09-19-05, 05:50 PM
| | 250+ Club
| Saginaw Box Brace ??? I went wheeling near Mt. Rainier for three days this past weekend. On one section I smacked the upper part of the front drivers side tire (I am SOA, 78 FJ40) on a tree rootball and it went BANG! No steering! The impact blew apart the bolts holding the Saginaw PS box to the mounting bracket. Did manage a trail fix and get home...
I am looking for ideas to build a brace for the Saginaw box between the frame rails. The box I have is a three bolt box. I want to beef this up as the threads in the box bolt holes are pretty much shot. I will find the best bolts and nuts I can to tighten the box to the mounting bracket. When I have the luxury funds I will later upgrade to the 4x4 Lab stuff. But for now I want to build a strong brace. Any ideas or photos out there?
Thanks!
Max
__________________ Max
Seattle, WA
1978 FJ40(35's, SOA, PS, SR, 4.88's, H41 & Orion)
1976 FJ55(33's, PS, H42 & Ranger OD) www.seattlecruiserheads.com |
09-19-05, 05:59 PM
| | Site Addict
| somone was making a brace that held the lower part of a sag box with the lower end of a connecting rod, and it spanned across to the other side of the frame. It was a guy on pirate, I can't find the thread, this was about a year ago. |
09-19-05, 05:59 PM
| | 250+ Club
| Is it possible that the bolts were loose? It seems like some you could drill the holes a litte larger and use some grade 8 bolts. What is your mounting bracket like? I have heard that over time the frame will crush if not sleeved and loosten the bolts.
Just some ideas, I have not had problems with mine....yet, I have the 3 bolt box and made my own plate from 1/2 plate and welded it to the frame rail.
__________________ jetboy,
75-40 |
09-19-05, 06:00 PM
| | Oh...Durka Durka Durka.
| If the threads in the casting of the steering gear are trashed, I would get a new gear, and not think twice about it. It is your steering.
Copied from a Currie Ent. set up for a jeep....
1" tube heated and pressed flat on one end....then on the other end I did the same thing and welded it to a flat plate that attaches to the bottom of the passenger side frame, behind the front spring hanger...with two 3/8" bolts...
Seems to have worked al right since '94....
__________________ |
09-19-05, 06:09 PM
| | 250+ Club
| Poser:
Actually I had started a brace like the one you have in the photo, but i did not have it secured to the passenger side frame rail yet(DOPE!!!) Do you have a photo of this (passenger) side? Also: how important is it for the bolts to actually thread into the box holes? And is it OK to add a fresh collection of grade 8 bolts and nuts to secure everything?
Max
Seattle, WA
09-19-05, 06:09 PM
| | Site Addict
09-19-05, 06:13 PM
| | 250+ Club
| Quote: |
Originally Posted by bustanutley |
That looks pretty darn beefy! Thanks for searching and posting it!
Max
Seattle, WA
09-19-05, 06:18 PM
| | Site Addict
| no worries I should build one too, need to finish cage first though |
09-19-05, 06:25 PM
| Quote: |
Originally Posted by CruiserMax ... how important is it for the bolts to actually thread into the box holes? |
I would think that it is very important, since that is how it is supposed to be secured....
I only use grade eight bolts(Caterpillar) to mount things that really matter...
I do not have a picture of the other side...sorry man.
It is just a flat piece of 1/4 thick strap, the same width of the frame, secured by two grade eight, 3/8 bolts, with metal locking nuts..
Good luck!
-Steve
09-19-05, 06:33 PM
#10 (permalink)
| | 250+ Club
| Quote: |
Originally Posted by Poser I would think that it is very important, since that is how it is supposed to be secured....
Good luck!
-Steve |
Thanks Steve. I will tap new threads and use grade 8 bolts w/ nuts... And finish the brace. I never want to go through this kind of trail repair again (if I can avoide it!)
Max
Seattle, WA
09-19-05, 06:54 PM
#11 (permalink)
| | not an addict
| jeep aftermarket companies make them...i measured a cj7 once and, iirc, it was about the right size for those that don't have time to fab one.
__________________ "to learn is to teach someone else"
only four cruisers left |
| Thread Tools | | | | Display Modes | Linear Mode |
