Old 06-04-05, 06:33 AM   #21 (permalink)
KC6ZWY
Doug_S's Avatar
I found my 8274-50 on this site for sale. It's great. I've hauled out vehicles that are bigger than my rig with it. It's wonderful! Try to buy one that is complete and in need of very little. The more that is missing means the more that you will have to purchase to make it work right. I second the suggestion to try http://www.shercosales.com.
Doug
Olympia WA
1977 FJ40
1968 R60/2 W/Steib S350
1980 CT110
1984 R100ST
Doug_S is offline   Reply With Quote
Old 06-04-05, 04:39 PM   #22 (permalink)
springfield user
brian's Avatar
traded my rear lunch box for an OLD 8274(no freespool option). never got around to put it on.
and now i've lost the one sideplate/bearing plate thingy.
so in the few times i've needed somthing, my industerial strength come-along and straps have got'en the job done.
it's only metal, we can out think it.
77-fj40 20th anniversary edition
87-fj60 216K mile DDer
93-fzj80 mall crawler
toyota material distribution center. your source for Factory Service Manuals.
they're alot cheaper than you think.
1-800-622-2033
brian is offline   Reply With Quote
Old 06-04-05, 05:12 PM   #23 (permalink)
wesintl's Avatar
I've got 2 8274's. One on the 70 and another on the 40.
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Sponsor 06-04-05, 06:29 PM
Sponsored Link
advertisement
Old 06-04-05, 06:29 PM   #24 (permalink)
Texx's Avatar
Hey '71 Cruiser...yer bib is on upside down. Always a smart ass in every crowd. I've had both...never used any of em. Not in anger, anway. I like the look and idea of the PTO tho.
world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 restored SOLD:( 03 Tacoma TRD SR5, Suzuki DR350 Sold :(
Texx is offline   Reply With Quote
Old 06-05-05, 05:15 AM   #25 (permalink)
Rookie
i have the toyota factory winch, and i say it is the best. orginal the breakpin will break at 4400 lbs. but i drilled up the holes and put in a 6mm bolt insted of the pin now it will pull 26500 lbs or to the winch cable snapp.
Bj40 hardtop SOA
http://home.aland.net/m04188/offroad/main.htm
Alandia40Cruiser is offline   Reply With Quote
Old 06-05-05, 05:34 AM   #26 (permalink)
3pits's Avatar
8274 on the 40 used it with snatch block to pull out my 4x4 kubota m5700 (57 hp) VERY stuck tractor,,, had to chain the rear 40 axel to a tree, and still picked the rear end up
needless to say I was really stuck a 70 hp 2wd jd tractor could not budge it, the fel did nothing, b4 I hooked the 40 to a tree I burried 2 12" tall steel wheel chocks, just shoved them into the ground (2 pcs of like 9-10" channel welded together and braced)
m12000 going on the 62,,
You can have it done QUICKLY, done INEXPENSIVELY, done CORRECTLY Pick any 2
Liberals are like Slinkies, Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs
3pits is offline   Reply With Quote
Old 06-05-05, 06:00 AM   #27 (permalink)
crushers's Avatar
my history with winches:
first ever was anew in the box ramsey 8000. lasted 1 year 1 month and the motor died, no warrenty
then a bellview 6000, unreal power, would out pull the later warn 8000.
next was a 8274 that one outlasted quite a few trucks.
PTO, should read POS. the down fall of this winch is the shear pin and no load notification. the elec will stall out if you are trying to pull too much. the PTO just quites, no sound, no notification all of a suddedn you get the feeling you are not going forward anymore. the shear pin is in the most inaccessable spot and when you are up to your headlights in ice cold water you are FUBAR. to change out the shear pin on dry ground can be an endevor in futility as well.
my vote is the 8274, 8274-50 or the bellveiw.
cheers
we are all given sh*t in life, but some of us learn to turn it into fertilizer and grow from it, and some us try to fling it on others like monkeys.
the start to the above truck here: http://forum.ih8mud.com/70-series-te...uck-build.html
Wayne in Ontario
www.luxuryimports.ca
crushers is online now   Reply With Quote
Old 06-05-05, 06:02 AM   #28 (permalink)
The Anti-Leafer
LC_Hamma's Avatar
I got (3) 8274's & (2) M12000's - not all installed yet. All but 1 were bought off Ebay. Other than me buying some synthetic cable, they were all complete & in good working condition.
LC_Hamma is offline   Reply With Quote
Old 06-05-05, 06:09 AM   #29 (permalink)
Supamod
Gumby's Avatar
Garage
Gotta belleview for the 40. Wish I had an 8274-50. Not that I don't like the Belleview.
Need something on the 80. I might as well just buckle under and accept the fact I'm going to keep wheeling it. M12000, hopefully.
Cerdito and the 4.5LV
92 Cummins D250 tow rig
Team Lop headed Axial AX10
Gumby is offline   Reply With Quote
Old 06-05-05, 07:20 AM   #30 (permalink)
I went with a standard warn m-8000 a short while back. I really wanted a 8274, but looking at what that thing weighs, and how it mounts, it really wouldn't have worked very well for me. I had to have a multi-mount. I didn't want to carry a winch around in the back of the 40 and I didn't like warns setup, so I just built my own.
folsom50 is offline   Reply With Quote
Old 06-05-05, 07:24 AM   #31 (permalink)
fatherofdaughterofromer
Romer's Avatar
Garage
Chicago 8000lb on the 40 (Came with the rig) has worked fine
Warn M12000 on the LX450
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is offline   Reply With Quote
Old 06-05-05, 11:21 AM   #32 (permalink)
sanjuancruiser's Avatar
been through two rep 8k's and one ramsey PTO8k. settled on the warn m12k. Haven't truly put it to the test but it should be enough.
The ramsey PTO was indestuctible but I no longer own it. Ramsey 8k was a joke burnt up first use trying to pull myself out of the mud -man IH8MUD! It got the name of cable spooler inner outer cause, thats all it would do.
I'd buy the m12k for the same money as the 8274 or less?!
TLCA#14565
62 FJ45 SWB H55 Locked etc.., 04 Lexus RX330 OME lift, BFG A/T's, Drag Wheels, 79 FJ43 stock, 83 Troopy RHD Lifted, RTT, A/C!
If it can't be grown it's gotta be mined
http://www.safari-ltd.com
sanjuancruiser is offline   Reply With Quote
Old 06-05-05, 11:50 AM   #33 (permalink)
Ramblin Wreck
CruisinGA's Avatar
Read somewheres that a double lined 8274 is still faster than an m12, and has a larger load capacity.
Also doesn't have the tie-bars limiting how much cable you can stack up on one side of the drum on a angled pull.
I'm waiting for a good deal on a Belleview or 8274 to stare me in the face.
Until that happens I've got a free m8000 waiting for some solenoids. Will probably go on the 80.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-8274-FJ60 PS-MetalTech Cage
'93 FZJ80-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's-XD9000i
'53 Willys Wagon 4x4
CruisinGA is offline   Reply With Quote
Old 01-14-06, 11:58 AM   #34 (permalink)
Lifer with a 2F-ETI
matt.mcinnes's Avatar
I run a modified 8000lb high mount
I have a question for the PTO followers. How do you winch your truck back onto it's wheels when rolled or layed on its side without damaging the engine? PTO's in general seem every bit as good if not better than electric, they will go longer and just as hard.
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
matt.mcinnes is offline   Reply With Quote
Old 01-14-06, 12:30 PM   #35 (permalink)
HawkDriver's Avatar
Here's what I been runnin for about 4 years now. Havn't had to use it in quite a while, but it's proven to be quite a capable little unit. I've seen similar ones in TSC but they aren't as beefy. I think once I do upgrade to an 8274 I'll prolly still keep it handy.
Forty kind of guy with a Hundy
HawkDriver is offline   Reply With Quote
Old 01-14-06, 01:54 PM   #36 (permalink)
hudyhue's Avatar
Sorry if I missed it but ,anyone running a milemarker (electric) any size just wondering how you like em?
The Hudyhue Crew...
'77 fj40..Mostly stock sua 4in springs up front ,soa on stock springs on a welded rear...sitting on 33in mud terrains not on "z"rated tires
member, 4X4HIM & Central Valley Crawlers!
hudyhue is offline   Reply With Quote
Old 01-14-06, 02:56 PM   #37 (permalink)
rusmannx's Avatar
Just one more to agree with the Warn 8274.
I've sucked people out of the goo i've seen other winches just bog down on.
While your spending money get your self a good snatch-block and some extra tow/winch ropes.
www.rusmannx.com
72 fj40: F-3speed, DUI, 2bbl rochester, 4 inch skyjacker, 33x10.5 tsl radials, saginaw, 8274.
imrdb.org = two-way radio geeks
impdb.org = airPlane geeks
immdb.org = motorcycle geeks
rusmannx is offline   Reply With Quote
Old 01-14-06, 03:12 PM   #38 (permalink)
photosynthesizing
pappy's Avatar
Garage
I bought my XD9000 on the 4Runner from http://www.4wheelonline.com/ in Florida. Free shipping because it's drop shipped. Price on the 8274-50 right now is $1075.99, which sounds pretty good.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 01-14-06, 03:23 PM   #39 (permalink)
Walking The Line
PacToy supports the BlueRibbon Coalition!
PacToy's Avatar
I have a friend that has one. He has a 8000lb electric. They are loud and slow. He has had it for about two years and I can personally atest that he has about 150 hundred real hard pulls and recoveries on it. Last outting the milemarker finally gave up the ghost during a hard pull on a seriously stuck BJ74.
PTOs here are usually trashed and replaced with a electric winch. I Believe a lot of people THINK PTOs are great until they have actually used them in demanding situations. No engine power, no winch power, shear pins break, up grade shear pins and then the PTO propeller shaft joint/transfer case can/will go.
I have two 24v Toyota high profile winches (8274 look alikes) on my BJ44. I can't say enough about these two winches. Quite and fast. Even faster with a snatch block vice straight pulling.
Japanese wheelers will ditch their Toyota winches for Warn winches. They think Warn made their reputation with the 8274 and nothing else will do. If you can find some way of getting a Toyota winch I would tell you to really consider it as a viable option with good quality.
Randy
71 FJ40
78 FJ40 (Formerly Andy's Butch Built Rig)
81 HJ47 Troopie
82 BJ44 13B-T/H55/Cable Lockers
90 HDJ81 VX Limited
96 FZJ80 Locked
Coxwell-59th Alabama CSA
PacToy is offline   Reply With Quote
Old 01-14-06, 03:37 PM
Sponsored Link
advertisement
Old 01-14-06, 03:37 PM   #40 (permalink)
mikruiser's Avatar
8274-50. it's been perfect.
mikruiser is offline   Reply With Quote
