11-22-05, 08:53 PM
| | Oh...Durka Durka Durka.
| OEM back-up lamp... Post up a pic on your PRE 09/73 40 series please...
THANKS!
-Steve
__________________ |
11-22-05, 08:58 PM
| | Forum Regular
11-22-05, 09:08 PM
| | Forum Lifer
| Lemme know if you want a better closeup of mine than the one in the thread Les linked, Steve.
__________________ 9/70 FJ40
9/64 FJ45 (L) P-B
4/84 Toy 4x4 Mini PU
We do not see things as they are;
We see things as we are. --Talmud |
11-22-05, 09:36 PM
| | Forum Lifer
| I can't post a picture until next week, but I have one or so packed away for my 73. I don't keep them on the back of the vehicle since someone broke the lens on one while sitting in my driveway. I picked one up off of Ebay a while back, was listed as a fog light.
I just reread your post did you want any early backup light or the 73's which were larger then the 68-72 ones?
John |
11-22-05, 09:38 PM
| Reason for thread was I have a 02/73 40 series in the shop right now that has what looks like a fog/spot lamp that is significantly larger than what was posted up in this thread...It is a Toyota piece, seems to use a similar mounting gasket to the body as the smaller one, but is the size of a large rectangle fog lamp.
I know, I know, worthless without pics....
I am a tard when it comes to the 'puter..
-Steve
11-22-05, 09:41 PM
| | Forum Lifer
| That was the stock backup light on the 73 model year only.
John |
11-22-05, 09:55 PM
| Quote: |
Originally Posted by Living in the Past That was the stock backup light on the 73 model year only.
John |
I have parted out two '73's that had the small style....Feb and Apr...
11-22-05, 10:13 PM
| | Forum Lifer
| Check the tread on Ground Up's restro. That is what was on my 73 and on one I picked up off a 73 in a junk yard years ago. Since you can no longer get the larger one and they are easier to break since they stick out, as for the ones you parted out it wouldn't surpise me if they were replaced with what they could find. The opening in the tub is the same.
John |
11-22-05, 10:22 PM
| Kinda what I figured....
11-22-05, 10:45 PM
#10 (permalink)
| | not an addict
| sorry i can't get a better pic...backed it up a little too close to the fence
__________________ "to learn is to teach someone else"
only four cruisers left |
11-22-05, 10:54 PM
#11 (permalink)
| that would be it!
thanks Ige!
11-22-05, 11:01 PM
#12 (permalink)
| | 250+ Club
Join Date: Jun 2004 Location: Northern New Mexico, Espanola
| Here is the light on my 73 (11/72 build date).
Vince
__________________ 1995 FZJ80 Moonglow Pearl, ARB FR, Slee rear, 305/70/16 Toyo's and full length roof rack.
1973 FJ40 2F, mud sticker and soft top
2009 VW JETTA TDI
ا |
11-23-05, 11:10 AM
#13 (permalink)
| | 250+ Club
| I have one like that on my 9/72 also. I I thought it was aftermarket. Still in pretty good shape.
__________________ FJ-4.3 1973 FJ40 was frame off, got a 4.3 CFi/4L60E/NP-205 and FJ-62 power steering. SOA, 35x12.50 MT/Rs, FJ62 FDB. Brought back from the grave(traded a shotgun for it, if that tells you anything). Turning out to be a sick 40!!
Buildup Thread: ALMOST DONE!!!!! http://forum.ih8mud.com/40-55-series...up-thread.html Sanity is over-rated!! |
11-23-05, 11:14 AM
#14 (permalink)
| | Where are my keys?!
| Marc's '73 restoration has one... 1973 Restoration
11-23-05, 11:26 AM
#15 (permalink)
| | 250+ Club
| another Here is mine
__________________ 1984 FJ60 stock except for 33/10.5/15 BFG MT
Learning is everything and everything is learning.
11-23-05, 11:51 AM
#16 (permalink)
| | Forum Lifer
| So did all the 73s have the tie down loops on the back corners? Even the hard tops?  Seems most of the ones I picked up in junk yards were from 72s and 73s. How about the blower motor switches, only year they were marked front and rear.  That's a big help for us old guys who can't remember which is which.  There is a few things on the 73s that were a one year only. On the dash is there a light on the right side of the glove box? Seems I seen this on both hard and soft tops.
John |
11-23-05, 12:00 PM
#17 (permalink)
| | Forum Lifer
| My 09/73 is the same as above. What, did they change in 10/73? |
11-23-05, 12:06 PM
#18 (permalink)
| | Forum Lifer
| Tail/brake/ turn/ backup lights were the same as the later models. Three lenses glued together mounted on the rear crossmember.
John |
11-27-05, 11:59 PM
#19 (permalink)
| | elder statesman
| Quote: |
Originally Posted by Living in the Past So did all the 73s have the tie down loops on the back corners? Even the hard tops?  Seems most of the ones I picked up in junk yards were from 72s and 73s. How about the blower motor switches, only year they were marked front and rear.  That's a big help for us old guys who can't remember which is which.  There is a few things on the 73s that were a one year only. On the dash is there a light on the right side of the glove box? Seems I seen this on both hard and soft tops.
John | John, IIRC that light on the side of the glovebox was standard issues for several years of soft top model, but only 1971 in the hardtop model. I also think IIRC that those footman loops were standard issue on both 73 and 74 models.
__________________ A carbureted man in a fuel injected world.
65SWB45, 64LWB45, 68FJ40, 69FJ40, 72VJ40, 76HJ45[gone],84FJ60[gone], 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
TLCA member, The White Trash Of The Elwood chapter
my website: http://www.marksoffroad.net IT'S FASTER if you CALL ME! |
11-28-05, 11:10 AM
#20 (permalink)
| | Forum Lifer
| Quote: |
Originally Posted by 65swb45 John, IIRC that light on the side of the glovebox was standard issues for several years of soft top model, but only 1971 in the hardtop model. I also think IIRC that those footman loops were standard issue on both 73 and 74 models. | So my 2/71 with the light on the side of the glove box could have originally been a hard or soft top? The PO MAY have removed the footman loops as I do not have them. I also have the drop down tail gate. What other clues tell me what top it had from the factory? |
