Go Back   IH8MUD Forums > Toyota Tech Forums > 40- & 55-Series Tech
Old 04-13-05, 08:16 AM   #1
TLCA# 3968
Saginaw advice needed
I am having trouble with my Saginaw power steering conversion. Basically, it doesn't want to turn left now. When we first finished the conversion, it turned ok in both directions. It turns to the right fine. The pump and both lines are new. I have the Marlin Crawler high steer kit, and have no problems with it. I can't see anything putting the steering in a bind. All of this leads me to believe the problem is in the steering box. Has anyone experienced this before?
R.K.
R.K. is offline   Reply With Quote
Old 04-13-05, 09:53 AM   #2
Admin
woody's Avatar
TLCA# 1548
does it happen with the drag link removed as well?
Brian 'woody' Swearingen
1974 FJ40 'The Raisin' - Pitbull Rockers, 30-spline Longfields, SOA - 1/4 ellip
1996 FZJ80 'Gretchen' - MetalTech, ARB, OME, IPOR, 4x4Labs
2003 2500HD Duramax - Edge/Juice/Attitude, 285 Nitto Terra Grapplers, 4" exhaust
'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln
Old 04-13-05, 01:00 PM   #3
orvis17's Avatar
TLCA# 18820
Get in, while a friend is bleeding your system, turn to both right and left stops...I have heard of air bubbles causing a stop in the range, especially if it worked correctly before the install...
Good Luck
6/72 FJ40, 350, Front discs, h55f, 4"lift, ARB's f/r, 35's, 8274 = FUN
72 FJ40, 78 2F, Headers, 4 speed, 4" lift, 33's...Lots of work to do!
orvis17 is offline   Reply With Quote
Old 04-13-05, 04:25 PM   #4
You have air in lines.... jack the front end up, turn the steering wheel lock to lock 10 to 15 times should get all the air out. Be sure cap is off pump while doing this..
76fj40 4"HFS, saginaw ps conversion, 35's on 15's, galvanized frame
warhorse is offline   Reply With Quote
Old 04-13-05, 05:44 PM   #5
honk's Avatar
Just a thought.....did this by any chance happen after hooking up a steering dampener? If so, see of you didn't put it on in a way that restricts the steering.
Take it loose and try it again.
Specialization is for insects
'77 BJ40 FST;'77 FJ40; '65 FJ40;
honk is offline   Reply With Quote
Old 04-13-05, 05:46 PM   #6
Admin
woody's Avatar
TLCA# 1548
lock to lock, motor OFF...FYI...
Property Search | Loans | Auto Loans | FatCow Web hosting | Provence Properties for sale
