tucker74
Moderator
I've had an '89 3FE I picked up for $200 sitting in my garage on a stand for over a year, guess it's time to do something with it. Didn't really plan on swapping out a perfectly good 2F, but the deal was too good to pass up and mine didn't have domed pistons to swap just the top end. So last weekend I drained the oil and started tearing off the emissions crap, here's a pic of where I ended up:
Put together a list of parts and started reading threads until they came in Plan was to desmog it and make it stop leaking oil, so off came the valve cover, side cover, main pulley and timing cover after some degreasing. I replaced the valve cover gasket and plugged the air rail with the OEM plugs before turning it on it's side to do this one:
Over it went to slice off the oil pan with a razor knife, damn those cork gaskets suck to get off when they get brittle. Chained it up and pulled the back plate, rear main is pretty easy after you pull the rear bearing cap
Back on the stand for the oil pan gasket, used copious amounts of the black stuff:
So easy to button up when it's upside down Also went ahead and set #1 to TDC and installed the dizzy before it was closed, always want to make sure that sucker is seated correctly in the oil pump.
All torqued down and flipped it back over to tackle the injectors and intake next weekend.
That's where I'm at for now, not bad for a Saturday
To be continued ...
Tucker
To be continued ...
Tucker
