Old 09-14-05, 10:43 AM   #1 (permalink)
Dain Bramaged Member
rusty_tlc's Avatar
TLCA# 15069
YABQ (Yet Another Brake Question)
For some reason my brake lines have shrunk, they no longer reach from the frame to the axle. I just don't understand, everything was fine when I pulled the axle to do the SOA.
Anyway I need longer lines. I have heard rumors that there is an adaptor fitting to convert from my cruiser hard lines to AN3 lines. Any truth to this or is it urban legand?
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
rusty_tlc is offline   Reply With Quote
Old 09-14-05, 10:46 AM   #2 (permalink)
Ramblin Wreck
CruisinGA's Avatar
any reason to convert?
just double up with some stock cruiser lines or if you're feeling blingy get some stainless braided.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'53 Willys Wagon
ΣΧ
CruisinGA is online now   Reply With Quote
Old 09-14-05, 10:54 AM   #3 (permalink)
camcruiser13's Avatar
go to your local hose place and get longer ones made, pretty cheap
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
DIY Beadlocks
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
Old 09-14-05, 10:55 AM   #4 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Garage
http://www.ih8mud.com/techtrivia.php
Old 09-14-05, 11:02 AM   #5 (permalink)
FLYINGLOW's Avatar
TLCA# 9203
It is prolly true, but the adapters for SAE are prolly alot more common than those for metric. I know a racecar shop around here has braided stainless lines for about $30 with AN3 ends, but I haven't researched the adapters. Maybe one day.........
Go with the rabestos ones in the link Poser put up. Cheap and easy.
77 FJ40 TBI 2F, Aussie rear, rear 45 springs, 36" TSLs, Warn 8274......
Made in Japan, Built in Canada
97 4 Runner Ltd
FLYINGLOW is offline   Reply With Quote
Old 09-14-05, 11:12 AM   #6 (permalink)
rusty_tlc's Avatar
TLCA# 15069
I'll pick up a set of the raybestose ones from Napa at lunch.
Thanks Poser.
Dan Johnson
Rust never sleeps.
Old 09-14-05, 12:27 PM   #7 (permalink)
Poser's Avatar
TLCA# 1856
Garage
Just more info on this...
http://www.pegasusautoracing.com/gro...=BRAKEADAPTMET
Have purchased the -4/10mmx1.00 metric flare adapters and copper crush washers from these folks...spendy, but they have it....and A LOT more.
Good luck!
-Steve
Old 09-14-05, 09:26 PM   #8 (permalink)
rusty_tlc's Avatar
TLCA# 15069
Maybe I should have mentioned the Old Man Emu Springs, front shackle reversal, longer shackles, and rear spring flip. I picked up one line on my lunch break, no time to look at it, when I got home I realized it might work if all that had happened was a SOA. I'll check out Pegasus. Looks like they have the parts. I'm looking for 10mmX1 metric flare right?
Dan Johnson
Rust never sleeps.
Old 09-14-05, 09:35 PM   #9 (permalink)
Poser's Avatar
TLCA# 1856
Garage
I have used these red ones from Marlin too...these would thread right into the fitting on the axle, and the metric brake line would attach right to the other end....
http://www.marlincrawler.com/brake.html
Good luck!
-Steve
