Originally Posted by red66toy How can I tell if I have a later style slave cylinder? |
I only found out when I went to rebuild mine and discovered that the kit I bought from SOR had a bigger piston than the one I was trying to rebuild. I was able to get the later, smaller rebuild kit from NAPA I think.
Sorry- I don't actually know if there's a visual difference, although I think you should be able to pull the rod and dust cover off and measure the bore. As long as you keep the piston from pushing out, you shouldn't make much of a mess and you won't have to bleed the system.
