Old 09-14-05, 06:41 PM   #1 (permalink)
Elijah's Avatar
TLCA# 16029
ignition wire
Trying to locate the ignition wire to tap into it for the electric fan. How do I distinguish which one I want to tap into???
99 UZJ100 - overland use
95 FZJ80 - rock and trail use
Elijah is offline   Reply With Quote
Old 09-14-05, 07:09 PM   #2 (permalink)
Vortec_Cruiser's Avatar
TLCA# 5659
If this is on your 1976 FJ40, you'll find two male spade fittings on the fuse block. One of these is switched power, and the other is fixed power. You can tap in here.
Ed Gilbert - TLCA #5659
Formula 4 Toy #F006 build in-progress
1977 FJ40 - So. California
vorteccruiser@charter.net
Vortec_Cruiser is offline   Reply With Quote
Old 09-15-05, 09:43 AM   #3 (permalink)
Elijah's Avatar
TLCA# 16029
Thanks Vortec, worked perfectly.
Old 09-15-05, 10:10 AM   #4 (permalink)
Pin_Head's Avatar
The wire will be fuse protected, depending on which side of the fuse you tap into. You want to tap the side AFTER the fuse in case something shorts out.
Pin_Head is offline   Reply With Quote
Old 09-15-05, 10:43 AM   #5 (permalink)
Ramblin Wreck
CruisinGA's Avatar
For future reference, you can also use the lower terminal on the ballast resistor for the ignition coil.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'53 Willys Wagon
ΣΧ
CruisinGA is offline   Reply With Quote
