I should've listened to Rob (landcrusher909)when he recommended I do a rebuild thread to avoid seperate posting of different issues I would come across during my mini rebuild. I dont think these are issues I believe some heep neighbor has put a spell on my rig to malfunction in every which way possible.
Ive had 2 issues this past week, first my awful steering wander then the lack of brakes. I tackled the issues based on advise of the members here at mud (thank you all) and they are in the process of getting repaired.
Steering.... much better thanks to new 4 degree shims and some steering component tightening .
Brakes.....a little better but im waiting on new MC (i believe the first one i bought may be bad)which i will bench bleed as suggested by many and then continue with more adjusting and as poser suggested moving rig back and forth to center pads. Im also picking up a vacuum bleeder to help clear all the air.
Well heres the new issue....when I went to start the truck up today to try Posers advice of moving forward/back, it sounded funny. So what do I do ? I start moving around vacuum hoses around.Now it is sputtering/backfiring out of exhaust, the has carbon deposits and ive got 1 extra hose and it sounds far worse actually it may be 2 extra hoses.
I need help, what goes where and what should be capped If anything. Should the emmisions box (mounted on drivers fender)be scrapped. I dont have any other smog components that i know of except for charcoal cannister in bay and on center of bench seat, these I dont mind keeping, as I understand they control gasoline vapors.
My dizzy if I remember correct was set adv, and ive got a petronix flamethrower coil.
I feel like such a dumbarse messing the hose configuration up...
Here are some pics of my mess .
