Old 08-30-05, 07:54 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
My Anti wrap bar version
I used one of these. About 19 dollars I think. Cut the ends off it and extended it with some thick tubing. Then welded the schackle that I found at tractor supply with the brace for 13 dollars. The xpensive part was the bottom hiem joint which I bought from Summit racing for 22$. Next time I would just buy another one of the bars like I found at tractor supply and keep the one side I didn't use as a spare. All in all it cost me around 60$s.
Only thing I'm going to change is the front bottom shackle pin. The heim joint and the shackle pin are different diameters. I'm going to get the right bushing and some shock bushings for each side.
Amazing difference in traction and stopping. No more stuttering.
And since the previous owner mounted one without a shackle And it ripped out of the crossmember I patched the holes and added a strap over the top and welded it for added support.
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
"What fits your busy schedule better, exercising 1 hour a day or being dead 24 hours a day?"
Old 08-30-05, 11:00 AM   #2 (permalink)
camcruiser13's Avatar
kool im gonna need to make one i think. nice work, it gives me some ideas
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
DIY Beadlocks
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
Old 08-30-05, 03:03 PM   #3 (permalink)
Capt. Jim's Avatar
TLCA# 5390
That works. Nice job Marshall.
Capt. Jim
Florida Land Cruiser Association
North Florida Cruiserheads
Upstate Cruisers
TLCA #5390
Capt. Jim is offline   Reply With Quote
Old 08-30-05, 04:44 PM   #4 (permalink)
what he said
Mace's Avatar
TLCA# Something
First rock you hit with that shackle that hangs down is gonna give you a headache..
I am kinda gay.......
My Myspace
Old 08-30-05, 07:47 PM   #5 (permalink)
FLYINGLOW's Avatar
TLCA# 9203
Why do you say that? Invert?
77 FJ40 TBI 2F, Aussie rear, rear 45 springs, 36" TSLs, Warn 8274......
Made in Japan, Built in Canada
97 4 Runner Ltd
FLYINGLOW is offline   Reply With Quote
Old 08-31-05, 06:14 AM   #6 (permalink)
what he said
Mace's Avatar
TLCA# Something
nope, because the shaft of the rod end is gonna bend and will break..
My Myspace
Old 08-31-05, 06:47 AM   #7 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Well maybe. Though the shaft ends are pretty stout. It might bend but for 65$ I'll just make anotherone. A lot cheaper than replacing a driveshaft which is why I designed it to be lower than the ds. The hiem joint threads also run into the bar about twelve inches on both top ends. So even it did break it won't fall apart.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-31-05, 09:16 AM   #8 (permalink)
haystax's Avatar
TLCA# 14279
Looks pretty stout - except I've heard/read about the stock crossmember not being up to par to tie into. I can't say much though for personal experience, I am still too lazy to get one built for my junk. You think they will notice if a couple tractors are missing 3point links around here
'76 FJ40 - 2F,SO,SR,RDB,PS,4.88,Q78TSL,earlydizzy,mod'd carb,Aussie'd front,weld'd rear,MetalTech'd...still too fast in 4LO
haystax is offline   Reply With Quote
Old 08-31-05, 10:03 AM   #9 (permalink)
FLYINGLOW's Avatar
TLCA# 9203
If it bends, it will prolly break the first time you torque it, which will coincide with your D/S (or pinion) twisting itself up.
Mace do you suggest pointing the shackle up? Won't that give too much antisquat? I have never built a 4 link, but from my research on antisquat, I believe it will.
97 4 Runner Ltd
Old 08-31-05, 11:12 AM   #10 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
So are you saying Woody did it wrong also?
http://www.ih8mud.com/tech/woody/wrap.html
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-31-05, 11:53 AM   #11 (permalink)
what he said
Mace's Avatar
TLCA# Something
Boy are you defensive..
Woody's did not hang below the skidplate. It looks like yours does..
I had built one that hung low, Killed it quick in Moab.
Just my experience talking here.
Your discussion of "torquing" is actually a response to antisquat (obtuse as it may be leaves are actually a form of links) The direction of the track bar is a direct translation to how the vehicle will behave. If it is above the x-member you will have large amounts of antisquat and the truck will want to rise on acceleration. If it is below the xmember that "lifting" effect will be reduced. Infact, it is possible to have the rear of the truck actually squat during acceleration (my linked rear does this right now) Which one is better/worse depends on who you talk to.
BTW, Woodrow DOES do things wrong sometimes
My Myspace
Old 08-31-05, 11:55 AM   #12 (permalink)
what he said
Mace's Avatar
TLCA# Something
Also use better than grade 2 bolts on stuff.. IT really is not that much more expensive..
My Myspace
Old 08-31-05, 11:57 AM   #13 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Sorry about the defense. Yeah the pics make it look below the skid plate but it actually is not. But it is in line with the Driveshaft for the most part. But still any rock could hit it. I just cannot imagine hitting something that hard. I'm not a lower 2 kind of guy. 4,5,6 at tellico is about my threshhold. I like my junk to be able to drive around town also.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-31-05, 11:59 AM   #14 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Yeah every thing else except for that one bolt is grade 8. My thought was to have a wink link somewhere. I would rather break a bolt than something else. That why I carry a spare Grade 8 in the glove box.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-31-05, 12:13 PM   #15 (permalink)
what he said
Mace's Avatar
TLCA# Something
I tend to find that most of the time a "Weak link" breaks at the worst possible moment
I would use Grade 8's..
If the bar is gonna fail it will fail. A sub grade bolt will not help it. Also, if the bolt does shear you will put more instantaneous force on your axle potentially increasing the amount of axle wrap you have seen. teh bar keeps the Kinetic enery contained. When it fails you release that energy and all sorts of neat things can happen .
My Myspace
Old 08-31-05, 12:36 PM   #16 (permalink)
In the garage
John Smith's Avatar
TLCA# 9074
I have seen two traction bars fail and they both punched a hole in the floor of the truck.
79 FJ40 & 78 FJ55
John Smith is offline   Reply With Quote
Old 08-31-05, 03:15 PM   #17 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Well then it on for the grade 8 and off with the grade two. Easy swap and I'll keep it as the spare. Thanks for the advice. Though I think I'll rip the shackle off before the grade 2 bolt breaks.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 09-03-07, 07:43 AM   #18 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Update. Well after 2 years of beating on it. It looks like it has bit the dust. The joints are worn out and the links are wallowed out. Still works but there is a lot of slop. Great idea with poor products and little money. Decided to cut out the cross member all together and start over using quality products.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 09-03-07, 09:40 AM   #19 (permalink)
Dynosoar's Avatar
TLCA# 17857
Quality will always win! "Do it right the first time" can be an expensive lesson to learn. Luckily in you case you were able to do version one on a budget and have it last for a while.
Dynosoar
'82 V8J60 - TPI 350 with a 700R4 attached to a splitcase, Cable Locker FF rear end, 4" SUA (National Spring), Copper Metalic Has been south to Cabo San Lucas, BCS and North to Port Angels,WA.
Call Sign: KI6SMP
Dynosoar is offline   Reply With Quote
Old 09-03-07, 11:00 AM   #20 (permalink)
Bad Coco's Avatar
I'll try to post up some pics of mine tonight. Went with 1.5" .156wall dom with the ruffstuff brackets on the axle. Made a new crossmember with a shackle to a polyperformance uniball. We will see how it hold up in time. I inboarded my rear springs (rear 60's) an attached the crossmember to the spring hanger and the frame to beef it up.
Don't gnaw on your kitty
Poo-flinger build up: http://www.pirate4x4.com/forum/showthread.php?t=548889
Bad Coco is offline   Reply With Quote
Old 09-05-07, 12:13 AM   #21 (permalink)
Bad Coco's Avatar
No luck with posting the pics. Too big and I'm too tired to figure out how to resize. Here is the link to where I posted up some picks on Pirate. I think it should work pretty well. Time will tell.
http://www.pirate4x4.com/forum/showt...=548889&page=5
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/58015-my-anti-wrap-bar-version.html
Posted By For Type Date
Upstate Cruisers Tech Archive This thread Refback 11-17-08 12:31 PM
Upstate Cruisers This thread Refback 02-28-08 09:03 PM
