LinkBack (12) Thread Tools Display Modes
Old 08-01-05, 08:19 AM   12 links from elsewhere to this Post. Click to view. #1 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Cut and Turn: My experience
Before cutting the perches and hardware off
Before cutting all the hardware off (So I know how it goes back on)
Back on with vehicles weight on axle to measure stock castor (jack stands are for safety only, no weight on them right now)
Measuring stock castor. Make sure angle finder is parallel to spring and spings are parallel to frame.
Cutting off mounts. Make sure you mark where the old perches were located on the axle because your mounting the new perches 180 degrees on the other side. Makes it a lot easier.
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
"What fits your busy schedule better, exercising 1 hour a day or being dead 24 hours a day?"
Old 08-01-05, 08:19 AM   #2 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
The Cut off wheel and old perches.
Bare housing with rough weld from old perches and hardware.
In vise level and at stock or original castor angle (mine was 2 degrees + because PO had added shims normal should be +1)
Smoothed down filling all cuts from taking perches and hardware off; filled and then ground back smooth.
With level housing rotated 14 degrees I put perches on at 0 degrees to measure how much I would need to cut them to fit on the housing. You can see the left side needs no modification.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-01-05, 08:20 AM   #3 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
But the right side will due to differential housing.
You can see how much I needed to grind to make it fit. I used Dodge perches # P4120074 there are two prches in each box. They were $11 dollars a box. You need two boxes. Though it's not nessesary to put a perch on the left bottom side I did anyway. The right side needs something to keep ubolt from slipping off. If you look ata a stock non SOA you will know what I mean.
This is a diagram of what I ground down with each dot representing an inch. (this is for one side only of the right perch.) Use this for reference only.
Making sure it is level.
I cut the knuckle 1/32 less than 1/4 inch using a depth gauge to measure distance. (You can actually see the seam of the outer housing and the knuckle in this picture.) Also notice the vertical cut to the left. I did this as a refence to stock setting so when I tested the knuckle to see if I had ground enough down and truned it I could put it back to stock again. Turning it was not that hard as others have recommended use old bearing races in the knuckle when turning it otherwise you could deform the race areas and have a mess on your hands.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-01-05, 08:21 AM   #4 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Home owners rules states that all 4 tires must be on the vehicle at all times. (looks good to me )
Back on with the pinion angle set correctly (+14). We also backed this up by installing the diff and lining up the driveshaft. Centered the housing between the springs. Added the new perches with the weight on the front housing and tighten the u-bolts. The weld the new perches enough so when I did the knuckle turn it would hold the housing from turning. I also tacked the bottom perches on at this time.
Ground the cut out on the knuckle to make for a better weld penetration. Turned the knuckles to +5 degrees using a breaker bar and a 5 lb sledge hammer. And then tacked it into place. (Make sure when using an angle finder that you are consistant with where you put it on the knuckle and that it is parallel to the frame and springs.) I found it was easier to turn the knuckle to 0 degrees and then get this right because the more degrees the knuckle is turned the harder it is to get an acurate reading. I also did this with the bearing races in. (not shown in pic)
My helper Alex. Air tools are the best investment. (taking the housing back off)
Welding left perch
Welding right perch
Then weld knuckles on. Then shock, brake, steering stop mounts go on next. I did this while the housing was back on the vehicle for proper adjustment. Then put everthing back on. And your done.
Have fun. It really was not that hard. The grinding and cuting everything off was by far the hardest part.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-01-05, 08:35 AM   #5 (permalink)
TLCA# 12604
Hey. Great pics. I appreciate the detail in the write up. When do we see the completed project? Cheers, Jim
Jim S. is offline   Reply With Quote
Old 08-01-05, 08:38 AM   #6 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
This week. I'll add more pics of the final rebuild after that.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-01-05, 09:22 AM   #7 (permalink)
Supporting Vendor
71-CRUISER's Avatar
TLCA# 14378
Looks good.
Michael Harness
co-owner
TLCA #14378
www.AtlantaCustomCreations.com
ACC Toyota Vendor Forum
03 Tundra 4x4
71 FJ-40 EFI 5.0, NP435, SOA, 38.5s SXs, Disked/Longed/Aussie/4X4 Labs front, FF Rear, MetalTech, Saginaw etc.....
71-CRUISER is offline   Reply With Quote
Old 08-01-05, 11:10 AM   #8 (permalink)
camcruiser13's Avatar
very helpful troll, i getting started on mine this next week and will use this info. looks good
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
DIY Beadlocks
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
Old 08-01-05, 11:22 AM   #9 (permalink)
clemson55's Avatar
Very nice Marshal now dont forget any of it before I go SOA in the future (timeframe yet to be determined). I want to see lots of pics and carnage from Tellico in 2 weeks.
Cruiserless for the first time in 4+ yrs
Upstate Cruisers
clemson55 is offline   Reply With Quote
Old 08-01-05, 12:01 PM   #10 (permalink)
greencruiser's Avatar
great write up dude
the more pics you have makes it easier to understand what really needs to be done
this winter I will be doing some 60 series housing for my 40 along with a shackle reverse and rear disc brakes. and will definatley be doing cut and turn :-)
1971 fj40 tbi350 465 sr soa 98wb welded f/r saginaw ps 4x4labs 37s
greencruiser is offline   Reply With Quote
Old 08-01-05, 02:26 PM   #11 (permalink)
Klunky Chris's Avatar
TLCA# 4821
OK, dumb question that will show my ignorance...
is the knuckle ball attached to an *inner* axle?
IOW you are cutting through the outer axle inboard of the factory weld so you can twist the knuckle ball and inner axle INSIDE of the outter axle???
and this will keep the knuckle alligned and centered so your axle seal and such are in the right place?
if so....... I never realized it was this easy. I always had a picture of cutting the knuckle LOOSE ...then trying to hold it on and weld it on while keeping everything alligned.
great pics! Thanks!
Chris Basehore TLCA# 4821
74 FJ40- built F, knuckles/brakes from a FJ60, Longs, 4" Pinnacle sucks big wads, mini PS, shite paint
93FZJ80 "klunky"- E-lockers, home built sliders, IronPigOffRoad bumper, CDL switch, D-less, mucho maintenance
www.ILUVROCKS.com
Klunky Chris is offline   Reply With Quote
Old 08-01-05, 02:28 PM   #12 (permalink)
Admin
woody's Avatar
TLCA# 1548
Garage
outer ball is sleeved about 3" inside the outer housing...makes the cut-turn "relatively" easy that way....
http://www.ih8mud.com/tech/soa/5.html for pics
Brian 'woody' Swearingen
Owner, IH8MUD.com
Owner, ROCKCRAWLER.com
Forum Questions? Click Here! .. .. .. .. 2009 IH8MUD Wheelin Schedule!
'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln
'Everyone wants to save the porpoises, but no one cares about the tuna'
Old 08-01-05, 08:36 PM   #13 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Don't worry I won't forget.
Thanks guy for the comments. I welded the knuckles tonight and took some more pics. WIll post tomorrow.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-02-05, 08:25 AM   #14 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Welding the knuckles.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-02-05, 08:38 AM   #15 (permalink)
Mad Chemist's Avatar
Silly question from a welding newbie- did you TIG weld after the cut and turn? I've got a Lincoln 135, and am wondering whether I'll (or I should say, the more experienced person I guilt into welding for me) get enough penetration to get strong welds?
Great writeup, I'm definitely more of a "visual" learner!
-David
'73 FJ-40
2008 5.7L Tundra TRD
Just traded '98 4Runner and 2005 Tacoma TRD Sport in for Tundy
Mad Chemist is offline   Reply With Quote
Old 08-02-05, 08:49 AM   #16 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Millermatic 175 mig
.035
I think if you grind the cut out to about a 1/16 from the buttom of the cut you will get good weld penetration. I made sure by watching the sides of the cut to see if they were flowing into the filler material.
I bought my first welder when I was 14 and have been welding ever since; I'm 34 now. Stick and brazing is mostly what I have done. Mig is new to me. I love it though. No slag to deal with and very little splatter. Once you learn the properties of metal and how angles and filler materials interact with them at certain temps and conditions you pretty much can weld with anything. I'm really looking forward to getting my hands on a Tig.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-02-05, 03:11 PM   #17 (permalink)
Deny's Avatar
TLCA# 11568
Nice write up! I really liked how you took a picture of every step, makes me want to start cutting!
One question though, how come you welded perches under the axle?
Cheers,
Deny
Diesels Rule
81 BJ42 and a few other cruisers
Check out my endless fix up progress at http://forum.ih8mud.com/ca-bc-peace-canyon-toyota-swamp-donkeys/152995-bj42-winter-fix-up.html
Deny is offline   Reply With Quote
Old 08-02-05, 04:06 PM   #18 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Garage
Cheers,
Deny
" You can see how much I needed to grind to make it fit. I used Dodge perches # P4120074 there are two prches in each box. They were $11 dollars a box. You need two boxes. Though it's not nessesary to put a perch on the left bottom side I did anyway. The right side needs something to keep ubolt from slipping off. If you look ata a stock non SOA you will know what I mean. "
Nice write up Troll...
Old 08-02-05, 04:12 PM   #19 (permalink)
dmaddox's Avatar
TLCA# 13877
I am doing this as we speak. I was really concerned about the front diff side perch to make sure it was not creating a "lean". Meaning, to make sure and measure how far from the axle tube to the perch surface. This would make sure that one spring pack was not higher than the other. This is a great write-up, pictures are very nice.
Thanks for the write up, and perfect timing as I am doing all this right now!
-ragman
1996 -80
1977 -40
1963 -45
dmaddox is offline   Reply With Quote
Old 08-02-05, 04:21 PM   #20 (permalink)
Pin_Head's Avatar
The key to successful welding of thicker stock (1/4 inch or more) with a 110V welder, like the Linc 135, is joint preparation. You need to V or U grind joints to the full depth and leave a 1/16 root gap. Weld in 2 or more passes. Remove the slag in between if you are using flux core. Preheating to 400 F wouldn't hurt and do the second and later passes w/o cooling down.
Pin_Head is offline   Reply With Quote
Old 08-02-05, 04:35 PM   #21 (permalink)
Maddox , in regards to your ? , the outside edge of the perch remains uncut and sits on the last bit of straight part of tube so just grind inside till it sits level and you are golden.
John on the hawgs
peesalot is offline   Reply With Quote
Old 08-02-05, 04:46 PM   #22 (permalink)
JimL's Avatar
A1 for photography and writeupy, great stuff Trollhole !
(also, did you really weld the left and right perches with your finger ???)
'81 & '83 BJ40s, both dead, awaiting resurrection day
JimL is offline   Reply With Quote
Old 08-02-05, 08:47 PM   #23 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Thanks for all the positive comments. I wanted to try to relay what I was seeing and what was most important. Thank you for the kind words.
Now back to reality. Shock mounts are on and level. When I cut them off orinally Icouldn't get the whole thing so when I installed them back on i ran two beads down the axle tubeand ground them flat for the shock mounts, This gave me stock height. Steering stops were next. I used the knuckle with one bearing to determine the correct placement, Now all I have left is the brake line mounts. And tap a new vent line that will accept a 1/4 inch barbed fitting.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-02-05, 08:53 PM   #24 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
That's my helper Alex. He wanted to point and I wanted to take pictures. A match made in cruiserdom.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-02-05, 09:02 PM   #25 (permalink)
HawkDriver's Avatar
TLCA# 15861
Superb thread troll.
This reinforces my decision to cut and turn on my next SOA. Last time I just didn't want to deal with the cutting and reinstalling of all the little parts. Nice to see some closeups of the actual cut where the turn is made too. Nice welds too. Question is how did the heat effect it, I mean did you do it all the way around at once, take little steps letting it cool? Same with the perches? Thanks and nice lookin Cruiser too.
Forty kind of guy with a Hundy
HawkDriver is offline   Reply With Quote
Old 08-03-05, 06:46 AM   #26 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Thank you. I see people talking about heating the ends to get them to turn. Though I did my cold. I don't think heat will affect it. The whole housing it's self is welded together. Though on welding the knuckles I did only wel about two inches then move to the otherside and then come back and rotate just incase.
Pic of the shock mount and steering stops I welded last night.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-05-05, 06:46 AM   #27 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Finished up the axle last night.
Welded the brake line mounts. I used the old brake lines as a reference.
Made sure the brake parts are plugged so no crap gets in them
Then used the wire wheel on the grinder to clean it up and finally washed it down with brake cleaner to get if completely clean inside and out.
Then bolted diff on with new gasket and painted. Pretty huh
Next thing is to bolt it back on and install the new stainless steel brake lines. And then measure for the driveshaft so I can get it shortened. That will be tonight. And then hubs tommorow and I should be done.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-05-05, 07:19 AM   #28 (permalink)
TLCA# 4821
did you *point* your pinion upward? IOW: different than stock which is level?
if so how much?
also, are you using stock springs or did you get new ones? what kind?
great writeup!!!
www.ILUVROCKS.com
Old 08-05-05, 07:21 AM   #29 (permalink)
Capt. Jim's Avatar
TLCA# 5390
Nice work Marshall. And nice write-up, too.
For you and Alex.
Capt. Jim
Florida Land Cruiser Association
North Florida Cruiserheads
Upstate Cruisers
TLCA #5390
Capt. Jim is offline   Reply With Quote
Old 08-05-05, 08:13 AM   #30 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
if so how much?
great writeup!!!
Stock Springs
"Back on with the pinion angle set correctly (+14). We also backed this up by installing the diff and lining up the driveshaft. Centered the housing between the springs. Added the new perches with the weight on the front housing and tighten the u-bolts. The weld the new perches enough so when I did the knuckle turn it would hold the housing from turning. I also tacked the bottom perches on at this time."
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/54253-cut-turn-my-experience.html
Posted By For Type Date
Landcruiser SOA Castor - Pirate4x4.Com Bulletin Board This thread Refback 09-13-09 11:08 AM
60 Series SOA help - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 05-18-09 06:27 AM
Upstate Cruisers Tech Archive This thread Refback 11-06-08 10:54 AM
Indice: Archive through This thread Refback 05-24-08 02:44 PM
Toyota4X4.RU -> 60- This thread Refback 05-23-08 04:23 AM
Indice: Registro Italiano Toyota This thread Refback 05-16-08 12:55 AM
Knuckle rotating ..? - Trail-Gear On-Line Forum This thread Refback 02-12-08 09:09 AM
Les conseils 4x4 de serie4.com. bj40, bj42, bj43, bj45, bj46, fj40 This thread Refback 01-19-08 01:23 AM
CLUB 4x4 loi 1901 - TLC Srie-4 France - le forum :: Voir le sujet - TUTO SOA This thread Refback 12-28-07 03:26 PM
Upstate Cruisers This thread Refback 12-28-07 12:06 PM
Welcome to Upstate Cruisers! This thread Refback 12-18-07 02:04 PM
Les conseils 4x4 de serie4.com. bj40, bj42, bj43, bj45, bj46, fj40 This thread Refback 12-18-07 10:44 AM
