Go Back   IH8MUD Forums > Toyota Tech Forums > 40- & 55-Series Tech
Old 11-04-05, 01:57 PM   #1
74fj40's Avatar
pilot bearing removal...
ok been trying all morning to get this damn bearing out. weve tried the "hydrolic" method, filling the cavity up with grease and sticcking a dowel in the whole and whackin it. it work, but it took the front of the bearing off the rest is still in the crank. treid using the wall anchor, it just broke off so now its stuck behind bearing. weve tried heating it up didnt work. what other options are there?
So PLEEAASSEE HELP!!!!
Max Parkinson
72' FJ40-4" lift, FJ60 axles, FJ60 4speed with split case, 35's, detroit locker, 96"WB, saginaw with GM tilt column. badass.
74fj40 is offline   Reply With Quote
Old 11-04-05, 02:03 PM   #2
wesintl's Avatar
TLCA# 4180
LOL.. Sorry to hear that. Maybe PM perry (bh4rnnr?) and see if he has a snap on pilot bearing remover he could stop by and pop it out in a min or two..
forgot it's a teacher workday
carfully cut out with dremel?
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Old 11-04-05, 02:22 PM   #3
wesintl's Avatar
TLCA# 4180
call around and see if checker or someone rents one.. could always buy a cheap one from napa etc.
Rising Sun
; Former CLCC
Old 11-04-05, 02:57 PM   #4
mel lowe's Avatar
pilot removal
max,
trust me on this one.......
I tried for hrs using 2 different pullers w/o sucess (one was a SNAP ON)
here is how to get it out in 3 minutes using hydralic (sp) pressure:
1. get out your grease gun and hose
2. FILL cavity behind pilot bearing with grease
3. make tool from old bolt and electrical tape
4. place bolt into pilot bearing (must be sealed all the way around)
5. using hammer bang bolt one good time into old pilot
6. the grease will push out the bearing
you will get it out this way
mine came out 2nd try
THE key is having a bolt almost as big as the pilot bearing and a good seal with
the electrical tape. I wrapped more tape on the end to create a tapper.
good luck!!!!!
"if the asparagus is over 4 inches in height then you have to go for the broccoli spring over roll with oppressive shackle reversal" - PhilC64
mel lowe is offline   Reply With Quote
Old 11-04-05, 02:58 PM   #5
mel lowe's Avatar
if you need a pic of the tool lemme know
mel
Old 11-04-05, 03:01 PM   #6
camcruiser13's Avatar
i thought he tried that method already/ get a dremel and cut the sucker
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
Old 11-04-05, 03:20 PM   #7
mel lowe's Avatar
oops only read title not content of post
sorry max
Old 11-04-05, 03:27 PM   #8
oldman's Avatar
TLCA# 3156
I have had mixed success with teh hydraulic method. I finally said th ehell with it and bought a puller. They pop right out and there's no greasy mess!
oldman is offline   Reply With Quote
Old 11-05-05, 03:48 PM   #9
74fj40's Avatar
Pilot bearing.....
...DONE!!!!!
we finnaly just said screw it. and started drilling the hell out of it and took the dremel to it. and finally it came out. also got the new one installed
Max Parkinson
Old 11-05-05, 03:51 PM   #10
wesintl's Avatar
TLCA# 4180
Glad you got that sucker out... They can be a PITA. Easier now than later on
Rising Sun
; Former CLCC
Old 11-05-05, 07:09 PM   #11
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
slide hammer with special ground attachment just for this...works great.
glad you got it.
Old 11-05-05, 10:29 PM   #12
Cruiserdrew's Avatar
TLCA# 11734
I bought a pilot bearing puller from Harbor Freight. It's too big. If you carefully grind the business end to just fit inside the bearing, it pops it out with NO EFFORT. I'm about to mail my modified tool to Toadhopper to use in his H55 install.
Andrew
1984 FJ-60 H55f, 4.11, Now SOA!
1997 FZJ-80 Driveway queen
Old 11-05-05, 10:52 PM   #13
Ramblin Wreck
CruisinGA's Avatar
Two ways have worked flawlessly for me-
What Poser said, and,
a carraige bolt ground to "hook" the bearing, and a large socket and apropriate nut.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'97 FZJ80
'98 UZJ100-OEM RR locker
ΣΧ
CruisinGA is offline   Reply With Quote
Old 11-06-05, 12:43 AM   #14
Pin_Head's Avatar
The 39 cent carriage bolt puller gets most of them out before you can even start wiping all the grease off of your face.
A carbide burr in a pneumatic die grinder will cut through the race fast if it resists all other methods.
Pin_Head is offline   Reply With Quote
Old 11-06-05, 08:31 AM   #15
IDave's Avatar
TLCA# 13705
So, how do the socket, nut and bolt combine to pull the bearing, exactly? A picture would be great!
9/70 FJ40 +Rollbar
9/64 FJ45 (L) P-B with restored wiring
4/84 Toy 4x4 Mini PU
"The hungry sheep look up, and are not fed: but, swol'n with wind, and the rank mist they draw, rot inwardly and foul contagion spread."--Milton
IDave is offline   Reply With Quote
Old 01-18-06, 07:19 PM   #16
Poser's Avatar
TLCA# 1856
Dave-
Sorry no pic..
Insert modified puller bolt, pass socket larger than the OD of the bearing over the threaded section, if you need a washer put one on, and then the nut. Tighten the nut against the socket, and it will pull the bearing out.
I have not used this method, as I have a different tool for this, but it should work fine.
Old 01-18-06, 07:32 PM   #17
It's crazy, I thought I was the only one with this problem.
khaugland is offline   Reply With Quote
Old 01-18-06, 08:03 PM   #18
IDave's Avatar
TLCA# 13705
Originally Posted by Poser
Dave-
Sorry no pic..
I got it.
9/70 FJ40 +Rollbar
Old 03-24-06, 03:11 PM   #19
when all else fails, put a rim of weld around the inside diameter of the bearing being careful not to weld the bearing in. the weld will make the bearing contract allowing one of the above methods to pull it out. do not do this if there is grease in the crank end unless you want super hot grease splatter in your face
cruiserdoc is offline   Reply With Quote
Old 03-24-06, 08:29 PM   #20
mel lowe's Avatar
I wore gloves and made lil to no mess
No grease in the face only the cavity, which wiped clean
Old 03-24-06, 08:56 PM   #21
ranger's Avatar
This method has worked flawlessly many times over. The hydraulic method was hit and miss, and was usually another mess to clean up!
ranger is offline   Reply With Quote
Old 03-24-06, 10:25 PM   #22
Ian Rogers's Avatar
TLCA# 14752
x2 pin head is the man with this one
TLCA #14752, L.A. Trail Crew
http://www.marksoffroad.net My Parts Source
"nothing pairs better with a bottle of Merlot than an honest workout digging in the sand and my shovel is always ready, lol" PKP80 thoughts on Surf and Turf
Ian Rogers is offline   Reply With Quote
Old 07-02-06, 03:03 PM   #23
wesintl's Avatar
TLCA# 4180
I just like to say I used the carrige bolt method on a VERY pesky pilot bearing and it got it out. It took several passes to get it out but it did what a pilot bearing rental tool couldn't
Thanks again for the tip. now on to rebuilding my 3 speed tranny
Rising Sun
; Former CLCC
Old 12-02-06, 10:14 AM   #24
SHREG's Avatar
I spent about 30 min this morning trying to get that blasted pilot bearing out. a quick search on mud saved me a ton of frustration...... .73 cents later and I had my Mud-Pilot bearing puller...
Mud search = FREE
Long bolt washer and nut.... .73
5 min removal of pesky pilot bearing....PRICELESS!
Thanks guys. Here is a pick of my puller
Stuff
ALL HALE THE F/2F
1994 FZJ80 Every Day GG
1965 FJ40 Stock, DQ Sunday fun truck
1984 FJ60 Cabin Cruzer
2005 XL Big Green Egg. www.biggreenegg.com
SHREG is offline   Reply With Quote
Old 12-02-06, 12:35 PM   #25
Pin_Head's Avatar
Mud search = FREE
73 cents? You got ripped off. Mine was just 39 cents.
Old 12-02-06, 12:35 PM   #26
IDave's Avatar
TLCA# 13705
Doncha love it? So sweet.
9/70 FJ40 +Rollbar
Old 12-02-06, 12:57 PM   #27
SHREG's Avatar
Im gunna bring the bolt back for a refund!
Stuff
ALL HALE THE F/2F
Old 12-02-06, 02:45 PM   #28
Fuzzy Logic's Avatar
Hey,SHREG! I think this one has more of a bite
'73 FJ40- F power plant- " HI-Ho, Silver Away!" "puff "of blue smoke on start-up, "puff" of black smoke when I frog it, but I'm work'n on it! (It's All About Love! )
Fuzzy Logic is offline   Reply With Quote
Old 12-02-06, 03:53 PM   #29
Blue77FJ40's Avatar
This was what I was gonna suggest. I have the OTC puller, so no worries, but for those that don't, this or the slap hammer as Poser mentions with similar end works fine. The slap hammer and same edge also work wonders on my hardtop rain gutter when a tree pushes it in. A few light taps and the gutter is good as new (well almost).
Forget the grease method. I've never seen that work. Every time I've done that or seen it tried, all it did was blow out the bearing cover, and splat grease on my glasses.
'77 FJ40: HFS, 33's, Locked and Low'd
Blue77FJ40 is offline   Reply With Quote
Old 05-21-07, 07:37 PM   #30
DanS HJ-45's Avatar
