a 1977 carb and matching aircleaner. The carbs will all swap. I assumed the aircleaner would bolt right up also. However the spacing of the intake is different. I had to move the aircleaner assembly away from the carb, and drop it down in order for the aircleaner and airhorn to mate up. I made custom brackets for the mounts to the valve cover and simply shimmed the large mount to the head on the distributor side of the engine. I also had to enlarge the depressions on the under side of the cleaner to clear the valve cover nuts. I assume the 1F's had a similar spacing. But the distance from the block and height of the carb difinetely changed for the 2F's. I also have noticed the visible difference of the air cleaner in a FJ-60, compared to the 77 model and the possiblity that the dimensions of the later 2F's may be different. Does anyone know? __________________ 1996 T100, Stock, new to me, cool truck 1973 FJ-40, Stock, Restored, Ehsan top coming soon ![]() 1984 FJ-60, Stock, 221,000+miles ![]() 2002 Subaru Forester L, for the wifey
#23 |
I sold the electronics from my project 62, leaving me a 3fe short block. Now that I think about it....... My question should have been will a 2f head bolt on to the 3fe block. Then any 2f intake would work. The reason for the question is because I know where there is a 66 fj40 that needs an engine rebuild. I was considering using the 3fe long block with a 2f intake/ carb in the 66 instead of rebuilding the f in there now. It is just a matter of putting what I have to use. __________________ 82 Fj60 TurkeyWizz THXAL 88 BJ62 Family Truckster http://nfcruiserheads.org/forum/index.php |
#24 | |
It would have bolted right up if you had used a 2F intake. I did the same thing on my F155. But you figured out a way to make it work anyway. More than one way to skin a PitBull, eh? Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#25 | |
If you don't have the EFI, a 2F is a better motor than a 3F. 2F head will bolt onto a 3F bolck. Make sure you use a closed chamber head or you compression wil suffer. Mark... |
#26 |
Are there any fitment issues with the wide runner manifold and your average F/2F header?
I've been wondering for a while. __________________ Clean your filthy Wok! 1969 fj55 1977 fj55 1981 Toy 4x4 Pickup 2007 Tacoma TeRD Nourishing Earth Body Care and Candle Company |
