Old 12-29-05, 02:08 PM   #1 (permalink)
Gas Struts for rear lift gate on '73 - I FIGURED IT OUT!!!!!
Saw some on eBay, but was outbid ($50). Where do you get 'em? Or does anybody have the specs so that I can order some?
cooney is offline   Reply With Quote
Old 12-29-05, 10:10 PM   #2 (permalink)
HawkDriver's Avatar
TLCA# 15861
I think that they are pretty generic and you should be able to find someone who sells em online.
Not much help.
Forty kind of guy with a Hundy
HawkDriver is offline   Reply With Quote
Old 12-30-05, 04:20 AM   #3 (permalink)
honk's Avatar
Not really sure what you're asking about. The rear lift up door on cruisers before '75 (?) had a chromed spring lift strut to hold the upper door up when open, not a gas strut.
I DID change the chromed spring things on our '65 out for gas struts though, and all I did was take the extended length measurement and go to Napa to pick up a pair off their generic replacement rack that extend to the same length. They had a bunch of sizes that went for something like $17. to $30. each.
I needed to do some adaptation of holes and pins but the things work great now. I even painted their little black tubes Freeborn Red to match.
Specialization is for insects
'77 BJ40 FST;'77 FJ40; '65 FJ40;
honk is offline   Reply With Quote
Old 12-30-05, 08:20 AM   #4 (permalink)
Yeah, my thoughts were to replaced the chromed spring lift struts for ease of use. I figured the gas shocks would be easier than having to tighten the original springs every time I lift the rear hatch. I will pull one of the springs off and try the Napa route.
I did a google search and found several companies that you can special order the gas shocks the exact length and size you want. You can even pick from about 20 different ends. The only thing is that you have to do some calculations to specify the spring you want. The perpindicular distance from the hinge point, the weight of the gate, the distance from shock mounting point to the center of gravity, etc...
You would think that SOR, CCOT, etc... would sell these things with the right ends and length. Am I the only one who would buy a pair?
Old 12-30-05, 08:25 AM   #5 (permalink)
Check www.mcmaster.com as well. There a bunch of lengths and sizes to chose from.
Brad
73 FJ40 - 78 2F/SM420
North GA
73lndcrsr is offline   Reply With Quote
Old 12-30-05, 10:06 AM   #6 (permalink)
honk's Avatar
Yeah, you'd think so considering the unavailability of the OEM type.
Although I knew that there were several factors involved I didn't bother with any of that when I did the change. I think that the hatch on our '65 may not go up as high as it did, but it's close, and I could bump my head on it either way. My wife neatly avoids such contact and the cruiser was/is mostly for her anyway.
Old 12-30-05, 10:11 AM   #7 (permalink)
Shawn Russell's Avatar
I have read there is a Toyota replacement for the spring type. They are said to be gas filled. I will see if I can find the part number, however, they are not cheep.
65 V8J45 SWB, 70 V8J40
Shawn Russell is offline   Reply With Quote
Old 12-30-05, 10:29 AM   #8 (permalink)
Here is what I found:
"Toyota has begun making gas charged supports for the
lift gate! They aren't cheap ($188 a piece), but I
could have bought 10 sets for what I paid for my
hospital stay for the stitches. So I bought a pair.
Preventative matinence, so to speak...
The Toyota part numbers are as follows:
Right side - 68930-90300
Left side - 68940-90300"
I do not know if this is correct, but something to check out.
Old 12-30-05, 11:30 AM   #9 (permalink)
Thanks. I'm gonna check it out. If I happen to find a good (cheaper) alternative that seems to be of equal quality to the factory part I'll let ya'll know.
Maybe we could post it in the tech section.
Old 01-13-06, 07:25 PM   #10 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Garage
What have you found out?
This is now in the F A Q
Old 01-13-06, 07:31 PM   #11 (permalink)
cabron's Avatar
also a thread in the 80 forum
1974 Toyota FJ40 (sold Jan 27)
1985 Toyota FJ60 two-tone, Safari Rack, OME Heavy,33x9.5's, custom front/rear bumpers, fully sound deadened, Alpine H/U, Rainbow components, dual v12 amps, 12" Type_R, Mot's Lights.
cabron is offline   Reply With Quote
Old 01-13-06, 07:41 PM   #12 (permalink)
Poser's Avatar
TLCA# 1856
Garage
On the 40 series?
Linky?
Old 04-03-06, 10:13 AM   #13 (permalink)
Gas lift gate shocks for 40 - I fugured it out!!!!
Well, I searched for a while, tried a few different shocks and finally figured out a solution. I wanted to keep the stock look so I found some gas shocks that fit inside the original lift gate arms. Just remove the original arms, remove the inner springs and misc. hardware and insert the new shocks. Worked like a charm. I shimmed a little on one end to lift the gate about a half inch farther but that was it. I now just pull the handle and watch the gate lift. No more twisting to lock in place! No more wondering if it's gonna come loose and knock me out! No more wrestling to unscrew the gate once lifted! Problem solved!! I'll try to get some pics posted.
Oh yeah, NAPA part#819-5565
Old 04-03-06, 02:09 PM   #14 (permalink)
Coolerman's Avatar
TLCA# 13645
Damn cooney! Now that was a hell of an idea! I have added that to my list of things to get. Just this weekend my large cat jumped onto the raised hatch from a higher point and collasped it on my head... The springs in mine are simply not there and yes I had the nut tight... Yeah, yeah, laugh if you must but I had a welder in my hand at the time and after getting my heart under control started considering welding the cat to the nut on the arm!
!Oy my 1971 FJ40
It's not having what you want, it's wanting what you got...
http://tinyurl.com/ygeqfp7 FJ40 Wiring Parts for Sale
http://tinyurl.com/mxj5ve Misc Parts FOR SALE!
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 04-03-06, 03:22 PM   #15 (permalink)
Thanks. It just worked out beautifully. What can I say?
The guys at NAPA were kinda pissed after all the returns but I finally got it right.
Old 04-04-06, 06:21 AM   #16 (permalink)
I just checked out your website and all I can say is DAMN!!! Keep up the good work. I definitely want a copy on CD when you get to that point. I will be following along in the meantime. I had intentions of a 40 that I would repair while driving because of budget limitations, but I happened to find one within my budget that didn't need a lot of repairs. Don't get me wrong, I'm not complaining. It's just the work you're doing looks like fun in a wierd sort of way. A little overwhelming, but fun.
Old 04-06-06, 07:12 PM   #17 (permalink)
Coolerman's Avatar
TLCA# 13645
Ooops missed your reply somehow! Thanks for the compliments on the site. I'm still about two months away from being able to daily drive it. My work just does not allow a lot of spare time to work on it. I picked up my cargo floor today from a local sheet metal shop and after I return from a Florida trip next week hope to finish the wheel wells and floor.
!Oy my 1971 FJ40
Old 04-15-06, 08:55 PM   #18 (permalink)
I replaced mine about 2 years ago, i got them off of my parents 1986 crysler lebaron 4dr. they came of the rear hatch and they were almost the perfect length, maybe 1/2 inch too long when fully extended but they bolted right into the same location. It also holds the door up higher than the original arms which helps me from hitting my head
Wyofj40 is offline   Reply With Quote
Old 06-29-06, 11:24 AM   #19 (permalink)
mdjohnsen's Avatar
http://www.napaonline.com/MasterPage...al+Gas+Charged
mdjohnsen is offline   Reply With Quote
Old 06-29-06, 11:46 AM   #20 (permalink)
jrfj40's Avatar
TLCA# 16396
Mdjohnsen
are these what you used?
any other fab to do or just relace?
1972 FJ40
TLCA #16396
"you can run all your life and never go anywhere"
jrfj40 is offline   Reply With Quote
Old 12-18-08, 04:54 PM   #21 (permalink)
TLCA# 18958
I know this is an old thread but is there any update on the gas struts mentioned above?
Thanks,
Flash
Flash1034 is offline   Reply With Quote
Old 01-17-09, 11:50 AM   #22 (permalink)
hill's Avatar
lets see some pics...
1997 FZJ80 - Supercharged w/ F&R lockers, 285/75r16, ARB w/ Warn9000, 2.5" Slee Lift
1973 FJ40 - Soft top, 2" lift, 33x10.5 BFG, Pwr Str, H4 Lights, Warn 9000
Calgary, Alberta Canada
hill is offline   Reply With Quote
Old 01-17-09, 07:13 PM   #23 (permalink)
Ball & Claw Club
Dusty 66's Avatar
X2
66 FJ40L Soft Top Done ,2006 FJ Cruiser 6 speed ! 1978 FJ55 next project,
and use to have a couple others' 1971 FJ40 , 1977 FJ40, 1984 FJ60 , 1994 FZJ80
Dusty 66 is offline   Reply With Quote
Old 01-17-09, 10:21 PM   #24 (permalink)
TLCA# 18958
I have the two old stock spring lift units from my 72 FJ40. They are used but in pretty good shape if anyone would like to buy them at a fair price. I know they are next to impossible to find.
Flash
