04-23-05, 11:56 PM
Bolt Pattern and Oil filter for my FJ40....
Here's my deal, I am a new owner and in my research stages just trying to get info so I'm at least educated. I need to know what oil filter I need for my F2 in my 74 FJ40 and I need to know the bolt pattern as I would like to replace the rims. What can I swap and get rims off of?
Thanks a lot!
04-24-05, 02:26 AM
Isn't this just a really easy one? Please help me out a little..
04-24-05, 03:30 AM
I think its 6 on 5.5" and the parts store should be able to tell you what filter to use.
04-24-05, 07:36 AM
Rookie
oil filter
The factory Toyota oil filters are said to be best. Available at any Toyota dealer.
Whatever you do, be sure to use an oil filter with an anti-drainback valve, such as factory or the Fram Tough Guard (not the orange Fram).
Here is the stock rim info from my files:
"6 on 5.5 with a 3.5 inch or less offset. 3.75 will clear drums but not disk calipers. Stock offset is approximately 3.375".
I just switched to stock rims from some nasty wrong-offset ones and I love 'em!
John A
04-24-05, 07:39 AM
Just make sure you get a good oil filter from a parts store the # I cannot remember this early, The bolt pattern is very common, but the back set of the wheel is harder to come by I believe it is 3.25 inches so that it does not hit the front Tie rod ends. Try using the search engine in this tech forum as both have been discussed and cover alot. good luck
81 BJ42 3b full cage, rear locker, rocky mountan Parobolic springs , 4 " lift., 63 Fj45 swb. started rebuild w\ 78 Fj55 running gear (Stalled)
65FJ45 lpb needs work. 2 65 FJ40s parts rigs
Polson MT
04-24-05, 08:53 AM
There are some threads in both the 80 and 60 FAQ about oils, and contained therein are also some opinions as to filters.
Doug G
Seattle, WA
TLCA#12671
04-24-05, 09:26 AM
Ramblin Wreck
You want no more than 3.5" of backspacing. You will have issues with a 15" wheel and more backspacing than 3.5".
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'53 Willys Wagon
ΣΧ
09-14-05, 09:06 PM
there are cheap spacers available from ccot I think they work well .. I guess
"if you wind up with a boring, miserable life because you listened to your mom, your dad, your teacher, your priest, or some guy on tv telling you how to do your shit, then you deserve it" - Frank Zappa
09-15-05, 07:32 AM
Merchant of Death
WIX 51515 its prolly the most common filter made, also fits most Ford trucks ect ect
Truth is a torch that shines through the fog without dispelling it. Always be true to your work, your word, & your friends, & you will never live a day without peace
09-15-05, 11:08 AM
#10 (permalink)
Dain Bramaged Member
Any Chebby Truck six lug wheel fits fine.
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
