Old 10-07-05, 05:53 PM   #1 (permalink)
Window felt
I need some advice on removal and installation of the window felt. 1980 FJ40 hard top. All new OEM stuff going on the doors.
Tnx
According to the Toy Tech guy, I'm suppose to use the following part numbers:
68180-90300 outside felt strip
68160-90300 inside felt strip
the production date on my FJ40 is Nov 1979; which, according to toytech is really a 1980 model. The parts cut off date is around jun1979; which makes some parts and numbers a little tricky to figure out.
I'm wondering if I need to remove the glass; which if I do - I will be pissed because I just installed all new Toy glass a few day ago and cleaned, greased, new seals and rust proofed inside of doors.
These weatherStip felts look similar to the CCOT stuff:
Insert gif
D.F.Morse
1994 FZJ80 Kazumatized 74000 mi
1979 FJ-40 74000 mi
Here endith the lesson
dfmorse is offline   Reply With Quote
Old 10-07-05, 06:22 PM   #2 (permalink)
Degnol's Avatar
It is just held in there with some barb-type deals, so you can just pry it out. I used a small piece of luan underlayment (1/4" thick) in the channel and a non-maring rubber mallet to install the new stuff. I would spray the channel down inside the felt(where the glass goes) with some silicone, because the first "roll up" I did was tight. Now I did this on early doors. Yours is probably one piece if later doors, so just start at one end and work your way around.
GL
Ed
My Anger-Management Class really pisses me off
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers, WhiteKnuckle sliders
Degnol is offline   Reply With Quote
Old 10-07-05, 06:28 PM   #3 (permalink)
Tnx Ed
D.F.Morse
1979 FJ-40 74000 mi
Old 10-08-05, 03:47 AM   #4 (permalink)
Plowboy's Avatar
There is a rightup in the tech section on installing the felt in the doors using the ccot replacements.
78LC40, sbc 327, PuPs, Aussie Locker, 4wdisc. 1948 bradley trailer
Plowboy is offline   Reply With Quote
Old 10-08-05, 06:57 AM   #5 (permalink)
Tnx Plowboy; must have missed it..
D.F.Morse
1979 FJ-40 74000 mi
Old 10-08-05, 07:27 AM   #6 (permalink)
honk's Avatar
Kinda' hard to tell what channel Larry is putting in in the tech link, but if you have anything other than the OEM late model style channel to put in, with no chrome (or stainless), do yourself a favor by returning it to the store and getting the all rubber with felt inside type that came in later model FJ40s. It's WAY better than the earlier type and holds the window securely from rattling while also doing good sealing. Easier to install too.
Specialization is for insects
'77 BJ40 FST;'77 FJ40; '65 FJ40;
honk is offline   Reply With Quote
Old 10-08-05, 07:49 AM   #7 (permalink)
Merchant of Death
Landpimp's Avatar
would the later model rubber work on the 74 and before doors? oh.........just cut it down to make up for the vent window...eh?
Truth is a torch that shines through the fog without dispelling it. Always be true to your work, your word, & your friends, & you will never live a day without peace
Landpimp is offline   Reply With Quote
Old 10-08-05, 07:52 AM   #8 (permalink)
honk's Avatar
More post padding, right?
The question is raised by a person with a 1980 FJ40.
Old 10-08-05, 08:01 AM   #9 (permalink)
honk's Avatar
A quick look makes me think that it's not long enough for the earliest doors but in any case it wouldn't need cutting, it just wouldn't circumvent the vent
Old 10-08-05, 08:44 AM   #10 (permalink)
Merchant of Death
Landpimp's Avatar
82 fj40's
but I also have a 66 fj45 and am swaping later(77) door onto it......so really it was a valid question.....
Old 10-08-05, 04:27 PM   #11 (permalink)
honk's Avatar
Only if you intend to put the new window channel into the takeoff door of the 66 FJ45....which you don't.
Old 10-08-05, 07:13 PM   #12 (permalink)
Degnol's Avatar
Talking
Go to neutral corners, and Honk.....take a 'Lude.
This is recreation, isn't it?
Peace,
Ed
Old 10-09-05, 07:43 AM   #13 (permalink)
honk's Avatar
Of course - all in fun!
Old 10-09-05, 08:38 AM   #14 (permalink)
Merchant of Death
Landpimp's Avatar
I guess I am not following you on what felt/rubber to swap to what doors.
and Ed......its all fine, I didn't take it as Honks typical smart ass reply to me
